1…157158160162163…206
  • jbreezy5
    jbreezy5 Posts: 1,141
    VR3 wrote: »
    Man it may be time to clean the closet if you have that much in hand lol
    You’re the one whom told me to buy all this Schiit! 😂
    treitz3 Posts: 20,364
    LOL....'bout spit my drink out when I read that!!!
    Awe, chit son!
    VR3 Posts: 29,752
    Well, if this is true, then you need to throw out the cabinet and upgrade to a storage unit!
  • jbreezy5
    Nuff said, lol
  • michaeljhsda2
    michaeljhsda2 Posts: 2,219
    edited February 2023
    Installed this GFCI with manual reset in case there's a loss and sudden return of electricity to my tube amp.
    https://www.amazon.com/TRC-14650006-6-Shockshield-Protection-Unmonitored/dp/B000XVG72G
    SDA SRS 2.3TL's
    SDA 2B TL's
  • jdjohn
    jdjohn Posts: 3,445
    jdjohn wrote: »
    A while ago, I bought a Denon DP-3000 turntable that ended-up having erratic speed fluctuations. Finally got around to doing a PCB refresh with 13 new transistors, and 9 new electrolytic caps.
    Testing afterwards has been very successful! :)
    I posted about this setup before, with the goal of having a Micro Seiki MA-505L (12") arm mounted on the large Denon DK-110 plinth B)
    Even after replacing 22 PCB components, I still had speed fluctuation issues with this unit. Generally, I had been following guidance from this website: https://www.leson.org/the-denon-dp-3000-project-unidentified-fulfilling-object/
    During my remove-and-replace exercise of electrolytic caps, and the main board transistors, with recommendations obtained from the leson.org website (previously referenced), there were three transistors curiously omitted - the (3) 2SC1222 transistors. So, I left the old ones in place, thinking they must not play a significant role in speed regulation.
    Then, after replacing the 22 board components (call it 23 since I also replaced the TA7061AP IC chip), and still not having success in regulating the speed, and with nothing to lose, I ordered three of the 2SC1222 transistors @ $2USD/each, plus shipping. While removing the remaining three transistors, one of the circular soldering pads partially lifted off the PCB, and about 1/3 of the 'circle' broke-off. Fun! Luckily, I have a few PCB repair supplies from circuitmedic.com, and a tiny piece of bonding film got things sorted. I highly recommend their products.
    Anyway, after replacing those (3) 2SC1222 transistors, the speed has now been stable! :) I guess it figures that after replacing 23 other components before this, it was these last 3 that actually fixed the problem (hopefully!).
    Who knows which particular component, or combination thereof, actually fixed the issue, but obviously I'm glad it is now working properly, and holding steady speed. I did a lot of research on the web trying to figure this out, but it seems there is no clear-cut, consistent solution for speed issues with this generation of Denon DD turntables. What solves the issue with one unit will not necessarily solve it for another unit, so it becomes somewhat of a shotgun approach.
    Funny story: in my frustration and haste, before resolution, I placed a bid on eBay for a DP-2000 (with quartz-controlled speed), and wouldn't ya know it...I won. I've been practicing this as my speech to my wife. What do you think?
  • jbreezy5
    Love those Denon ‘tables.
  • jdjohn
    jdjohn Posts: 3,445
    Thanks, and good-eye on the plinth. It's a Denon DK-110 plinth, which was their 'big-body' plinth - able to accommodate longer tonearms. In that generation of Denon decks, there was the option to mix-and-match direct-drive motor units with their plinths/bases.
    In this setup, I installed a Micro Seiki MA-505L arm, which is basically a 12" arm.
  • stangman67
    stangman67 Posts: 2,334
    Picked up this MOFI pressing of “Brother in Arms”. Enjoying it on this Friday morning as my leave dwindles down
  • stangman67
    Norfolk, headed to United States Fleet Forces Command. Just transitioned off my department head rides (Surface Warfare Officer)
    Thank you for your service.
