Billet RD-0194/8 Tweeter Bezels
12346»
    pitdogg2 Posts: 27,828
    Never liked the look after that plastic bent.
    No disagreement here!
    xschop Posts: 5,783
    Badass. I bet Megadeath never sounded so good lol
    Toolfan66 Posts: 18,399
    xschop wrote: »
    It’s Deth , not Death. But I’m sure you know that!!🤣
    Tony M Posts: 11,977
    edited April 28
    I didn't... :s Now I do. ;)
    xschop Posts: 5,783
    Had no clue. My friend in HS would play hooky and watch Headbangers Ball on MTV think it was.
    xschop Posts: 5,783
    If I torqued too much or too little, that original -194 I designed them from would make the nastiest sound.
    xschop wrote: »
    I had to super glue 2 ss washers under each screw hole to get them air tight enough yet not deform or sizzle on certain frequencies.
    billbillw Posts: 8,164
    edited April 30
    I think this is what is known as a Mandela effect?
    Same thing as Loony Tunes (not toons), JIF, not Jiffy peanut butter, etc.
    xschop Posts: 5,783
    edited April 30
    They must have graduated from The Quality Learing Center.
    xschop Posts: 5,783
    xschop wrote: »
    That's quality manufacturing.
    edited April 30
    xschop wrote: »
    xschop wrote: »
    Yea, I'm not sure why the made the stand off shorter in the RD-0xxx series, makes no sense.
    xschop Posts: 5,783
    8 left from this run.
    Anyone building Monoliths?
    F1nut Posts: 52,347
    xschop wrote: »
    xschop wrote: »
    Someone didn't measure twice.
  • bcwsrt
    bcwsrt Posts: 2,662
    Or, they did, but they used Tom’s ruler …
    Brian
    xschop Posts: 5,783
    6 left.
    xschop Posts: 5,783
    Made 6 extra alloys plates this weekend.
    So 12 left
    xschop Posts: 5,783
    10 available.
    xschop Posts: 5,783
    8 to go.
    PSA:
    Dont forget to use a piece of electrical tape over coil leads before installing with 4 factory magnet screws...
    and post pics when done.
    xschop Posts: 5,783
    Down to 4
    xschop Posts: 5,783
    All out. Where's all the install pics people?
    VR3 Posts: 29,715
    I asked Ai to provide a me a picture for you and it did not dissapoint
    edited June 29
    I've had other projects going on.
    Tools were everywhere on the floor. Kind of congested.
    I put in a new transmission in my Toro recycler personal pace mower, and it is DEFECTIVE. :s I told them about it, and they said to return it free of charge for review. I ordered another one, and it is arriving today. :) I hope I don't feel a momentary stoppage point like I did with the other one. It was a soft stoppage, so I thought the 190cc motor would overcome it, but it didn't. It SUCKED. The left tire would propel, but that was it. I took the geared wheel off and put a free-rolling wheel on, and the mower was 90% or more better, almost like new. I could pull it back EASY. The new trans wouldn't let the left tire roll back or turn at a different rate than the right.
    I also had my F150 4-shocks replacement project underway. That entailed one missing the bushings and a replacement shock waiting period for a few days too.
    When this is done, or not, I should be replacing those bezels soon.
    I have to check on my NAD C370 or (372?) int. amp, Newform speakers, and the wires connected to them on the speaker B connection. My Polk SDA-SRS2s are on speaker A, and they work fine. B) They're still AWESOME sounding! <3
    I heard a crackling sound from the Left Newform speaker a few months ago. The Bass cut out then. Then later, the sound cut out completely on the left. I'll check that out at the same time. :)
    xschop Posts: 5,783
    Tony M wrote: »
    Ok. You're excused. :D
  • dorokusai
    dorokusai Posts: 25,640
    Very nice indeed.
  • ptrooper
    ptrooper Posts: 632
    These Bezels are just so good,Anyone doing any upgrades on their SDA's needs to put this at the top of the list <3 !
  • JCL
    JCL Posts: 174
    Finally got around to installing these plates in the 2.3’s. Originally thought it was going to be a pain to do. It’s actually very easy to replace the plates on the tweeters.1vtdy093xava.jpeg
    L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
    SCompRacer Posts: 9,346
    7C's looking xschop sharp.
    xschop Posts: 5,783
    Great job. Enjoying the pics. I still prefer the Silverface look on the stock cabinets.
