My Pioneer PD-09 was/is no slouch but this Krell is a magnitude force factor of 10.
Much cleaner bass, better midrange and the sparkle in the upper registers are crisp clean and concise without any fatigue.
You said it, IT was no lie!!
END GAME!!!
I mean really it sucks😳🤣
I was wondering whose tranny was missing some gears! Congrats Ivan!AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
END GAME!!!
Thanks Glenn.
John and I had fun with all that.
Great seller and a wonderful Polkie.
I had ran into some initial problems with it playing some SACD's. While he does have the manual he was not able to include it's due to its location at the time of packing. He was very helpful in getting the player to play the SACD's I was having trouble with.
It has played everything I have put in it today.
Glad this stayed in the family Ivan. It is also good to know my description of you was right on the money!
I have realized I was off in my comment here, thinking @nooshinjohn had purchased (a lowly) Audio Technica cart. In my defense, the logo on the box confused me between the two manufacturers. Perhaps you can understand my confusion looking at the company logos side-by-side:Oh, so GF is now the backup? I really like the AT house sound. I guess my top ones are OC9/I & III, and AT33PTG. Also an AT33 Mono. Lots of vintage AT MM carts as well. Nice, flat FR IMO.
For the record, though, I do like the AT house sound...especially for the money."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
I recently picked up an AT-OC9XSL, about 40 hours in and it's starting to shine. I like the Threaded Body on the new style AT offerings as well.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
I'm gonna need another piece from you so I can put some in the back of the enclosure behind my driver in my Martin Logan Dynamo Sub. Ha ha just kidding!
Thanks again and Happy New Year!George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
How would that affect the your ML sub’s FR?Gardenstater wrote: »I'm gonna need another piece [of BH] from you so I can put some in the back of the enclosure behind my driver in my Martin Logan Dynamo Sub.
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
I've also wondered about putting my left over bh5 in my sub.......anyone know if it's a good idea or should I leave well enough alone?
I don't know. I think that it will have the effect of making the enclosure size somewhat larger. I don't know how much larger based upon size of BH5 piece. The EQ section of the circuitry inside is designed for the sub as is, not modified, of course.
I think I need to start small. I would hope that by attenuating some of the back wave reflection, it will make the sound more clean. Also, the BH5 should reduce some of the panel resonance on any panel it is applied to.
I would also appreciate any input from DIY speaker builders.George / NJ
iFi nano iDSD DAC
iPurifier3
motorstereo wrote: »I've also wondered about putting my left over bh5 in my sub.......anyone know if it's a good idea or should I leave well enough alone?
You still haven't given us your listening impressions on your 1.2tl's !!!George / NJ
iFi nano iDSD DAC
iPurifier3
Gardenstater wrote: »motorstereo wrote: »I've also wondered about putting my left over bh5 in my sub.......anyone know if it's a good idea or should I leave well enough alone?
Woops sorry bout that. Ok here's what I've noticed so far in my few hours of listening. To start with there's slightly better bass and slightly clearer vocals. Those 2 areas are very subtle improvements and it does take some critical listening to notice the change. The biggest change I've noticed and is impossible to overlook is the center image is now more solid and pronounced. I had always thought the 1.2tl's center imaging was a weak spot compared to some of my other speakers. That is no longer the case. Thankfully this increased center imaging does not come at the cost of losing any of the wide and deep sda soundstage. I have not noticed any change in the depth or width of the soundstage.
I'm also wondering if some of the improvements may have come from breaking and re-making 16 speaker connections that haven't been touched since 2012. At any rate I'm pleased with the improvements and recommend this easy to do mod.
Well that's terrific! I believe your install was about 40% less BH5 surface area per MW driver than mine. Perhaps it was more subtle in your case due to that, whereas it was in your face instantly noticeable in my particular situation. I don't think mine is overdone or too sterile and I'm really happy with it. Everything is just clearer, and I also noticed a better center image where there is more air to the sound and the acoustics of the recording venue are more apparent, making everything sound more live.George / NJ
iFi nano iDSD DAC
iPurifier3
Black hole 5 does not make the cabinet seem larger, that's what polyfill is for. Black hole five is to cut down the reflection inside the cabinet so you have a cleaner sound. -
motorstereo - Did you read DarqueKnight's thread on his BH5 1.2tl install? He used more material; strips on the side walls and behind the tweeters.
https://forum.polkaudio.com/discussion/148198/blackhole-5-damping-material-in-the-sda-srs-1-2tl
invalid - you don't think that the speed of sound would be reduced when travelling through that outer layer of open cell foam until it reaches the barrier layer of polymer that isolates the inner damping mat'l + foam from the outer? That layer is about 1" thick. If so, then the effective cabinet volume should increase by some small amount. At least that's my understanding.
