1…152153155157158…208
    Clipdat Posts: 13,104
    Yeah, I heard that too.
    VR3 Posts: 29,741
    I don't leave tube gear on so I may never hear its potential
  • invalid
    invalid Posts: 1,559
    You don't leave any gear on or just tube gear?
    VR3 Posts: 29,741
    I don't leave any gear on in the main rig other than the lumin.
    This is for multiple reasons but ultimately I don't run a preamp and in order to turn the tube dac off, I have to turn off the amplifier to prevent a pop so I leave the amp and dac off except when listening
    VR3 Posts: 29,741
    Fwiw, lampizator manual says if the dac is burned in.. After 20 minutes it is ready to rumbld
    mhardy6647 Posts: 35,561
    I thought we went to digital to get away from rumble...
    B)
  • skipshot12
    skipshot12 Posts: 2,155
    Llllleeeet’s get ready to…… oh
  • GlennDog
    GlennDog Posts: 3,158
    Not familiar with Level 5, but the current models are easy on tubes. Mine is on 24/7 along with the LUMIN U1 Mini
    FWIW, Level 5 can be upgraded to Baltic. I’m assuming it’s Not Delta Sig
    That separate PS musta been a one-off. I didn’t know Lukasz offered that option
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    VR3 Posts: 29,741
    I sent them an email, no response yet.
    Based on my research, the level 5 of this era was a level 4 with a separate power supply and more part upgrades. 6k msrp or so
  • GlennDog
    I just noticed that Lampi is offering a New Enigine (chip set) . . . NOT Level eLeven but 18
    That’s like within 6 months they went from engine 53 >> to eLeven >>> now 18
    Gotta get my learn on
    Example
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • GlennDog
    btw . . . I’m lov’n the OLED
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    VR3 Posts: 29,741
    The lampizator sounds very good. It is interesting how different the ank and lampizator is, very different sound signature sbut both extremely good dacs
  • GlennDog
    edited January 2023
    VR3 wrote: »
    You reached out to Fred/Rob North American distributor reps Or HQ?
    HQ is slooow, generally fred and rob are quick-ish
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    VR3 Posts: 29,741
    I believe it was HQ, I can try the americas as well.
  • GlennDog
    VR3 wrote: »
    Didjya ever get your ears on Skips highly touted North Star Design Supremo?
    Very very good DAC
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • GlennDog
    I’m sure there are others out there, but I have not seen one like it . . .
    WISH I HAD VOL CONTROL (pre amp functionality)
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    VR3 Posts: 29,741
    Have not heard the north star gear but have heard good things.
    I set the volume on the lampizator and then used the lumin u1 leedh processing volume, which is easily the best preamp you could ever have!
    The lampi volume does seem competent however 😎
  • GlennDog
    edited January 2023
    How exactly do you use the Leedh vol feature?
    I thought the preamp had to have a “unity gain of one” or some such thing
    Any info would be greatly appreciated . . . TIA Trey
    One thing that LUMIN seems to lack in their lit is this topic
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • jdjohn
    jdjohn Posts: 3,442
    This is a 'lazy' question, but: which of these are 'RTR ladder' DACs?
    VR3 Posts: 29,741
    In the lumin settings you disable volume and enable leedh. I recommend adjusting the max volume so you don't blow anything up.
    Been preamp free for a long time with no regrets. @Reagan has a Cary SLP05 and we bypassed it with leedh and there was a clear advantage towards leedh..
    The lampi doesn't have unity but I adjusted it to match the ank volume at the same volume on leedh which seems to work fine.
    From what I can tell the lampi appears to be a delta sigma and sounds like it while the ank is a R2r
  • GlennDog
    jdjohn wrote: »
    “ I think” the Level 5 is R2R and my A3 is Delta Sig
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • GlennDog
    VR3 wrote: »
    I’ll look into this . . . Thanks Trey
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    VR3 Posts: 29,741
    Hard to know, this dac looks to be more of the early days before they had their own boards and chip sets. The boards are labeled with EXD audio which is a Chinese audio company and then everything is souped up around it which appears to be standard for the early lampi stuff.at some point they started doing everything in house branded
  • GlennDog
    I think initially Lukasz preferred R2R . . . then jumped the fence
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    VR3 Posts: 29,741
    I'll update once I have more info. So far I have had fun with it
  • jdjohn
    jdjohn Posts: 3,442
    edited January 2023
    Out with the 'old' make-shift XLR-to-RCA cable assembly:
    And in with my new DIY custom job:
    DH Lab Silver Sonic XLR plugs, Supra PPSL locking RCA plugs, and Supra EFF-I analog IC cable
    FYI EDIT: this is to connect my Benchmark HPA4 preamp to my Butler TBD 2250 power amp.
  • jbreezy5
    jbreezy5 Posts: 1,141
    Very nice work @jdjohn.
    VR3 Posts: 29,741
    Very nice!
