You’re doing it wrong…
Or a persuader... piece of pipe 2 or 3 feet long on the wrench. Torque. It's a thing. -
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
Oh yea a cheater bar is a god send!! -
Well, do you expect them to mow that field in the dark? DUH!
Just maybe the someone put the road on the wrong side..... 🤔
Yeah, that's gonna hold for all of about zero seconds. This is in the Ford you just did you new bedliner for? I thought so. Didn't you just post recently that your RTA-15TLs sound best aimed inward at your TV?Deleted User wrote: »
Judging from the gnarliness of those nuts - well never mind, I'm not gonna comment on gnarly nuts. That problem should be fixed once Fall arrives and the humidity dissipates.
Anyone got Aldi nearby? I need people to buy Burman's sauces for me. Out of stock for the season here.
But not you, Brian. I'm not sure these are safety-sealed, and I don't trust you with the avocado one.
I disabled signatures. -
Anyone got Aldi nearby? I need people to buy Burman's sauces for me.Deleted User wrote: »
I hit three or four occasionally. How many of each do you want if I can find them?Expect that there will be bumps in the road. Choose to not let them rattle you.
Ooh! Sorry for the late response - long week so far!
Thank you! As many of the Polynesian ones as you can find, say, up to 12?, and 3ea of the Avocado and Garlic, please, if you can find them? I've not had those two.I disabled signatures. -
Will do. May take a week to reach them all.Expect that there will be bumps in the road. Choose to not let them rattle you.
ken brydson wrote: »
And then whizzed on it. Something about processed electrolytes for signal optimization.I disabled signatures. -
It's called humor
kickerofelves wrote: »
The Dunning-Kruger effect! Man I forgot the name of that. I'm a chronic sufferer...My gear:- TCL 75QM7K TV
- Onyko TX-NR656 AVR
- RT3000p Fronts
- CS1000p Center
- RT35 Side Surrounds
- RT35 Rear Surrounds
kickerofelves wrote: »Blah blah...
The first one that resorts to name calling is the loser. Yep, that's you. -