Edit to add - However, there is about 1/4" of reduced cabinet volume due to the location of that isolation layer. I wonder if it balances out at no effective volume change?Post edited by Gardenstater onGeorge / NJ
iFi nano iDSD DAC
iPurifier3
There is no back wave from tweeters. Yes I also ran a 4" wide piece behind the woofers only and the same length of the woofers on the sides 3 inches wide. I covered non of the factory standing wave cuts. There's minimal if any gain to be had behind the tweeters.
SRS 2.3tl
I assumed that DarqueKnight knew there was no backwave from the tweeters and that the reason he put some material there was that it was just a suitable place to put some more in, absorbing more reflected and standing waves in such a large cabinet volume as the 1.2tl.George / NJ
iFi nano iDSD DAC
iPurifier3
I thought about it. We know BH5 would help w/resonances but I’m guessing the BH5 excels at maybe 500-1K hz on up - little if any in the lowest octaves.motorstereo wrote: »I've also wondered about putting my left over bh5 in my sub.......anyone know if it's a good idea or should I leave well enough alone?
However consider this non-comital way to try it. Do a little listening to just the sub. Casually tape a piece to rear wall. And, well... you know the rest.
Let us know. TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
Tony - I guess brilliant minds think alike
I was thinking just the same and that maybe a couple strips of double sided carpet tape would work well. Of course, the BH5 won't have its full effect of reducing the vibrations of the panel it is taped to, as it would if it was properly bonded with its PSA, and when removing it the protective paper may be taken off at the same time. No biggie. George / NJ
iFi nano iDSD DAC
iPurifier3
Thanks George - yes we do! I believe he could confirm either way if BH5 affects bass response the way it affects mids and above - since this is an FR-only experiment, I doubt he will hear a diff.Gardenstater wrote: »Tony - I guess brilliant minds think alike
If I had piece of BH about a foot square I’d give it a go though my subs come up a smidge short below 30hz
Curious... TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
Interesting youtube video.....Does Polyfill Make a Box Bigger? - Tested and Revealed
https://www.youtube.com/watch?v=INM0g1JeMLY
One could do the same experiment with BH5 carpet taped inside of a subwoofer enclosure.
I have modified my Martin Logan Dynamo so that I have the option of placing the circuit board outside of the enclosure and I could actually stuff it completely full with Polyfill and/or BH5 on all the walls except the baffle. I'd have to get the measurement equipment of course.George / NJ
iFi nano iDSD DAC
iPurifier3
Thanks and yes I did read that. The jury is still out whether or not I'm going to do the side wall strips. At some point I probably will and then I'll have a good reference point of how they sound with just the backs done. There's no backwave behind the tweeters so no I don't plan on treating that area. . -
OK cool. Looking forward to your further impressions. Not to be a wiseguy but there's no "backwave" at the sides either. I think it's more a matter of having the BH5 in the vicinity of the drivers because every surface of the back of the cone becomes a point source for a sound wave, in other words there are sound waves radiating out in all directions and bouncing all over the place within the cabinets and that can cause interference with the proper primary motion of the cones. I think the other key is amount of BH5 relative to total cabinet volume, along with keeping the area around the passive free of it. Just my 2c.George / NJ
iFi nano iDSD DAC
iPurifier3
Finished up some stands for a recently acquired pair of Quicksilver Mono 120 Amps.
Picked this up to give it a spin.
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
It's an Integrated amp.2 Channel
Oppo 103
Pangea PC
I just looked up it's specs and it seems very well made .
It's supposed to drive all speakers with ease. Sounds like a winner to me.
let us know later on.
Will do,once I spend some more time with it.But I can say right now this is the best amp I've had in my system so far and it has detail in spades. It doesn't break a sweat running the 1.2tl's.2 Channel
Oppo 103
Pangea PC
@dkfreebird sure you don't want to try a norma in there?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156
