Billet RD-0194/8 Tweeter Bezels
Naturally, I like the VH-7 uber mods
Don't take experimental gene therapies from known eugenicists. -
motorstereo wrote: »Agreed; all great mods. My personal favorites are DK's dreadnaught and the wealth of his knowledge that he so kindly shared.
How did I skip the Dreadnought? I blame 5:30am and not enough coffee..🤣
Edit:
Joe’s Clamp
Rings
Gimpods Boards
Rob’s Tweeter Bezels
Dreadnought
Probably my top 5 of what’s came out of this forum. Am I missing something?
VR3’s Crossover Work stands on its own, each piece is a work of art.
Don't forget dynamatting the driver baskets and adding bh5. -
I received mine.
Great job!
Focus rings and phase plugs
I have 10 plates left over from this run if anyone still needs some.
I modded a set to take a 28mm dome and will experiment with those soon also.
I've been under the weather for a few days...I'm getting better, I think.
I'm dying to install them for sure.
Joe’s Clamp
Rings
Gimpods Boards
Probably my top 4 of what’s came out of this forum. Am I missing something?
Have all four of the above, whatever that says about me!Jay
Got side tracked but received mine on Friday. They look fantastic, Thanks Rob.
Ok well we all know that I am a little bit crazy and I don't have any actual evidence but I do think that I notice an improvement in the over all sound of the 2b's after installing Rob's bezels.
Either way after installing them there is no way I would want those darn plastic ones. I mean they sent right in when you crank down on the screw! And that is a small screw. They can even be seen through the grill! They look, feel and sound better to me. I am glad not to have that plastic anymore. Just always made those replacement tweeters seem cheap to me. Never liked the look after that plastic bent. Thanks a million @xschop. I feel like a millionaire!
Badass. I bet Megadeath never sounded so good lolDon't take experimental gene therapies from known eugenicists.
I didn't...
Now I do.
Had no clue. My friend in HS would play hooky and watch Headbangers Ball on MTV think it was.
No disagreement here!Never liked the look after that plastic bent.
If I torqued too much or too little, that original -194 I designed them from would make the nastiest sound.Don't take experimental gene therapies from known eugenicists. -
I think this is what is known as a Mandela effect?
Same thing as Loony Tunes (not toons), JIF, not Jiffy peanut butter, etc.
They must have graduated from The Quality Learing Center.
I had to super glue 2 ss washers under each screw hole to get them air tight enough yet not deform or sizzle on certain frequencies.
That's quality manufacturing.Don't take experimental gene therapies from known eugenicists. -
8 left from this run.
Anyone building Monoliths?Don't take experimental gene therapies from known eugenicists. -
Yea, I'm not sure why the made the stand off shorter in the RD-0xxx series, makes no sense.
Someone didn't measure twice. -
Made 6 extra alloys plates this weekend.
So 12 leftDon't take experimental gene therapies from known eugenicists. -
8 to go.
PSA:
Dont forget to use a piece of electrical tape over coil leads before installing with 4 factory magnet screws...
and post pics when done.Don't take experimental gene therapies from known eugenicists. -
All out. Where's all the install pics people?Don't take experimental gene therapies from known eugenicists.
I asked Ai to provide a me a picture for you and it did not dissapoint
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I've had other projects going on.
Tools were everywhere on the floor. Kind of congested.
I put in a new transmission in my Toro recycler personal pace mower, and it is DEFECTIVE.
I told them about it, and they said to return it free of charge for review. I ordered another one, and it is arriving today.
I hope I don't feel a momentary stoppage point like I did with the other one. It was a soft stoppage, so I thought the 190cc motor would overcome it, but it didn't. It SUCKED. The left tire would propel, but that was it. I took the geared wheel off and put a free-rolling wheel on, and the mower was 90% or more better, almost like new. I could pull it back EASY. The new trans wouldn't let the left tire roll back or turn at a different rate than the right.
I also had my F150 4-shocks replacement project underway. That entailed one missing the bushings and a replacement shock waiting period for a few days too.
When this is done, or not, I should be replacing those bezels soon.
I have to check on my NAD C370 or (372?) int. amp, Newform speakers, and the wires connected to them on the speaker B connection. My Polk SDA-SRS2s are on speaker A, and they work fine.
They're still AWESOME sounding!
I heard a crackling sound from the Left Newform speaker a few months ago. The Bass cut out then. Then later, the sound cut out completely on the left. I'll check that out at the same time.
