You’re doing it wrong…
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
I think the puzzled sage finally figured it out.
There lived a sage in days of yore,
And he a handsome pigtail wore,
But wondered much and sorrowed more,
Because it hung behind him.
He mused upon this curious case,
And swore he'd change the pigtail's place,
And have it hanging at his face,
Not dangling there behind him. -
The poophouse poet…The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
― Aleksandr Solzhenitsyn -
So many things wrong yet sort of genius had they just used the ground and the flats or collar under the ball if it didn't have flats....or hey a tool called an impact -
Not doing it wrong if it works and Joe Homeowner is obviously making it work with what he has. More than likely he doesn't have an impact or compressor as he doesn't even have a decent car jack. If anyone has worked on those nuts they would know that quite often even a good quality snap on air impact with lots of air pressure behind it won't budge those nuts.
Two strong baboons; one with a 3/4'' t bar and pipe and the other with a heavy duty pipe wrench with a pipe for the win. -
Or a persuader... piece of pipe 2 or 3 feet long on the wrench. Torque. It's a thing. -
Oh yea a cheater bar is a god send!! -
Well, do you expect them to mow that field in the dark? DUH!
Just maybe the someone put the road on the wrong side..... 🤔
Yeah, that's gonna hold for all of about zero seconds. This is in the Ford you just did you new bedliner for? I thought so. Didn't you just post recently that your RTA-15TLs sound best aimed inward at your TV?
Judging from the gnarliness of those nuts - well never mind, I'm not gonna comment on gnarly nuts. That problem should be fixed once Fall arrives and the humidity dissipates.
Anyone got Aldi nearby? I need people to buy Burman's sauces for me. Out of stock for the season here.
But not you, Brian. I'm not sure these are safety-sealed, and I don't trust you with the avocado one.
