mhardy6647 wrote: »Solid state amplifiers (or receivers) draw very little current (more to the point, they consume very little power) at idle.
Unless it is Class A.
That is absolutely true: Class A (power) amplifiers are running essentially "flat out" at all times, whether tubed or solid state.
Doing some serious A/B'ing between my B&K M200's and my Belles 350a Reference... Again.
Update. Rolland at Hi-Tech Audio told me to use a 2 prong adapter on my power cable for my Belles. Much better!Gustard X26 Pro DAC
Oh those B&K must sound terrible against the Belles. You should probably just sell the M200s to me.
just listened to it for hours today, no work done!
On & off over the past 2 weeks messed w/an RTA and its mic at preferred seating monitoring just my LR RTi A7 towers
This first image is the un-tweaked in-room FR. Pink noise from a phone app, LP’d ~3K. I turned off subs & verified DSP was disabled....
...and the after. LP’d @ 10Khz, after DSP W/subs.
During several sessions of fiddling & tweaking I learned and/or discovered a few things:
a. the spec’d FR is only the roughest suggestion of in-room FR.
b. In-room will surprise you
b. by the first “graph” you see a substantial hump @ 35hz. Polk specs the F3 at 35hz.
c. the tweeters* were “flipped”. I noticed a notch right at XO frequency between them* and the mids. I flipped first one channel, then the other seeing the notch disappear.
Following some tips from a friend:
a.I smoothed out the FR low end by “carving” the peaks - no boosted frequencies.
b. I performed BSC w/a 3dB sloped shelving cut @ 576hz followed by turning up the mid a few dB
I’m delighted the final in-room system F3 is below 25hz
During the last session I did some prelim on my CSi A6 center. I determined the tweeter has issues - blown I think. Next chance I’m gonna look at the RTi A3 surrounds and their subs.
CheersSamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
Ha! I seriously can't decide which one I'd part with. Since I don't have a gun to my head I'll probably just put one of them back in the spare bedroom eventually.Gustard X26 Pro DAC
Today I swapped my Yaqin mc100b tube integrated for the Mc mono's just to change things up a bit for a few days. It should be quite a change going from 1200+wpc down to 45wpc in triode mode.
My guess is the 1.2tl's aren't going to be as happy now with the big reduction in current
Gosh I'd love to hear both to be honest.
You're more than welcome to stop by if you're ever in the area.
Skipped the preamp and plugged the Lumin directly in to the amp. Yes please, more of this!
This isn’t great for the TT since both can’t be plugged in at the same time. Meaning I would be connecting and disconnecting ICs to change source and believe I would need a phono pre like Gram Slee Ascension.
That said I’m going to have an in home Demo of the RP-7 this weekend.
I really don’t know which way this is going to go. My Logic says less is more and having a preamp can only get in the way but who knows, it could add that something special.
I’m not a betting man but any thoughts on how it ends?
Karma after a decision is made! Wish me luck!Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels -
motorstereo wrote: »45wpc in triode mode.
Try the Yaqin in ultralinear mode as well...looking forward to your impressions.SDA SRS 2.3TL's
SDA 2B TL's -
I have been ignoring mine. But I got a bunch of iFi noise doohickeys to test when I have the presence of mind to check out.
Wespongebobsquarepants wrote: »
Well I took My 99 Magnum out of the chain so if my phone, as the current remote adds static, I will blame @daboyz !Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels -
phipiper10 wrote: »Skipped the preamp and plugged the Lumin directly in to the amp. Yes please, more of this!
I’m looking forward to your thoughts....
I’m not unhappy in the slightest with my Cary 05 preamp. However, I’ve often wondered what the RP-7 (or 9) would bring to the table when paired with my Rogue M-180 monos.
btw, I just upgraded to the Dark mod
Which LUMIN do you have?
TIAAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
phipiper10 wrote: »I’m looking forward to your thoughts....
TIA
I have the lumin T2. Also picked up Primaluna Evo 400 preamp, just before getting the RP-7 (no RP-9 at my dealer) this afternoon.
Primaluna is up first and just casual listening right now. I'll do a little write up when done.
Never heard them but Those Apollo Darks were on my wish list. Think I'd be afraid of those, they are beasts!Post edited by phipiper10 onAnalog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels -
Yesterday, performed a more comprehensive cleaning of equipment and stand than usual. And...
...tweaked the surrounds and their subs - much more challenging than the LRs and their subs. I regret no RTA image to post. The tweaked FR is smoother than before but it needs more than I had time allowed.
“The Dark Knight Rises” sounding MANY times better than in the theatre @ PCB years ago. In PCB theater, ANY gun fire hurt my ears so much I had to anticipate to put my fingers in my ears. My system - NO PROBLEM!Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
Put my B&K monos in the closet. The upgrade I performed on the Belles 350a Reference is taking a lot longer to break in than expected but I'm really liking what I hear. The things I liked more about the B&K's are becoming less of a difference now. The Belles takes up less space too.Gustard X26 Pro DAC
Nice of you to give Tom Cruise a set of amps to build around...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I had a pair of Mullard cv4003's that I thought were noisy since last I played them was a few years back when I had a Belles 21a preamp. Well something told me to try them in my Mastersound Compact 845 integrated amp. They were dead quiet and the best sound I have heard from the Mastersound, not to mention that it saved me $300 as that is what they are going for a pair now.
Puritan PSM156 -
I’ve been running this guy in my rig the last few days. AVA FET Valve 600R Hybrid. Sounds just plain excellent to my ears.
I’m wondering what some NOS Mullards or similar in the input stage might do for the sound. -
Almost pulled the trigger on that one several years ago. Glad you are liking it!
What tubes?
Its almost brand spankin new and still has the stock JJ 12at7 tubes in it. Just when I thought I would stay away from tubes , they drag me right back in. It sounds great as is but it’s been my experience with tube rolling there is a chance to be even better...guess it’s time to look for a deal on some nice sounding NOS replacements. -
That is a serious toroid...
I have this tube in my DAC, it provides the 'Secret Sauce'. In the right application, it's one of the best.
Warming up the HT for the big game, so nothing major just getting ready.Home Theater
What game would that be?
“Game” is right, I ain’t watching nothing
Being a Vikings fan it wont be a Packer Game, Aaron will be sitting at home watching it pretty sure he wont be boycotting it it's a game that he and Brady have one thing in common, that is they have each one a NFC championship game.
It was a **** season with all the teams not having all their starters and players opting out because of the pandemic that along with all the other BS that went on I agree with you guys I did not watch many games until the playoffs, as it didnt seem like a real season to me. But it's the Superbowl dangit it's like -20 with the wind chill I'm staying in and watching a inferior product and eating a ton of chicken wings and guacamole and chips tossing back a few cold ones and watch Mahomes win a second ring even if it is an astrix season. Dro just giving you a hard time about Rodgers joking aside.Home Theater
