You’re doing it wrong…
    F1nut Posts: 52,175
    Yuck
  • daddyjt
    daddyjt Posts: 3,193
    ― Aleksandr Solzhenitsyn
    mhardy6647 Posts: 35,400
    ^^^ I would totally do that. Or put a stub of pipe on that tee, get one of those caps, you know, and drill a hole in it, then glue in a piece of the small-diameter pipe with some PVC cement. The solution above is more elegant though.
  • daddyjt
    I have certainly utilized some creative PVC fitting combinations over the years… In a pinch you use what you have;-)
    audioluvr Posts: 6,016
    Clipdat wrote: »
    That setup rocks! Those are some museum quality pieces!
    Clipdat Posts: 13,101
    Then put them in a museum, instead of on the top of a pair of speakers.
    pitdogg2 Posts: 27,603
    Yea you need clay pots with plants on top to give them a glow ..after watering
  • sucks2beme
    sucks2beme Posts: 5,697
    That guy better have an inner tube inside that tire.
  • CGTIII
    CGTIII Posts: 1,264
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
    treitz3 Posts: 20,211
    sucks2beme wrote: »
    For what? The next mile and a half? If that...
  • sucks2beme
    treitz3 wrote: »
    sucks2beme wrote: »
    For the cheap amusement of watching the guys at discount tire try to remove the tire
    from the rim. They don't know how to deal with an inter tube. I saw this once. Those guys
    are so used to no braining their work, their heads exploded. That tire didn't look much
    better than the one pictured.
    msg Posts: 10,555
    That's like that meme someone posted recently about the guy who went to an auto parts store asking for some specific bulk fuel line, and the counter rep's brain suffered an unexpected reboot, requiring year, make and model to be able to function.
  • bcwsrt
    bcwsrt Posts: 2,588
    bcwsrt wrote: »
    That happened to me today. I went into NAPA and asked for a gallon jug of Mobil 1 5w40 turbo diesel truck oil.
    There is a better way to check for air leaks.....I guess this cat didn't get the memo...
    txcoastal1 Posts: 13,519
    Well Tom, like mentioned before…It’s effing hot…a dip in the pool to cool off
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    Ssshhhh, it's taking a nap
    Well, I am glad today's a slow news day.
    That's about all I have to say. :#
  • skipshot12
    skipshot12 Posts: 2,105
    ^ Not anymore….
  • stangman67
    stangman67 Posts: 2,330
    skipshot12 wrote: »
    ^ Not anymore….
    Whoosh, right over the head
    F1nut Posts: 52,175
    Still buzzing the tower...
  • skipshot12
    Can this year get any weirder?
    That should be a thread…..
    Blissfully unaware.
  • mrbigbluelight
    skipshot12 wrote: »
    Can this year get any weirder?..
    To quote BTO,
    "YOU AIN'T SEEN NOTHING YET"
    All caps, in Bold for emphasis.
    I could throw in a Ray Bradbury quote, maybe something from Shakespeare, too 🤔
    But ...nope. 👀
  • daddyjt
    Careful guys - we don’t want to wake the trolls and have another thread deleted….:-(
    Time for a “salad”….??
    I want to thank you for the opportunity….since you have given me the opportunity….I will cherish this opportunity…..with this opportunity I will provide opportunity
