You’re doing it wrong…
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
Not doing it wrong if it works and Joe Homeowner is obviously making it work with what he has. More than likely he doesn't have an impact or compressor as he doesn't even have a decent car jack. If anyone has worked on those nuts they would know that quite often even a good quality snap on air impact with lots of air pressure behind it won't budge those nuts.
Two strong baboons; one with a 3/4'' t bar and pipe and the other with a heavy duty pipe wrench with a pipe for the win. -
Or a persuader... piece of pipe 2 or 3 feet long on the wrench. Torque. It's a thing. -
Well, do you expect them to mow that field in the dark? DUH!
Yeah, that's gonna hold for all of about zero seconds. This is in the Ford you just did you new bedliner for? I thought so. Didn't you just post recently that your RTA-15TLs sound best aimed inward at your TV?
Judging from the gnarliness of those nuts - well never mind, I'm not gonna comment on gnarly nuts. That problem should be fixed once Fall arrives and the humidity dissipates.
Anyone got Aldi nearby? I need people to buy Burman's sauces for me. Out of stock for the season here.
But not you, Brian. I'm not sure these are safety-sealed, and I don't trust you with the avocado one.
I disabled signatures. -
I hit three or four occasionally. How many of each do you want if I can find them?Expect that there will be bumps in the road. Choose to not let them rattle you.
Ooh! Sorry for the late response - long week so far!
Thank you! As many of the Polynesian ones as you can find, say, up to 12?, and 3ea of the Avocado and Garlic, please, if you can find them? I've not had those two.I disabled signatures. -
Will do. May take a week to reach them all.Expect that there will be bumps in the road. Choose to not let them rattle you.
