Post a picture... any picture
1697698700702703739
    mhardy6647 Posts: 29,774
    edited April 19
    OleBoot wrote: »
    ^^^ I am rollin' on the floor here. B)
    Using that famous early stealth technology, plywood. :)
  • OleBoot
    OleBoot Posts: 1,148
    AND Balsa wood, like I made model airplanes with in my early years.
    audioluvr Posts: 4,201
    Clipdat wrote: »
    Oak logs and granite slabs. Good choice.
    Cambridge Audio 851N Streamer/DAC
    Belles 350A Reference modded with Mundorf Supreme caps
    There is about a 5% genetic difference between apes and men …but that difference is the difference between throwing your own poo when you are annoyed …and Einstein, Shakespeare and Miss January.
    by Dr. Sardonicus
  • maxward
    maxward Posts: 1,153
    Which came first, the rack or the Classe components?
    pitdogg2 Posts: 20,822
    That is glorious Ken !!!
    That old wool carpet wears like iron! Smells like a wet dog if you steam clean it though.
    by Dr. Sardonicus
  • maxward
    Or if you live in a humid climate.
  • Willow
    Willow Posts: 10,560
    maxward wrote: »
    Or if Russ was over
    TV room- B&W 703, SVS PB10 NSD, Marantz NR1607, Parasound 1500a, Pro-Ject Debut Carbon (Yellow) with Acrylic platter, Pro-Ject phono pre, MIT AVT 2 speaker cables, MIT AVT 1 and AVT 2 ICs, XLO Jumpers, Signal Dig Coax, Signal Cable Magic Power Cables x3, Samsung QN75Q7DR Qled 75" tv, Harmony 1100, Sony BDP-S6200, Marantz DV-4200 (as Transport), Cambridge Audio DAC Magic100, Monster 3600MKII, PS4, Nintendo Switch and Xbox 360 Family room Samsung 55JS7000 Android Mi Box3 and Apple TV, Polk Magnifi Max. - Pool /Gazebo Yamaha RX-A1010, Polk Patio 25x4, Rotel RDV 1045 (as CDP) MIT AVT3 ICs - Work - Spotify Premium, Neutron App or Amazon Music to my FiiO Kunlun into my Grado SR125e
  • lightman1
    lightman1 Posts: 10,707
    edited April 21
    ^^^^ aiyeeeeee... :#
    meanwhile, in sleepier backwaters of teh webz...
    I wonder if this is what Schroedinger was thinkin' about in his Gedankenexperiment?
    B)
    lightman1 wrote: »
    Willow wrote: »
    maxward wrote: »
    Or if Russ was over
    I see you are already in wedding shape .... You clean up fabulous
  • Willow
    lightman1 wrote: »
    Willow wrote: »
    maxward wrote: »
    Or if Russ was over
    As handsome as ever
    txcoastal1 Posts: 12,202
    Cute
    Yellow-bellied sapsucker
    1 wrong step would make home a bird brain
  • BlueBirdMusic
    BlueBirdMusic Registered User Posts: 1,750
    CA-W8 Tractrix Horns
    If you are going to do something STUPID, do it FAST so it doesn't affect someone else.
    tonyb Posts: 32,618
    Does that say "Red Hat Russ" on the top of that ? Red a$$ Russ would have ben more appropriate. :)
    [/quote]
    As handsome as ever [/quote]
