Post a picture... any picture
(ASR)
An obsessive compulsive perfectionist father would have rolled the clamps so those razer sharp ends weren't anywhere your hands or face. Just saying.Gustard X26 Pro DAC
^^^ I am rollin' on the floor here.
Using that famous early stealth technology, plywood.
AND Balsa wood, like I made model airplanes with in my early years. -
Which came first, the rack or the Classe components?
We have a Blue Bird couple making babies in the front bird house.
We usually get a couple every year in the front box or the Box on the left front corner of the side porch. You can see it too in the picture below. It's just 10' from the front one. I don't think 2 Blue Bird couples would nest that close to one another. They are SUPER protective of their surrounding area.
Once they make their nest in the box, you RARELY see them.
I'll try to get a picture or two of them soon.
That is glorious Ken !!!
That old wool carpet wears like iron! Smells like a wet dog if you steam clean it though.Gustard X26 Pro DAC
Or if you live in a humid climate.
^^^^ aiyeeeeee...
meanwhile, in sleepier backwaters of teh webz...
I wonder if this is what Schroedinger was thinkin' about in his Gedankenexperiment?
Cute2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
1 wrong step would make home a bird brain2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
― Aleksandr Solzhenitsyn -
CA-W8 Tractrix Horns"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Does that say "Red Hat Russ" on the top of that ? Red a$$ Russ would have ben more appropriate.
[/quote]
As handsome as ever [/quote]
lsi 9's -
Perfect!
