CRS+ RestoMod
  • Gardenstater
    Gardenstater Posts: 4,945
    I hope you sopped up all that yoke brutha! 👀
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,838
    edited June 6
    All joking aside, I did tidy up the X-over adapter. The M4 standoffs were ideal (props to @pitdogg2)
    I had to redrill the plate to move one over to an adjacent hole because the original was too close to the pin terminal plastic housing to fit the nylon nut even.
    Added damping foam front(under compression) to back (1/8" PVA) so no vibes will rear their ugly head.
    I'll simply have to drill the factory location to 5/16" so the barrel nut is self-guided thru the rear baffle....
    SCompRacer Posts: 9,399
    Speaking of bacon, that is hardly enough. :) I don't like to cook it inside, so I do it on the grill. I do 3 pounds with the hope of freezing some but only come in with one pound. I'm like that beggin strips dog.
    xschop Posts: 5,838
    Going to double up on my nattokinase and niacinamide.
    xschop Posts: 5,838
    Another midnight run. Detoxing from all the triglycerides.
    Got one done. Had to dremel each slot corresponding to where Polk drilled each PR attachment hole. A couple were slightly off from each other. Joy...
    I can't see the black PR thru it was goal...
  • Gardenstater
    I hope you aren't forced to only play AWB Average White Band on these 🤣
    Looking forward to the Too Much Rope test.......
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,838
    That's Antique White Band material right there.
    xschop Posts: 5,838
    edited June 10
    Was on fence, so went with @VR3 suggestion for magnet attachment since I'll be listening to them with grills off most the time. Polk relied HEAVILY on the larger plastic grill pegs compression as their drilling/matching of grill holes to baffle peg centers were also not accurate.
    3/8" cylindrical neodymiums glued in countersurface by @1/8 depth so I can fill and hide them.
    Just remembered why I preferred metal shop over wood shop. A lot of prep work. I decided to give them a 1/16" round over for looks and better paint adhesion.
    @F1, forgot I had this tucked away from the shop speaker build years ago... Will fill in the mag holes...
    F1nut Posts: 52,406
    I've never used that product.
  • Unknown
    xschop Posts: 5,838
    Takes a couple hours to fully dry being water based, but equivalent to bondo on hardness I remember...
    While that's drying, prepping Erse inductors so there's no vibes going on as they only mount with 2 small screws...
    xschop Posts: 5,838
    Can barely see the indention of the magnets. Should only need a 2nd coat of primer then light sand and they are incognito...
    xschop Posts: 5,838
    Forgot to mention I had a bacon, egg, and cheese biscuit for breakfast. :D
    xschop Posts: 5,838
    Final fill of all dimples....and 400 grit sand tomorrow then final primer....
    These little guys are heavy and can still pick up with the cross-brace and shake....
    Tony M Posts: 12,018
    You HULK'n out? :p
    Why do you have to shake them?
    xschop Posts: 5,838
    edited June 12
    Shook out the drywall crumbs and demonstrated brace/Powergrab effectiveness B)
    Not needed here, but a set of reinforcement semi-rings would only need to go left/right top of the MWs in any CRS without a brace.
    xschop Posts: 5,838
    Final sand and test fitment. The 3/8" barrel neodymiums are solid...
    xschop Posts: 5,838
    Think just a pint of cabinet grade paint will cover these CRS+ 2X coats? Got to stop by Sherwin Williams and get that builder's discount lol.
    Wife says she wants the slight orange peel texture to match as well...Easy Peasy I say...
    VR3 Posts: 29,752
    Looking awesome
    I for one want a video of you shaking the enclosure
    xschop Posts: 5,838
    Two days of prep work calls for 2 days of Bacon @pitdogg2 B)
    xschop Posts: 5,838
    Final coat of flat-white primer just for the driver insets...
    xschop Posts: 5,838
    edited June 12
    Found 1/4 gallon tucked away from last home touch-up. 1st coat and I like that hue....
    xschop Posts: 5,838
    edited June 12
    I think a Megadeth sticker would set these off right. :D
    Thanks Larry. More WAF friendly than the Billet 5Jrs B)
  • Gardenstater
    You need a different Polk Audio badge that puts the letters on a strip of bacon.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,838
    edited June 12
    VR3 wrote: »
    Looking awesome
    @VR3 ....While the paint's drying lol...
    https://youtube.com/shorts/6KXrbCMmJmg?feature=share
    xschop Posts: 5,838
    2nd mag fill-in drying...
    These would be XSive...
    VR3 Posts: 29,752
    Lol!! Love it, too funny
    F1nut Posts: 52,406
    Shakin' it up here boss
    xschop Posts: 5,838
    At least I didnt tie a string too it. :D
  • Gardenstater
    edited June 13
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
