Added the black anodized aluminum trim to my XPA-2. The original owner preferred the silver, removed the black and lost them before he sold it to me. The black seems to classy it up a bit.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout. -
The CX-a5200 is a pre/pro. The problem I have had with Yamaha is their amplification, as it is very dry and sterile sounding. Given that I will be using my tube amps and a different brand of 7 channel amp for the rest, I am thinking it might work.Don't get the Yamaha. Your ears will thank you and you would just be wasting your time/money. I know they market, "Natural Sound" but they are nowhere close to it.....and IME? Completely underwhelming.
Thanks for that input. While I am looking into other options, I am still going to give the Arcam AVR20 a fair shot in my rig. The AVR30 was stellar until it went belly up. I am hopeful the replacement will be up to par as far as reliability goes...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
JBL Synthesis?
After not having sound for 6 weeks... About to plug this bad boy in
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Time to break it in with some baby shark!
The bass in baby shark is legit- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Wow those are cool door bell transformers !! Do the mundorf caps really bring out the DING or DONG?
They definitely can bring the ding and the dong haha
Looking forward to it, I loved the one below this one!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Good grief. Leave it to the boys on the Polk Forum to start talking about ding dongs....
I think I'll slide out now for a stint.
I prefer Ho Ho's...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
What is it Trey, tubed pre?
ANK R2R DAC 5.1 Pro with quad c coils- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
nooshinjohn wrote: »Thanks for that input. While I am looking into other options, I am still going to give the Arcam AVR20 a fair shot in my rig. The AVR30 was stellar until it went belly up. I am hopeful the replacement will be up to par as far as reliability goes...
When using preouts on my Yamaha receivers, yes, that helps the sound tremendously. However, had to remove my B&K 125.7 for repair, and the Yamaha amp, sux!
What the Yamaha gets really right as a pre/pro is ease of use, and large, easy-to-read display. Not familiar with the model you mentioned, though. FWIW, I have RX-V775 and 777.
Good luck with your Arcam replacement.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
The Yamaha CX-a5200 is their top of the line pre/pro. There is no internal amplification.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Hey John.
I started my HT journey with Yamaha. I have now had 2 different Marantz pre/pros since and would highly recommend the 8805A over the CX-A5200.
In fact, the 8805A is what I currently have running in my theater and it does an amazingly good job with anything I throw at it acoustically. I would even go so far as preferring it when specifically listening to 5.1 mixes of stuff vs listening to the same mixes downmixed to 2.1 in my 2 channel system.
In the end, obviously, your ears are your ears. But coming from someone who used to be a pretty heavy Yamaha fan-boy, go Marantz. You won't regret it.
Hearing this system in person, I agree 10000%Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
John, I am seeing a pattern here.....are you listening? Amp, no amp aside....empirical evidence/experience speaks volumes and continues building.
I used to run Yamaha as well (pre-pro, amp and integrated), FWIW, so I also speak from experience with a couple of different rigs/configurations. Anyhoo, this is the last I will mention it. It's your choice.
I am taking it all in Tom. The AVR20 needs to get here first. I am liking to sound I get from it and based on everything I have seen so far, the Yammy is going to be a polar opposite. NAD has a pre/pro in their lineup I am looking into now. The M17-V2i...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Remounted an AT-OC9XLS today that's got about 100 hours on it and she's singing beautifully
It's a very good Cartridge for the price of admission, ultra smooth and rich, yet excellent detail. I'm tempted to move up the line a little bit
Audio Technica is, IMO, the Rodney Dangerfield of the cartridge world.....I've put a few on inexpensive turntables and got nothing but good things to say.....I plan for the future. - F1Nut
I passed up buying an ART-9, (which by all accounts is an incredible Cartridge) simply because of the body. This latest lineup has a Threaded Body! My old hands won't let me deal with tiny taps anymore
I have been listening since earlier this morning to entire albums.
Dido's - Life For Rent
Donald Fagan's - Kamakiriad (currently listening to this one) and Morph the Cat
Dan Fogelburg's - Pheonix
Mumford and Son's - Babel
Eagles - The Long Run (Love, love, love the song, "The Sad Cafe")
......and last but not least....
Bob Segar's - Greatest Hits (Night moves sounded especially good)
More albums to come. It was just a nice day to listen and enjoy the music! It started out raining, then went on to sunny skies and turned out to be a beautiful day filled with awesome tunes. My new (to me) amplifier has me listening like never before and days like today are just what the doctor ordered.
You just described about every afternoon at my place during the colder months. Being retired has many perks and very few negatives
What Amp have you rolled in?
Hi, Mike. It's a Musical Fidelity KW750.
@treitz3 - sounds like you got past the streaming set-up woes?
If so, how do you have it set-up (i.e. LAN, wifi, streaming services being used)?
I’ve been using Airplay on mine, but need to get it to recognize my pc ripped files.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Nope. I haven't even bothered myself with it for about 3 or 4 weeks now. The damned thing frustrated me to no end, so I am taking a break. Using the LP player and Marantz for sources at the moment.
I have reached out to Auralic after sending a rather scathing email and they sent an email back stating that they can get me up and running, that I need to do some more technical crap before they proceed. I'll put it to you like this. I opened up the email, scanned through what they wanted me to do. Flagged the email and haven't looked at it ever since.
One of these days, I'll get back to it. Until then? I am simply enjoying the heck out of the rig as it is. I know it will be worth it when I do get it up because the snippets of the 3 songs that I did get it to play? Wow. It sounded really, really good. With that said, this is my hobby and I worked on it so much (basically a combined 24 hours)? I almost put my fist through the i-Pad. Hobbies should not make you infuriated.....so I'll wait a bit. I am still in my "cooling down" period.
I may just call the cable company and have them set up the router in the stereo room and let the rest of the house run on wi-fi, since nothing else seems to have any issues.
Mike Reeter wrote: »I have been listening since earlier this morning to entire albums.
I am SOOO jealous of you retired folks!See my profile for list of gear. -
I have a px3 rebuilt with a fifty dollar audio Technica cart and a turntable weight running through a carver c-19 modded though a ps audio
200cx heavily modded through legacy rare bookself speakers and my mouth is on floor.lol
https://www.youtube.com/watch?v=q6qmIBdxOEI
