1152153155157158203
    nooshinjohn Posts: 25,998
    VR3 wrote: »
    5.1 pro
    If it has USB, I would love to get my ears on it...
    VR3 Posts: 29,549
    The ank and lampizator both have usb, for sure
    I would note however the ank uses a cheap 25 dollar usb to spidf card to convert that signal to apidf so using a 1.5 bnc cable is the best route for connection
    treitz3 Posts: 20,116
    That can be upgraded though, no?
    VR3 Posts: 29,549
    edited January 2023
    Ank recommends if you want to use USB to buy an external USB to spidf converterIMO and in my research, your transport should already have a good USB to spidf converter if it has spidf out...
    Again, alot of redundancy there.
    If both pieces of gear has spidf connections, just use the spidf connection.
    I requested they throw the USB board in there just so it had USB, easier for future resale
    audioluvr Posts: 5,987
    In with 46 on the one you don't keep!
    Clipdat Posts: 13,100
    It's "spdif" ffs, not "spidf"
    VR3 Posts: 29,549
    So my first impression is the lampizator has better detail retrieval but the ank is more musically engaging... But I've only spent about thirty minutes with the lampizator.
    Will keep hooked up for a few weeks and then install the ank back in
    What is the tubes used in the Lamp?
    VR3 wrote: »
    I heard that the Lampi gear likes to be left on. You might not hear what it is truly capable of for a couple days.
    Yeah, I heard that too.
    VR3 Posts: 29,549
    I don't leave tube gear on so I may never hear its potential
  • invalid
    invalid Posts: 1,525
    You don't leave any gear on or just tube gear?
    VR3 Posts: 29,549
    I don't leave any gear on in the main rig other than the lumin.
    This is for multiple reasons but ultimately I don't run a preamp and in order to turn the tube dac off, I have to turn off the amplifier to prevent a pop so I leave the amp and dac off except when listening
    At least leave the Lampi on overnight tonight...
    pitdogg2 Posts: 27,307
    Clipdat wrote: »
    Yep
    Sony philips digital interface
    I think that is correct....
    VR3 Posts: 29,549
    Fwiw, lampizator manual says if the dac is burned in.. After 20 minutes it is ready to rumbld
    mhardy6647 Posts: 35,229
    I thought we went to digital to get away from rumble...
    B)
  • skipshot12
    skipshot12 Posts: 2,092
    Llllleeeet’s get ready to…… oh
  • GlennDog
    GlennDog Posts: 3,158
    Not familiar with Level 5, but the current models are easy on tubes. Mine is on 24/7 along with the LUMIN U1 Mini
    FWIW, Level 5 can be upgraded to Baltic. I’m assuming it’s Not Delta Sig
    That separate PS musta been a one-off. I didn’t know Lukasz offered that option
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    VR3 Posts: 29,549
    I sent them an email, no response yet.
    Based on my research, the level 5 of this era was a level 4 with a separate power supply and more part upgrades. 6k msrp or so
  • GlennDog
    I just noticed that Lampi is offering a New Enigine (chip set) . . . NOT Level eLeven but 18
    That’s like within 6 months they went from engine 53 >> to eLeven >>> now 18
    Gotta get my learn on
    Example
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • GlennDog
    btw . . . I’m lov’n the OLED
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    VR3 Posts: 29,549
    The lampizator sounds very good. It is interesting how different the ank and lampizator is, very different sound signature sbut both extremely good dacs
  • GlennDog
    edited January 2023
    VR3 wrote: »
    You reached out to Fred/Rob North American distributor reps Or HQ?
    HQ is slooow, generally fred and rob are quick-ish
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    VR3 Posts: 29,549
    I believe it was HQ, I can try the americas as well.
  • GlennDog
    VR3 wrote: »
    Didjya ever get your ears on Skips highly touted North Star Design Supremo?
    Very very good DAC
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • GlennDog
    I’m sure there are others out there, but I have not seen one like it . . .
    WISH I HAD VOL CONTROL (pre amp functionality)
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    VR3 Posts: 29,549
    Have not heard the north star gear but have heard good things.
    I set the volume on the lampizator and then used the lumin u1 leedh processing volume, which is easily the best preamp you could ever have!
    The lampi volume does seem competent however 😎
  • GlennDog
    edited January 2023
    How exactly do you use the Leedh vol feature?
    I thought the preamp had to have a “unity gain of one” or some such thing
    Any info would be greatly appreciated . . . TIA Trey
    One thing that LUMIN seems to lack in their lit is this topic
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • jdjohn
    jdjohn Posts: 3,382
    This is a 'lazy' question, but: which of these are 'RTR ladder' DACs?
