Post a picture... any picture
1…691692694696697…1107
    audioluvr Posts: 6,079
    (ASR)
    An obsessive compulsive perfectionist father would have rolled the clamps so those razer sharp ends weren't anywhere your hands or face. Just saying.
    mhardy6647 Posts: 35,562
    edited April 2022
    OleBoot wrote: »
    ^^^ I am rollin' on the floor here. B)
    Using that famous early stealth technology, plywood. :)
    Clipdat Posts: 13,105
  • OleBoot
    OleBoot Posts: 3,138
    AND Balsa wood, like I made model airplanes with in my early years.
    Clipdat wrote: »
    Oak logs and granite slabs. Good choice.
  • maxward
    maxward Posts: 1,743
    Which came first, the rack or the Classe components?
    Tony M Posts: 12,025
    We have a Blue Bird couple making babies in the front bird house. :)
    We usually get a couple every year in the front box or the Box on the left front corner of the side porch. You can see it too in the picture below. It's just 10' from the front one. I don't think 2 Blue Bird couples would nest that close to one another. They are SUPER protective of their surrounding area.
    Once they make their nest in the box, you RARELY see them.
    I'll try to get a picture or two of them soon.
    treitz3 Posts: 20,365
    That old wool carpet wears like iron! Smells like a wet dog if you steam clean it though.
  • maxward
    Or if you live in a humid climate.
  • Willow
    Willow Posts: 11,367
    maxward wrote: »
    Or if Russ was over
  • lightman1
    lightman1 Posts: 10,803
    edited April 2022
  • lightman1
    Willow wrote: »
    maxward wrote: »
    Or if Russ was over
    ^^^^ aiyeeeeee... :#
    meanwhile, in sleepier backwaters of teh webz...
    I wonder if this is what Schroedinger was thinkin' about in his Gedankenexperiment?
    B)
  • Willow
    lightman1 wrote: »
    Willow wrote: »
    maxward wrote: »
    Or if Russ was over
    As handsome as ever
  • OleBoot
    edited April 2022
    txcoastal1 Posts: 13,520
    Cute
    Yellow-bellied sapsucker
    1 wrong step would make home a bird brain
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,137
    CA-W8 Tractrix Horns
    Harry / Marietta GA
    Does that say "Red Hat Russ" on the top of that ? Red a$$ Russ would have ben more appropriate. :)
    [/quote]
    As handsome as ever [/quote]
  • daddyjt
    daddyjt Posts: 3,265
    edited April 2022
    ― Aleksandr Solzhenitsyn
  • maxward
    Perfect!
