CRS+ RestoMod
You need a different Polk Audio badge that puts the letters on a strip of bacon.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Looking awesome
I for one want a video of you shaking the enclosure
@VR3 ....While the paint's drying lol...
https://youtube.com/shorts/6KXrbCMmJmg?feature=share
Don't take experimental gene therapies from known eugenicists. -
2nd mag fill-in drying...
These would be XSive...
Lol!! Love it, too funny- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Shakin' it up here bossPolitical Correctness'.........defined
President of Club Polk -
😆 hahaha
At least I didnt tie a string too it.
George / NJ
iFi nano iDSD DAC
iPurifier3
Got one double coated, dry, and test fitted. I may hunt down a rattle can with more antique hue for the PR covers...
After a few days curing, will go over them with 000 steel wool....
Looks great
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thanks Tre.Wife thinks so. She has better eye than I do. I'm glad I didn't drill the extra four spots on MW perimeters. Would throw off the retro look. They're growing on me.
WOW!!! Looks Great!! I can go on record and say this is my favorite build you have done/doing..
I didn't make a billet baffle and didn't truck bedliner the cabs. There must be hope lol.
Still need to spin the terminals at a finer grit and find some 5/16" ring elec. terminals. My next shop visit will start the shorter XS Dreadnaught. Can't run the torroid out in the open, wire-nutted lmao.Don't take experimental gene therapies from known eugenicists. -
Tastefully donePolitical Correctness'.........defined
Well, she did mention the 5Jrs complimented the kitchen appliances.
IndeedPolitical Correctness'.........defined
Just awesome.
What are you going to do for stands?
How tall are factory stands?Don't take experimental gene therapies from known eugenicists.
This factory stands quite tall, but its smokestack stands quite a bit taller.
Someone is smoking a stack.Don't take experimental gene therapies from known eugenicists.
I don't recall what the stock height is, but make them 2-3 inches taller..
The stock stands are in the 24" to 25" range...way too short! You want the tweeter at ear height (38" to 40") when seated.Political Correctness'.........defined
I'm assuming those pucks at the top of the stand are half of the neodymium magnetic levitation devices for vibration isolation 👍George / NJ
iFi nano iDSD DAC
iPurifier3
Magnets? Just build a support bar at the top like the original stands. Use rubber pads between it and the cabinet.Political Correctness'.........defined
No magnets. Those 2 spuds would go thru the bottom and compress the sand-filled tubes to their bases using long all-thread.
Will probably be a winter project.Don't take experimental gene therapies from known eugenicists. -
Probably why the 2B's sound great whether sitting or standing.
I Think 30" stands would be the sweet spot. That'll be the goal.Don't take experimental gene therapies from known eugenicists. -
Wow I like the way they are turning out. They look really good.
