Documenting: My SDA-1c upgrades from start to finish
145791031
    audioluvr Posts: 5,861
    lightman1 wrote: »
    Best mod ever
    Is that the OCC version?
    Toolfan66 Posts: 17,978
    Escalating?? A few people sharing their point of view is Escalating??
  • @Toolfan66
    Meaning the number of participants and the number of comments since my ringing basket update. And a reference to the arousal bits.
    Given how escalate is used in meme-dom, I can see the confusion. I should've used a different intro.
    I'd change it to 'All this was a lot to catch up on!' or 'So many comments to go back and make sure I keep track of!' or 'Hit the brakes, I need to collect my thoughts!' or 'O.k., let's take stock of what I have here, because, going back through and reading, some people think I'm an idiot, or cheap, or disrespectful because I'm trying something non-standard or off-the-wall (or even just tossing ideas out to see what people think).'... or something, to avoid confusion.
    I did say I wrote that long-**** thing when I woke up... and the thoughts cross 3 or 4 different threads.
    I certainly wasn't complaining about anything you said! You're helpful!
    The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
    Ah, yep I took it the wrong way. Sorry..
  • No problem!
    My essays are prone to errors/typos/things I wish I could fix.
    More words = more chances for [insert unintended consequence here]
  • Now.
    Printing a terminal plate and putting a few things up for sale to fund coils =)
  • Figured I'd date and sign the terminal plates.
    Basic.
    No frills.
    Pink.
    Silly.
  • invalid
    invalid Posts: 1,439
    Looking good, now for the binding post upgrade
  • invalid wrote: »
    ...now for the binding post upgrade
    I know, right?
    I thought I had upgraded posts in the pile o' parts, but I didn't =(
    Will order soon.
    Vampires are seemingly the posts of choice here, but do you have a recommendation?
  • skipshot12
    skipshot12 Posts: 1,772
    edited October 2022
    I’ll second pit’s Cardas’ recommend. On the spendy side but excellent.
    I have experience with the CCBP posts.
    Upgraded the speaker posts in my Legacy-Audio monobloc amps. They work great.
    Since I had a little accident in shorting out my binding posts, beer induced, I now go with insulated pieces.
    WBT are also very nice. Also spendy.
    Only two I’ve used.
    So I cannot recommend others…
  • Gardenstater
    Gardenstater Posts: 4,721
    @plastic_avatar 8 phase plug shims are off and away towards you, now in the clutches of the US postal service :)
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • invalid
    I used these from meniscus audio for about $13 a pair.
  • Ooof. I'm almost ready to take the posts off my homebrews (nothing special, but better than stock)... might go with @invalid's choice to begin, and when I finish upgrading my 5B, I can swap these to those and buy a fancier pair (and print a better quality terminal plate... first go, not bad).
    I'm really thinking I wish I had different boards. The stock soldering is awful. And they'll be crowded when I get to soldering =( I was thinking about diy'ing it, but @VR3's stuff is so incredible, it seems like an insult to try [laughs]. But if I want to get the new coils... the stock board is an even bigger p-i-t-a for me...
    And the oldest has Rona again (we all had it in January). So I'll have time here to design... maybe.
    F1nut Posts: 51,663
    Positive terminal on all but one vintage Polk speaker model goes on the left.
  • terminal swap = just had them in to check my print (paid no attention to the color, all is good)
    Found the Vitamin A. Went ahead and doped.
    The 2 bottom domes were thirsty. Lucky I guess, that the tops and bottoms were different in how tight the weave/fabric is. That way, they're matched in weight of oil. whether that really matters to the ear, though...
    Sure makes them shiny.
  • plastic_avatar
    plastic_avatar Posts: 727
    edited October 2022
    Less shiny today.
    Had to sop up some oil from around the base of the domes.
    Permeating the weave nicely.
    Stock, the fabric had a crinkly quality. Not like the 2000 dome, but on the same quality of deformation feel/sound shelf- when handling and poking around. Not nearly as sharp, but nit supple like the newer domes. I hope the doping smooths out that characteristic, without killing the sparkle.
    I'll put a doped Wuhan in the 5B to compare.
    Doped Wuhan:
    198 (omg, sooooo dusty):
    The 198 looks like the outer ring of fabric was doped.
    I didn't do that on the Wuhans... should I? I didn't because I worried about loosening the glue holding the dome to its plate...
    xschop Posts: 5,046
    I don't think the outer rings matter much, but may help in faster break-in?
    The important thing is to not have any excess oil in the circular pleats.
    Looks good
    pitdogg2 Posts: 26,919
    edited October 2022
    What is the 411 on this Vitiman A oil ? What does it do and why will it not turn rancid ?
    What is the benefit on the diaphram I guess.
    F1nut Posts: 51,663
    edited October 2022
    It appears there are 3 different oils used in the liquid form of vitamin A depending on the manufacturer. Either cod oil, olive oil or coconut oil.
    Cod, olive and coconut oil will turn rancid and olive oil will become a gummy mess. I'm not sure if the other two will.
    NONE of those oils has any business on a fabric tweeter dome.
  • Gardenstater
    That one he used has soybean oil, gelatin, glycerin, purified water, and 3,000 mcg Retinyl Palmitate per capsule. Vitamin A is an antioxidant which would tend to keep the soybean oil from oxidizing (becoming rancid).
    I have no idea what manufacturers use for doping their tweeter domes and I suspect it is a highly guarded proprietary secret in each case.
    Here's a thread where it is discussed:
    https://www.diyaudio.com/community/threads/soft-dome-tweeter-coatings.79999/
    Two interesting mentions were (up to page 2):
    Oppanol (polyisobutylene) and Silicone (1 part Permatex 81730 Windshield and Glass Sealant thinned with 3 parts hexane)
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 51,663
    Vitamin A, however, is sensitive to oxidation caused by light and metal in the presence of oxygen
    xschop Posts: 5,046
    The oil suspension won't allow oxygen contact with the retinoic acid, the reason for its encapsulation in oil.
    The doped wuhans will sound very similar to 194's.
  • Gardenstater
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • invalid
    Doesn't this procedure add mass to the tweeter?
  • It's an affordable experiment.
    If these go South, I'll have money to replace them with either more Wuhan domes, or upgrade to a different dome, or get the 194.
    As it is right now, everything is fine =)
    I'll try them out in the 5B soon.
    I never thought I'd be messing with as much as I have. It's fun =)
    Went ahead and doped my one working 5B. It's all in the name of science!
  • Gardenstater
    Do you think you could blot the excess off with something non lint forming like maybe lens tissue that is used to clean camera and binocular lenses? Seems like a lot there :#
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,046
    Just use a dry Q-tip to soak up the excess.
  • Gardenstater
    OK but not my DollarTwentyFiveTree Qtips. Very shedding of fibres prone they are :)
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
