Post a picture... any picture
1…694695697699700…1153
    Clipdat Posts: 13,104
  • OleBoot
    OleBoot Posts: 3,138
    ^^^ I am rollin' on the floor here. B)
    Using that famous early stealth technology, plywood. :)
    AND Balsa wood, like I made model airplanes with in my early years.
    audioluvr Posts: 6,065
    Clipdat wrote: »
    Oak logs and granite slabs. Good choice.
  • maxward
    maxward Posts: 1,742
    Which came first, the rack or the Classe components?
    Tony M Posts: 12,000
    We have a Blue Bird couple making babies in the front bird house. :)
    We usually get a couple every year in the front box or the Box on the left front corner of the side porch. You can see it too in the picture below. It's just 10' from the front one. I don't think 2 Blue Bird couples would nest that close to one another. They are SUPER protective of their surrounding area.
    Once they make their nest in the box, you RARELY see them.
    I'll try to get a picture or two of them soon.
    treitz3 Posts: 20,352
    pitdogg2 Posts: 27,881
    That is glorious Ken !!!
    That old wool carpet wears like iron! Smells like a wet dog if you steam clean it though.
  • maxward
    Or if you live in a humid climate.
  • Willow
    Willow Posts: 11,360
    maxward wrote: »
    Or if Russ was over
  • lightman1
    lightman1 Posts: 10,801
    edited April 2022
  • lightman1
    Willow wrote: »
    maxward wrote: »
    Or if Russ was over
    mhardy6647 Posts: 35,553
    ^^^^ aiyeeeeee... :#
    meanwhile, in sleepier backwaters of teh webz...
    I wonder if this is what Schroedinger was thinkin' about in his Gedankenexperiment?
    B)
    lightman1 wrote: »
    Willow wrote: »
    maxward wrote: »
    Or if Russ was over
    I see you are already in wedding shape .... You clean up fabulous
  • Willow
    lightman1 wrote: »
    Willow wrote: »
    maxward wrote: »
    Or if Russ was over
    As handsome as ever
  • OleBoot
    edited April 2022
    txcoastal1 Posts: 13,520
    Cute
    Yellow-bellied sapsucker
    1 wrong step would make home a bird brain
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,097
    CA-W8 Tractrix Horns
    Harry / Marietta GA
    Does that say "Red Hat Russ" on the top of that ? Red a$$ Russ would have ben more appropriate. :)
    [/quote]
    As handsome as ever [/quote]
  • daddyjt
    daddyjt Posts: 3,246
    edited April 2022
    ― Aleksandr Solzhenitsyn
  • maxward
    Perfect!
    SCompRacer Posts: 9,383
    Who needs Batman.... we got lightman.
