Billet RD-0194/8 Tweeter Bezels
    pitdogg2 Posts: 27,913
    Agreed; all great mods. My personal favorites are DK's dreadnaught and the wealth of his knowledge that he so kindly shared.
    Absolutely!!
    He's missed.
    xschop Posts: 5,913
    Naturally, I like the VH-7 uber mods B)
  • motorstereo
    motorstereo Posts: 2,428
    Toolfan66 wrote: »
    How did I skip the Dreadnought? I blame 5:30am and not enough coffee..🤣
    Edit:
    Joe’s Clamp
    Rings
    Gimpods Boards
    Rob’s Tweeter Bezels
    Dreadnought
    Probably my top 5 of what’s came out of this forum. Am I missing something?
    VR3’s Crossover Work stands on its own, each piece is a work of art.
    Don't forget dynamatting the driver baskets and adding bh5.
    Tony M Posts: 12,029
    I received mine.
    Great job! B)
    xschop Posts: 5,913
    edited April 25
    Focus rings and phase plugs B)
    I have 10 plates left over from this run if anyone still needs some.
    I modded a set to take a 28mm dome and will experiment with those soon also.
    xschop Posts: 5,913
    Tony M wrote: »
    I received mine.
    Great job! B)
    Install pics or else, Tony.
    I've been under the weather for a few days...I'm getting better, I think. :)
    I'm dying to install them for sure. :p
  • agfrost
    agfrost Posts: 2,497
    Toolfan66 wrote: »
    Joe’s Clamp
    Rings
    Gimpods Boards
    Probably my top 4 of what’s came out of this forum. Am I missing something?
    Have all four of the above, whatever that says about me!
    Jay
  • Grabber70Mach
    Grabber70Mach Posts: 79
    edited April 28
    Got side tracked but received mine on Friday. They look fantastic, Thanks Rob.troovamkofsf.jpg
  • VSAT88
    VSAT88 Posts: 1,390
    edited April 28
    Ok well we all know that I am a little bit crazy and I don't have any actual evidence but I do think that I notice an improvement in the over all sound of the 2b's after installing Rob's bezels.
    Either way after installing them there is no way I would want those darn plastic ones. I mean they sent right in when you crank down on the screw! And that is a small screw. They can even be seen through the grill! They look, feel and sound better to me. I am glad not to have that plastic anymore. Just always made those replacement tweeters seem cheap to me. Never liked the look after that plastic bent. Thanks a million @xschop. I feel like a millionaire!
    No disagreement here!
    xschop Posts: 5,913
    Badass. I bet Megadeath never sounded so good lol
    edited April 28
    I didn't... :s Now I do. ;)
    xschop Posts: 5,913
    Had no clue. My friend in HS would play hooky and watch Headbangers Ball on MTV think it was.
    xschop Posts: 5,913
    If I torqued too much or too little, that original -194 I designed them from would make the nastiest sound.
    xschop wrote: »
    I had to super glue 2 ss washers under each screw hole to get them air tight enough yet not deform or sizzle on certain frequencies.
    billbillw Posts: 8,353
    edited April 30
    I think this is what is known as a Mandela effect?
    Same thing as Loony Tunes (not toons), JIF, not Jiffy peanut butter, etc.
    xschop Posts: 5,913
    edited April 30
    They must have graduated from The Quality Learing Center.
    xschop Posts: 5,913
    xschop wrote: »
    That's quality manufacturing.
    edited April 30
    xschop wrote: »
    xschop wrote: »
    Yea, I'm not sure why the made the stand off shorter in the RD-0xxx series, makes no sense.
    xschop Posts: 5,913
    8 left from this run.
    Anyone building Monoliths?
    F1nut Posts: 52,406
    xschop wrote: »
    xschop wrote: »
    Someone didn't measure twice.
    xschop Posts: 5,913
    6 left.
    xschop Posts: 5,913
    Made 6 extra alloys plates this weekend.
    So 12 left
    xschop Posts: 5,913
    10 available.
    xschop Posts: 5,913
    8 to go.
    PSA:
    Dont forget to use a piece of electrical tape over coil leads before installing with 4 factory magnet screws...
    and post pics when done.
    xschop Posts: 5,913
    Down to 4
    xschop Posts: 5,913
    All out. Where's all the install pics people?
    VR3 Posts: 29,758
    I asked Ai to provide a me a picture for you and it did not dissapoint
    edited June 29
    I've had other projects going on.
    Tools were everywhere on the floor. Kind of congested.
    I put in a new transmission in my Toro recycler personal pace mower, and it is DEFECTIVE. :s I told them about it, and they said to return it free of charge for review. I ordered another one, and it is arriving today. :) I hope I don't feel a momentary stoppage point like I did with the other one. It was a soft stoppage, so I thought the 190cc motor would overcome it, but it didn't. It SUCKED. The left tire would propel, but that was it. I took the geared wheel off and put a free-rolling wheel on, and the mower was 90% or more better, almost like new. I could pull it back EASY. The new trans wouldn't let the left tire roll back or turn at a different rate than the right.
    I also had my F150 4-shocks replacement project underway. That entailed one missing the bushings and a replacement shock waiting period for a few days too.
    When this is done, or not, I should be replacing those bezels soon.
    I have to check on my NAD C370 or (372?) int. amp, Newform speakers, and the wires connected to them on the speaker B connection. My Polk SDA-SRS2s are on speaker A, and they work fine. B) They're still AWESOME sounding! <3
    I heard a crackling sound from the Left Newform speaker a few months ago. The Bass cut out then. Then later, the sound cut out completely on the left. I'll check that out at the same time. :)
