Billet RD-0194/8 Tweeter Bezels
No disagreement here!Never liked the look after that plastic bent. -
Badass. I bet Megadeath never sounded so good lolDon't take experimental gene therapies from known eugenicists.
It’s Deth , not Death. But I’m sure you know that!!🤣
I didn't...
Now I do.
Had no clue. My friend in HS would play hooky and watch Headbangers Ball on MTV think it was.
Don't take experimental gene therapies from known eugenicists. -
If I torqued too much or too little, that original -194 I designed them from would make the nastiest sound.Don't take experimental gene therapies from known eugenicists. -
I had to super glue 2 ss washers under each screw hole to get them air tight enough yet not deform or sizzle on certain frequencies. -
I think this is what is known as a Mandela effect?
Same thing as Loony Tunes (not toons), JIF, not Jiffy peanut butter, etc.
See profile for rigs. Nothing else here. -
They must have graduated from The Quality Learing Center.
That's quality manufacturing.Don't take experimental gene therapies from known eugenicists. -
Yea, I'm not sure why the made the stand off shorter in the RD-0xxx series, makes no sense. -
8 left from this run.
Anyone building Monoliths?Don't take experimental gene therapies from known eugenicists. -
Someone didn't measure twice.Political Correctness'.........defined
President of Club Polk -
Made 6 extra alloys plates this weekend.
So 12 leftDon't take experimental gene therapies from known eugenicists. -
8 to go.
PSA:
Dont forget to use a piece of electrical tape over coil leads before installing with 4 factory magnet screws...
and post pics when done.Don't take experimental gene therapies from known eugenicists. -
All out. Where's all the install pics people?Don't take experimental gene therapies from known eugenicists.
I asked Ai to provide a me a picture for you and it did not dissapoint
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I've had other projects going on.
Tools were everywhere on the floor. Kind of congested.
I put in a new transmission in my Toro recycler personal pace mower, and it is DEFECTIVE.
I told them about it, and they said to return it free of charge for review. I ordered another one, and it is arriving today.
I hope I don't feel a momentary stoppage point like I did with the other one. It was a soft stoppage, so I thought the 190cc motor would overcome it, but it didn't. It SUCKED. The left tire would propel, but that was it. I took the geared wheel off and put a free-rolling wheel on, and the mower was 90% or more better, almost like new. I could pull it back EASY. The new trans wouldn't let the left tire roll back or turn at a different rate than the right.
I also had my F150 4-shocks replacement project underway. That entailed one missing the bushings and a replacement shock waiting period for a few days too.
When this is done, or not, I should be replacing those bezels soon.
I have to check on my NAD C370 or (372?) int. amp, Newform speakers, and the wires connected to them on the speaker B connection. My Polk SDA-SRS2s are on speaker A, and they work fine.
They're still AWESOME sounding!
I heard a crackling sound from the Left Newform speaker a few months ago. The Bass cut out then. Then later, the sound cut out completely on the left. I'll check that out at the same time.
Ok. You're excused.
Very nice indeed.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
These Bezels are just so good,Anyone doing any upgrades on their SDA's needs to put this at the top of the list
Finally got around to installing these plates in the 2.3’s. Originally thought it was going to be a pain to do. It’s actually very easy to replace the plates on the tweeters.
L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800 -
7C's looking xschop sharp.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Great job. Enjoying the pics. I still prefer the Silverface look on the stock cabinets.Don't take experimental gene therapies from known eugenicists.
