Quick recovery for NooshinJohn
12346»
    SCompRacer Posts: 9,112
    The wife has diverticulitis and has been through this. Nothing brings you closer than dealing with a colostomy bag. Wishing you a successful surgery and speedy recovery!
    pitdogg2 Posts: 27,045
    Best of luck John!🍀🍀🍀🍀
  • erniejade
    erniejade Posts: 6,321
    Hope everything turns out OK.
  • aprazer402
    aprazer402 Posts: 3,386
    edited May 2024
    Best wishes and prayers. Insist on solid copper, no PEX or PVC. You'll do fine.
    Edit: Oh my, talking about waste not supply, go with whatever the doc's recommend I guess. :)
    Best to use all your own parts!
  • Milito
    Milito Posts: 2,003
    Good luck John and have a fast recovery.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    You're a Marine, so you got this.
    As a Marine, you're supposed to be surrounded.
    As you can see by all the well wishers, in this case they're all friendlies, so while it's a bit of a pain in the a$$, it's no sweat 🤗
    At least you don't have to worry about sand fleas.
    Semper Fi 🎖️🇺🇲
  • GlennDog
    GlennDog Posts: 3,152
    swift recovery and prayers sent . . . STAT
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • JCL
    JCL Posts: 169
    Best of luck on the surgeries and a speedy recovery.
    L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
  • indyhawg
    indyhawg Posts: 1,672
    Best wishes on the surgery and may you have a speedy recovery.
  • HzTweaker
    HzTweaker Posts: 959
    Good luck and a speedy recovery!
  • bcwsrt
    bcwsrt Posts: 2,410
    Praying for God’s wisdom and guiding hand for your medical team and and a speedy and thorough recovery for you, John!
    Brian
  • PSOVLSK
    PSOVLSK Posts: 5,381
    Best of luck John. I hope everything goes well.
  • Joey_V
    Joey_V Posts: 8,600
    Time to drag this back out… tomorrow begins the workups for the surgery to put my septic system back together. I will have consults with cardio, general surgeon, urology, and colonoscopies done. Then I will be meeting again with the surgeon doing the reassembly of my colon. He feels that the surgery will take place during the first half of July. Three procedures will be done at the same time, and will take 7 to 9 hours to complete, followed by 7 to ten days in the hospital for recovery and to ensure the plumbing work holds up without complications.
    Getting old sucks…
    Good luck man
    7-9 hours
    That’s a long surgery, this must be complex. I’m sure you have a highly competent surgeon. These guys who do these multi hour surgeries are commendable. I remember being scrubbed in a few of these when I was in med school… you wonder how they can hold their bladder for that long.
    I’m sure it’ll go well. You’ll be fine.
  • Jetmaker737
    Jetmaker737 Posts: 1,116
    Hope it all works out in the end! Pun intended. Jokes aside, pretty scary. Hope it goes smoothly.
    nooshinjohn Posts: 25,921
    All these damn tests have me feeling this today...
    https://youtu.be/pFfQDqY6mC4?si=6OU5_uUC2jXHZr9R
