Let’s see some Tube Glow!
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,357
    Yes, that's correct and those are EL34 tubes behind them for size comparison.
    mhardy6647 Posts: 35,505
    845 or bust! :)
  • invalid
    invalid Posts: 1,555
    845 or bust! :)
    GM100
  • invalid
  • blademan13
    blademan13 Posts: 8
  • invalid
  • invalid
    pitdogg2 Posts: 27,761
    That is gnarly!!
    treitz3 Posts: 20,275
    Is tube blow blue or bliss?
  • invalid
    Those old globe style 866 tubes from the 1920's sure do light up better than the later 866a version.
    edited June 2025
    A couple of Raytheon windmill getters and a Raytheon black plate 12ax7 in the signal path.
    Ear candy
  • bcwsrt
    bcwsrt Posts: 2,639
    Nice pics!
    Brian
  • invalid
    mercury vapor...
    B)
  • invalid
    mercury vapor...
    B)
    Old globe 866, these old ones seem to have a better glow, as I'm using them with a tube preamp, not much current draw.
  • bcwsrt
    bcwsrt Posts: 2,639
    Trying out the camera on the new iPhone …
    Brian
    heiney9 Posts: 25,625
    edited November 2025
    whoops... ne'er mind. :/
  • pearsall001
    pearsall001 Posts: 5,384
    Clipdat Posts: 13,101
    bcwsrt wrote: »
    Looking good! What kind of KT88s are you running? Such a smooth sounding power tube!
    Edit: Wait a sec, I guess those are actually KT120s?! My bad!
  • newbie308
    heiney9 wrote: »
    I remember when this kit was being introduced. I was intrigued by it and really wanted to build one. I remember signing up to be notified when they were available, but never got an email. How does it sound?
  • bcwsrt
    bcwsrt Posts: 2,639
    Good eye! They are Tung-Sol KT120s.
    I will probably give some KT88s a try next, though.. Hear good things about Genalex.
    Brian
    newbie308 wrote: »
    heiney9 wrote: »
    Superb. It's amazing what a few parts implemented correctly can sound like. Simple circuits always sound better.
    The ambient retrieval, open and transparent are all excellent. The NuTube adds just enough warmth and adds to already excellent dimensional information. It's super quiet too.
    If you want less 2nd harmonic you can adjust the voltage to the cathode with the two trim pots.
    FYI, the kits are back in stock as of today. It's been a long wait.
    The only area I see that can make a pretty big improvement is the volume pot. A standard ALPs is included which does a good job. But to take the unit another level I'm getting a TKD shunt type volume pot.
    This is in my office rig running a pair of Pass ACA mono's in parallel configuration. Since it's more near field and lower volume listening an excellent tracking volume pot is essential.
    Speakers are Polk Audio R200's and they have never sounded better!
    I didn't build this one, I bought it assembled from a great seller.
    bcwsrt wrote: »
    I recently picked up a quad of GoldLion and also JJ KT88s for my Cayin Jazz 90 integrated. Will let you know how they are once I try them.
  • tonyp063
    tonyp063 Posts: 1,153
    Some old friends from Great Britain have come to visit for Christmas.
    Nice XF2 Mullards! Score!
    Viking64 Posts: 7,764
    I don't have any tube glow, but I sure could use some tub glue. :#
  • TEAforONE
    TEAforONE Posts: 1,100
    Viking64 wrote: »
    Try a little calk. That should do the trick.
    audioluvr Posts: 6,053
    Had a tube go bad so I'm doing some rolling!
    Schiit Valhalla 2