  • dromunds
    dromunds Posts: 10,174
    Just listened to the 45 RPM mofi pressing of BIA. All of Knopfler’s recordings are so well done.
  • stangman67
    Yes they are. Really peak analog recordings. My (new) MOFI pressing has more surface noise than I would expect but once the music starts, it is bliss
    The MOFI one-step drama was annoying for sure but I appreciate the effort they put into place to create quality pressings. I am patiently awaiting the one steps for Hotel California and James Taylor’s greatest hits to be released. I’ve had them on pre order for about a year now
  • stangman67
    treitz3 wrote: »
    Appreciate the recognition Tom, not necessary at all but appreciate it regardless!
  • Reagan
    Reagan Posts: 116
    I wish they would just do the MOFI in 33-1/3.
    Speakers: Polk 1.2TL w/VR3 mods and Dreadnaught interconnects
    Amplification: ARC Reference 110 w/KT150s; Cary Audio SLP-05 w/Ultimate Upgrade
    Vinyl: VPI HW19 MK III (Heavily Modded); Origin Live Silver Tonearm; Hana ML Cart; Pete Riggle VTAF; VPI TNT Platter; SAMA; Iphono3
    Digital: Aurender N100H; Benchmark DAC1
  • zarrdoss
    zarrdoss Posts: 2,562
    zarrdoss wrote: »
    I tried out a set of Martin Logan's and am asking myself
    erniejade wrote: »
    zarrdoss wrote: »
    I tried out a set of Martin Logan's and am asking myself why I did not try them sooner?
    Just skip over them and go straight to Magnepan.
    I could be off but, with the Logan, you don't have to worry about integrating a subwoofer since the Logans have a woofer built in.
    I know both can be a bit difficult on setup and very sensitive to room acoustics and placement.
    I have heard both Logans and Maggie's sound amazing and horrible, depending on the room and placement.
    They both sound better with a sub IMO. Not really bad for set up either. I tried some Magnepans again MG .7. They are in way better condition than the other ones I tried and sound much better. I have the Martin Logans on HT duty paired with a Stage center and two SVS SB3000. The Magnepans are on 2.1 channel duty with a Paradigm studio sub 12. As for which one sounds better.... really close but the jury is still out. Pretty sure I am done with conventional speakers for a while though.
  • GlennDog
    GlennDog Posts: 3,158
    the remote control for my preamp never worked well . . . Well, I disassembled and cleaned the pcb contacts with isopropyl alcohol
    Works GREAT!
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • jbreezy5
    Might try that on my Arcam remote!
  • GlennDog
    jbreezy5 wrote: »
    the tech at Cary said use the tip of a pencil eraser.... didn’t do squat.
    Go with isopropyl and a Q-tip
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • jbreezy5
    Got some tube socket savers from Valves N More…
    Purchased 9-pin (8) and Octal (4). They seem to be of high quality and the Octal types had surprising heft.
    mhardy6647 Posts: 35,562
    edit: whoops! :#
  • skipshot12
    skipshot12 Posts: 2,159
    Arriving Tuesday is my Phase Linear preamp purchased in 1979.
    Company in Oregon repairs these along with offering upgrades. They’ve installed a remote control operation for the whiff along with upgrades 👍
    Have been playing the Oppo directly into the amp, this is gonna be awesome!
    audioluvr Posts: 6,079
    skipshot12 wrote: »
    Company in Oregon repairs these along with offering upgrades...
    Who might that be?
    I'm guessing Rolland. He might have moved his shop. He used to be in WA.
  • stangman67
    Website still lists in Washington but there are third party sites that do say Oregon.
    Hitech Audio
  • skipshot12
    stangman67 wrote: »
    Hitech Audio
    Yes, it is Rolland @ Carver Audio Repair.
    Absolutely top notch experience.
    So, which is it? His original shop in WA or did he move to Oregon?
    He lives in Stevenson WA. Not Oregon.
