The Grande Utopia Project
17810121316
    VR3 Posts: 29,513
    I really don't want to lead you on... That's probably not going to happen 😜
  • That mid does look like it is already designed so as to minimize reflections back at the cone, even though the spokes are wide, because of the angle of them and the absence of a lip around the spider between the spokes. :)
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,301
    Understand, the foam gets a little pricey.
  • jdjohn
    jdjohn Posts: 3,375
    VR3 wrote: »
    Crazy talk. Next, you're going to say you won't even be Dynamat'ing them ;)
    Seriously, though, are those red pucks on the woofer individual magnets?
    VR3 Posts: 29,513
    edited December 2023
    So.... no mids in these pictures. That is the 10" woofer and the 15" subwoofer.
    The 15" has 16 neodymium magnets and is a real tank at over 40 pounds!
    No foam or dynamat!
    Edit: I *might* consider dynamat
    Post edited by VR3 on
    VR3 Posts: 29,513
    Made some room last night!
    pitdogg2 Posts: 27,187
    Clipdat Posts: 13,100
    That rust can't be good.
    treitz3 Posts: 20,057
    It may not be rust. Could be that the electrolytes have seeped out over time. This is an older speaker, so there is that...
    Upon closer inspection it does look like leakage:
    VR3 Posts: 29,513
    New wiring team for the bass network and this officially preps them to be a 4 way active loudspeaker!
    Next to install the remainder of the parts
    VR3 Posts: 29,513
    Getting closer!
    txcoastal1 Posts: 13,514
    Well you have a 3 day weekend..."getter done"... :p
    VR3 Posts: 29,513
    Haha yeah right, quality daughter time ahead! I might be able to squeeze in some late night work though! 😅
  • jdjohn
    jdjohn Posts: 3,375
    VR3 wrote: »
    Do you mean 'active', as in 'powered'? Sorry if I missed that earlier.
    nooshinjohn Posts: 25,963
    jdjohn wrote: »
    VR3 wrote: »
    Phase plugs are in the works...
    VR3 Posts: 29,513
    So the main push behind this build was because I was absolutely consumed with this idea of what it would look like if the Grande could be a 4 way active loudspeaker... I mean like... consumed just mulling it over back and forth. Eventually I was just like... eff it! I took that idea, the user swappable resistors, etc and essentially decided to fully rewire, fully mod AND make them a 4 way active loudspeaker.
    So in maybe 30 minutes... disconnect some wires, relocate some jumpers... the grande will be capable of fully bypassing the internal crossover and ready to be hooked up to an external active crossover and 8 channel of amplification...
    The only missing piece will be the new binding post array, I will need 16 x WBT posts (8 per side)... that is a hefty investment. (the existing WBT posts have some corrosion on them)
    I dont have the immediate goal to try active, I just wanted to see what that looked like in reality and have the option when I am so inclined in the future.
    I can of course go partially active/passive. Running the bass fully active would be an easy achievement to accomplish!
    Anyways... this has been a brain racking project... between thoughts, design, building, tear down, etc... easily hundreds, maybe a thousand plus hours invested! lol
  • jdjohn
    jdjohn Posts: 3,375
    Ah, so active crossover, not active/powered speaker.
    VR3 Posts: 29,513
    Correct, active crossover capable. Many years away! But I like the idea its capable!
    jdjohn wrote: »
    VR3 wrote: »
    lol, zero benefit of phase plugs on subwoofers.
    The mids already have phase plugs though :-D
    Viking64 Posts: 7,598
    My plugs don't phase me.
  • jdjohn
    jdjohn Posts: 3,375
    Viking64 wrote: »
    Looks very natural...you do you.
    Looks painful... :#:#:#
    VR3 Posts: 29,513
    VR3 Posts: 29,513
    Bass resistors installed and wired up!
    Probably should sweep out the Cheetos crumbs.... :D
    VR3 Posts: 29,513
    The cheetohs add texture brother!
    The next part is mounting the 168uf midrange cap cluster... Already 3 hours into the design and still working out the details, will be tough
    VR3 Posts: 29,513
    xschop Posts: 5,301
    Faster bass response because of the large drivers?
    VR3 Posts: 29,513
    using multiple smaller caps (5 x 33uf) plus a small bypass cap (.022uf) should translate into faster transients and response compared to a single large 168uf cap).
    The other issue is you cant find a CMR or higher quality cap in that value and I doubt it would fit if they did! lol!
    The CMR 168 is for the midrange and the CSA is for the bass. The bass network is pretty straight forward with the cap/resistor for a zobel network.
    The 168uf and 75uf in the midrange network are directly in line with the positive amplifier terminal and the drivers so I wanted to go as high of quality as I could.
    xschop Posts: 5,301
    Nice work again. Midrange/midbass transients are always the first notable improvement when doing mods, whether electrical or physical.
