Post a picture... any picture
I think the vehicle industry has done well with 4 door trucks. Their making them to fit 4-5 passengers comfortable. I have a 4dr Tacoma & use a utility trailer if I need sheets of plywood. When I stop n think of it. How often did I use the back bed of truck ? Not daily but it was there when needed. Heck if you can't afford a utility trailer Uhaul rents them for under 20.00 for a day. Win winRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
My 2021 F150 holds 4x8 sheets just fine.
mhardy6647 wrote: »Here's the biggest secret in all of the auto industry. If you want to carry a 4 x 8 sheet of plywood, the best vehicle is... a minivan! Keeps it dry, too.
That is a great and valid point. Only one problem with that. It won't haul 42 sheets of plywood or sheet rock, plus other supplies with a loaded trailer in tow. At least not safely. That's sometimes a very normal load for a work truck.
Harry Homeowner? Sure. Contractor who needs a HD work truck? Not a chance.
Although, I have seen some painters here locally that will stack an untold amount of ladders on the roof of a minvan and somehow they make it down the highway (usually doing 47 in the fast lane). Of course, you can't see the top of the rear tires and they do nothing but infuriate you but....
She scares mePolitical Correctness'.........defined
President of Club Polk -
If Lemmy had a Pug.
(as seen on ASR)
I think I either need way more coffee... or way less.
Dali's house, maybe?
How fast was that column going???Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Brake lights still work!Gustard X26 Pro DAC
23_0015412 Convair Negative Image by SDASM Archives, on Flickr
Test launching a Tomahawk missle (from Convair/General Dynamics' archive, via SDASM).
That would be a fun field day for work, I would think.
23_0014648 Convair Negative Image by SDASM Archives, on Flickr
Looks like a bad day for -- a bunch of folks.
... and another vision of a future that didn't happen, from Convair.
23_0014665 Convair Negative Image by SDASM Archives, on Flickr
23_0014647 Convair Negative Image by SDASM Archives, on Flickr
Alternate caption: You may be cool, but you're not let's take the F-106 to work today cool.
I bet they have trouble sleeping in on a Monday morning when traffic gets heavy.
I dont think the 2 cats are still in the yard.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
(ASR)
^ Sales brochure:
"Easy access to interstate" -
I dig this!! McChord AFB took me from TX back in 79. I rigged the personnel parachutes for the pilots that flew the F-106 and T-33's. The 106 also had a deceleration parachute that deployed upon landing that I also rigged.
And because I was their rigger, they took me up in a T-33 ride. Had I obtained my altitude chamber card, I could have gone up in a 6. But the 33 was certainly no slouch. @mhardy6647 thanks for posting memories for me
Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB9000-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-11.2 -
I had a friend in High School who's younger brother was pissing off the dock at Lake Lewisville many years ago and his piss hit an exposed electrical line. It killed him. Horrible way to go needless to say.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream -
https://www.youtube.com/watch?v=YZKCa2gD1BA
