1159160162164165203
  • skipshot12
    skipshot12 Posts: 2,092
    edited February 2023
    Blurry shart happens when a 65 year old is dancing.
  • stevep
    stevep Posts: 362
    Picture depicts the excitement
    pitdogg2 Posts: 27,300
    65? You had better calm down before you stroke out
  • skipshot12
    🤣 I'm coming Elizabeth....
  • skipshot12
    Have started a new thread about the Phase Linear above...
    "Phase linear & High-Tech Audio."
    Didn't wish to clog up this thread with my journey.
    audioluvr Posts: 5,987
    You should start a couple more... Might be fun 😜
  • jbreezy5
    jbreezy5 Posts: 1,141
    Installed a pair of Canare xlr cables allowing me to run fully balanced from Ares II > B&K Ref 50 > Ashly EQ > B&K ST 125.2!
    Cambridge Audio CXC transport as source via KK DV30 digital coax.
    Sound is smooth, warm, and detailed w/o harshness. Canare xlrs are sandwiched between Monster xlrs in the signal chain.
    Thinking about going all Canare now. Really a great sounding low-cost cable.
  • Reagan
    Reagan Posts: 116
    Nice B&K! I have a B&K REF 200.2. Thinking about either selling it or giving it to my son in law.
    Speakers: Polk 1.2TL w/VR3 mods and Dreadnaught interconnects
    Amplification: ARC Reference 110 w/KT150s; Cary Audio SLP-05 w/Ultimate Upgrade
    Vinyl: VPI HW19 MK III (Heavily Modded); Origin Live Silver Tonearm; Hana ML Cart; Pete Riggle VTAF; VPI TNT Platter; SAMA; Iphono3
    Digital: Aurender N100H; Benchmark DAC1
  • Reagan
    Reagan Posts: 116
    What about buying Canare cable and making up Neutrik XLR connectors.
  • jbreezy5
    Reagan wrote: »
    Canare use Neutrik xlrs.
    treitz3 Posts: 20,113
    Switched out a throttleneck.
    What a huge difference.
  • treitz3 wrote: »
    What do you mean ?
    Streaming portion of rig. Switched out an Audioquest to a Transparent.
    The difference is literally akin to replacing an amplifier from a a low level to high end in my rig.
    When you get to a certain level of reproduction, the differences between what you have on hand that (in the past) didn't amount to much? Holy crap.
    They do now. In ALL aspects and in ways that are unfathomable. With so many things...
    More later. I am tired but can't stop listening.
  • Reagan
    Reagan Posts: 116
    I replaced ALL iron in my home brew KT88 SET. For the PT, used a smaller power transformer. Lowered B+ voltage and thus lowered current going through the tubes. Much less stress on the tube. Better grid admittance. Sweeter sound. Current swings! Much longer tube life. Changed output transformers to lower impedance. Again, allows current to really swing! Lower DCR with meatier wires and lower DCR. Then, last but not least…changed my single 10 Henry choke “pi” type power supply to an “L” power supply using two ultra low DCR, ultra low Henry (800 mHy each) chokes. Added four DCLink bypass caps. This is a very fast (responsive) power supply. Everything is still burning in but can’t wait to get home to listen.
  • Reagan
    Reagan Posts: 116
    I bought Canare 4S11 Star Quad Speaker Cable, 14AWG for $1.40 a ft and the Neutrik Speakons were less than $6 each. I’ve never used Canare for balanced I/C but imagine they are nice. Now that I have gone rogue with SET amps, I only use single ended I/Cs.
  • WagnerRC
    WagnerRC Posts: 2,209
    Playing the moving game around. Its been awhile since I fired up the Joule LA300. I love my SLP05 but the Joule just takes everything to another level. Jud did know his game. Happy Happy xi2gg989wj0e.jpeg
  • Dr_Wu
    Dr_Wu Posts: 356
    Put the entire system through a PS Audio P10 PerfectWave regenerator. May be done. Except now I need a new rack big enough for this beast and an A21 Halo. Ideas?
  • jdjohn
    jdjohn Posts: 3,381
    Not my rig, per se, but did a little triage/purging today from my dad's collection. After testing, and attempts to revive, I threw out two turntables. One was a Technics SL-B303, and the other a Sony PS-LX340. The Technics SL-B303 had to be one of their cheapest, lowest-quality options...just not worth the effort. As far as Sony turntables: did they actually make any decent turntables? Good grief...I've worked on at least four different Sony turntables from my dad's collection, and only one has survived as usable. And even that one (a PS-2350) required some 'shaving' off the motor pulley in order to get the speed right, since it has no fine-pitch adjustment.
    On a positive note, the Realistic STA-76 receiver pulled from storage today has worked like a champ!
    Here is a pic of the surviving Sony turntable with the Rat Shack receiver:
    Running the SBT (top right) through the receiver sounded very nice as well B)
  • jbreezy5
    jdjohn wrote: »
    At least it’s a nice looking TT.
    mhardy6647 Posts: 35,228
    Working (as hard as I can against my own inertia) to cull the herd.
    The "New England Vintage Electronics Expo" (sale/swapmeet/fleamarket thing) is Sunday.
    This is a moderately uncommon, attractive, but largely unremarkable item that I've had for a long time and, other than its aestetics, never really bonded with. Dragged it out, cleaned it up a little and I'm testin' functionality even now. It works. Looks like a lamp or two may be out -- I'll pop the hood anon.
  • xsmi
    xsmi Posts: 1,804
    Nice looking piece.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
    ... and the 1060 that didn't make the cut in the election ;)
    (a bit grubby but proud)
    I did a face transplant with the (otherwise) better one. B)
  • engie490
    engie490 Posts: 444
    Fired up the Martin Logan CLS-IIZs. They sounded like poo on the short end of the room. Sound awfully good now.
    Damn. I'm supposed to be downsizing...
    Infinity RS-1Bs / Bryston 7B STs / Sonic Frontiers Power 2 / Jeff Rowland Consonance / Bluesound Node 130 /Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
    engie490 wrote: »
    Nice setup!
  • engie490
    engie490 Posts: 444
    stangman67 wrote: »
    Norfolk, headed to United States Fleet Forces Command. Just transitioned off my department head rides (Surface Warfare Officer)
    Fair winds and following seas!
  • engie490
    engie490 Posts: 444
    audioluvr wrote: »
    engie490 wrote: »
    Nice setup!
    Thanks! But now I've got to try them with the Kinergetics SW800s. I suck at this downsizing stuff!
  • jbreezy5
    engie490 wrote: »
    IMO those speakers are small enough; you should keep them. 🙃
  • rebelsoul
    rebelsoul Posts: 758
    When my wife talks about downsizing and looking at my stereo, I ask her where she's going.
  • stangman67
    stangman67 Posts: 2,328
    edited March 2023
    Not really today, been in the stereo for a week but I’m comfortable enough with it now to speak on it a bit. Got a Lumin U2 Mini from Skip and got it installed along with an AQ Cinnamon ethernet cable. First couple hours were rough as it was very very bright, and my right ear is very sensitive to harshness and will start to buzz badly (medical community says there’s nothing wrong with me of course)
    I let it play constantly for 30 hours and re-evaluated and like what I am hearing now. Haven’t done the Sbooster yet, not real comfortable voiding the warranty right now.
