You’re doing it wrong…
1…6791112…132
  • CGTIII
    CGTIII Posts: 1,274
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
  • Unknown
    edited September 2023
  • CGTIII
    CGTIII Posts: 1,274
  • CGTIII
    CGTIII Posts: 1,274
  • motorstereo
    daddyjt wrote: »
    So many things wrong yet sort of genius had they just used the ground and the flats or collar under the ball if it didn't have flats....or hey a tool called an impact
    Not doing it wrong if it works and Joe Homeowner is obviously making it work with what he has. More than likely he doesn't have an impact or compressor as he doesn't even have a decent car jack. If anyone has worked on those nuts they would know that quite often even a good quality snap on air impact with lots of air pressure behind it won't budge those nuts.
    Two strong baboons; one with a 3/4'' t bar and pipe and the other with a heavy duty pipe wrench with a pipe for the win.
  • kevhed72
    kevhed72 Posts: 5,228
    daddyjt wrote: »
    I'll take "what is a fire hazard" for 800 Alex...
    mhardy6647 Posts: 35,562
    daddyjt wrote: »
    Or a persuader... piece of pipe 2 or 3 feet long on the wrench. Torque. It's a thing.
  • ken brydson
  • CGTIII
    CGTIII Posts: 1,274
  • CGTIII
    CGTIII Posts: 1,274
  • CGTIII
    CGTIII Posts: 1,274
    txcoastal1 Posts: 13,520
  • motorstereo
  • ken brydson
    Viking64 Posts: 7,811
    Well, do you expect them to mow that field in the dark? DUH!
  • bcwsrt
    bcwsrt Posts: 2,687
    Brian
    msg Posts: 10,650
    bcwsrt wrote: »
    Yeah, that's gonna hold for all of about zero seconds. This is in the Ford you just did you new bedliner for? I thought so. Didn't you just post recently that your RTA-15TLs sound best aimed inward at your TV?
    Judging from the gnarliness of those nuts - well never mind, I'm not gonna comment on gnarly nuts. That problem should be fixed once Fall arrives and the humidity dissipates.
    Anyone got Aldi nearby? I need people to buy Burman's sauces for me. Out of stock for the season here.
    But not you, Brian. I'm not sure these are safety-sealed, and I don't trust you with the avocado one.
  • bcwsrt
    bcwsrt Posts: 2,687
    You forgot I have your address, didn’t you? 😂
    Brian
  • CGTIII
    CGTIII Posts: 1,274
    msg wrote: »
    bcwsrt wrote: »
    I hit three or four occasionally. How many of each do you want if I can find them?
    msg Posts: 10,650
    CGTIII wrote: »
    msg wrote: »
    bcwsrt wrote: »
    Ooh! Sorry for the late response - long week so far!
    Thank you! As many of the Polynesian ones as you can find, say, up to 12?, and 3ea of the Avocado and Garlic, please, if you can find them? I've not had those two.
  • CGTIII
    CGTIII Posts: 1,274
    msg wrote: »
    CGTIII wrote: »
    msg wrote: »
    bcwsrt wrote: »
    Will do. May take a week to reach them all.
  • CGTIII
    CGTIII Posts: 1,274
  • CGTIII
    CGTIII Posts: 1,274
