1156157159161162201
    Clipdat Posts: 13,098
    Meh. I prefer my DACs to have at least 16 tubes. Minimum.
    treitz3 Posts: 20,037
    It's also balanced. No can use.
    VR3 Posts: 29,476
    It has rca outputs as well as rca analog inputs as part of the preamp section!
    Ah, maybe I should have kept reading the description....DOH!
  • GlennDog
    GlennDog Posts: 3,152
    Still running my new baby in . . .
    Seller pic
    My buyer pic
    Electronics are settling in . . . I’ll update later
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    audioluvr Posts: 5,967
    I like the cool blue light bulbs on top!
    VR3 Posts: 29,476
    Need internal pics!
  • newbie308
    newbie308 Posts: 805
    Found a Holman preamp at a local pawn shop today. They aren't much for looks, but from what I understand, the value is in the circuit design. I'm looking forward to comparing it to the Threshold SL-10.
  • GlennDog
    edited January 2023
    VR3 wrote: »
    Need internal pics!
    Not the Baltic, but the Amber 3 with upgraded/XLR c. 2021
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • GlennDog
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    Obligatory "You need to roll some vintage Mullards in there!" comment.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Dang GlennDog, she's a beauty B) Congratulations!!!
  • bcwsrt
    bcwsrt Posts: 2,440
    Got into some minutia leveling and double-checking all the geometry on the new turntable with some 3/4" ball bearings and a Hudson Hi-Fi kit I got today. I had re-aligned the cartridge a couple days ago because I didn't like how far forward in the head shell it was from the dealer (pics for comparison on the prior page). Evidently, he performed a Baerwald alignment with much more overhang than the 52mm specified by Technics. Not necessarily wrong, just different. After using the supplied Technics overhang gauge, accuracy was verified with a Technics-spec protractor I printed off and both null points were perfect.
    With the Hudson Hi-Fi kit, I checked azimuth, which was spot-on, vertical tracking angle and vertical tracking force, which was also spot-on the 1.6 grams specified by Ortofon. On the vertical tracking angle, it is a bit tough to get just the right view of the gauge with the s-shaped tonearm, but I ended up backing it off to below "0" (negative) on the adjustment ring to level it out despite the Technics manual calling for a setting of "1" for the cartridge height of the 2M Black LVB 250. This was basically the only thing I found "off" with the original setup. I may raise it back up and do some more critical listening at some point to see if I notice any differences.
    Does it sound better now? There may have been a slightly less harsh and bright sound after changing the cartridge alignment and overhang from how it was given to me. Other than that, no, it still sounds amazing! Of course, it is all still burning-in, so that could have something to do with any perceived changes, too. But, at least my OCD feels better knowing everything is dialed in the way I want it! At least until I purchase a test record! 🙄😝
    Turntables are cool!
    Brian
    Gorgeous table.
    VR3 Posts: 29,476
    Sure seems like alot of steps to listen to music 😝
    Said in jest in regards to another post
    Beautiful setup! I'm sure sounds fantastic!
  • bcwsrt
    bcwsrt Posts: 2,440
    TY! It was a lot of dorking around to say the least! Should be good at least every other tube bias check from now on, though! Lol
    Brian
  • My 2Bs are now 2BTLs. Before and after pics below. It’s not the prettiest solder job in the world but it’s solid and sounds pretty amazing so far. Only about 20hrs into burn in so far.
    VR3 wrote: »
    LOL
    VR3 Posts: 29,476
    You sir have a nice rack!
  • jdjohn
    jdjohn Posts: 3,370
    I love the attention to detail in this turntable setup. Is it justified? You only know when you know.
  • bcwsrt
    bcwsrt Posts: 2,440
    VR3 wrote: »
    Too funny! I knew I had seen your reference somewhere but just found that thread again and read through it now that my own over-complications are done with! 😂
    Brian
    VR3 wrote: »
    Perv!
    SCompRacer Posts: 9,117
    edited January 2023
    bcwsrt wrote: »
    High marks, nice work!
    You haven't arrived at the peak of TT OCD until you have the best VTA settings listed on your albums like Joe (hearingimpared, RIP) did. :D
  • bcwsrt
    bcwsrt Posts: 2,440
    edited January 2023
    I certainly admire that level of commitment, even if I don’t aspire to it! 😝
    I did find notes on some of my LP sleeves showing what EQ adjustments I prescribed for that particular album back in the day. That was when I had an EQ and much lower standard equipment. Now, the only tone controls I have beside the VTA wheel on the turntable are a few 12au7 tubes for my amp, yet everything sounds better than ever!
    Brian
  • jdjohn
    jdjohn Posts: 3,370
    The 8m length will go from router to switch, and the 0.5m from switch to ENO filter.
  • Reagan
    Reagan Posts: 116
    I have not compared LEEDH to a passive preamp attenuator but will have the opportunity in a few weeks when my stepped attenuator comes from Khozmo.
    Speakers: Polk 1.2TL w/VR3 mods and Dreadnaught interconnects
    Amplification: ARC Reference 110 w/KT150s; Cary Audio SLP-05 w/Ultimate Upgrade
    Vinyl: VPI HW19 MK III (Heavily Modded); Origin Live Silver Tonearm; Hana ML Cart; Pete Riggle VTAF; VPI TNT Platter; SAMA; Iphono3
    Digital: Aurender N100H; Benchmark DAC1
    VR3 Posts: 29,476
    We did compare leedh to the cary slp though 💥
  • Reagan
    Reagan Posts: 116
    True. But unfortunately, the signal was going through LEEDH AND the Cary volume controls.
    VR3 Posts: 29,476
    Nah we bypassed it completely remember
