Billet RD-0194/8 tweeter plate design.
Enjoying the reflection from the christmas lights -
Jingle tweets.Don't take experimental gene therapies from known eugenicists.
Little update and FYI. I was assembling another set of the billet plates with aftermarket domes and testing. I couldn't get one of them to sound just right unless I left the magnet screws too loose. After disassembling, I found excess solder at the wire leads/fast-on tabs that was sharp and penetrating the insulating tape. I just hit it with a fine flat file and the shorting went away...
Don't take experimental gene therapies from known eugenicists. -
I'll look close to the ones I have yet to do.
I still have a bunch to test. If I hear something bad, that's the first thing I'll look at if/when I'll have to remove them.Most people just listen to music and watch movies. I EXPERIENCE them.
Look what I found on my doorstep. Very nice work, Rob! Thank you.
No disrespect to the bling factor, the stainless is sweet, but my preference is for black, so next step is to find a shop that can do the work. Unless, you can recommend a suitable DIY paint process...etching followed by a mat black?
Pics don't do them justice. Excellent in person.
➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
They are on my list as well.
To match the crossover plate, you can take them to a small-batch anodizing shop.
FYI, the two factory handles and the alloy crossover plate can be stripped and sanded to match.
I think just the two handles stripped and sanded to match would be a nice contrast and easy to do.Don't take experimental gene therapies from known eugenicists. -
I'd rather have the plates silver as I think it gives a nice looking contrast and a more custom look. Especially with Larry's custom crossover plates with the brass handles
They can be mirror-polished as well. I'll do a set and post pics this weekend if I have time.Don't take experimental gene therapies from known eugenicists.
I have Larry's custom XO plates w/red lettering and, to my knowledge, the only stainless handles he made. He may have one other. That's about as much stainless as I'm looking for. Anodized it is.
Krylon rattle can.Political Correctness'.........defined
President of Club Polk -
If they are aluminum handles, then 320 grit will make them match the plates' patina.Don't take experimental gene therapies from known eugenicists.
Krylon rattle can.
No issues w/it adhering to the metal? From what I read painting stainless will result in future chipping without specific prep.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Krylon rattle can.
Clean thoroughly with acetone or alcohol and hit with a coat of flat-black primer on the cheap is an option.
A few years back when I built some custom bikes, there was a guy that always won best of show for paint. They called him the Krylon Kid as he only used spray cans and lots of elbow grease. His work was immaculate.Don't take experimental gene therapies from known eugenicists. -
Sorry, your post popped up before I finished typing mine. My comment was in reference to the tweeter bezels.Political Correctness'.........defined
Okay, cool. I'll do a test run on the back of one plate to see how it comes out. Again, will state, your work and the SS is very nice...this is just a personal preference.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
Looks like we're all posting as the other does. You are correct...I want to paint the bezels. Edit to add...not the handles or XO plate. They've been with me since I bought the speakers.Post edited by JayCee on➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Looks like were all posting as the other does. You are correct...I want to paint the bezels.
The bezels are aluminum.Political Correctness'.........defined
Ah, just went back to page 1 and see "aluminum". Somewhere, in my failed memory, I was thinking SS. Thanks, Jesse, for clarifying my dumb a * s * s*. Sorry, Rob et al, for the confusion. This makes things much easier.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
6061-T6 aluminum to be exact. No worries. If you decide not to keep the black paint, just strip it with acetone.Don't take experimental gene therapies from known eugenicists.
My posts remind me of this....
https://www.youtube.com/watch?v=HrwDzuUtQKY ➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
To have good luck painting aluminum it must be acid etched or sanded and cleaned and then primed within several minutes to avoid oxidation which will prevent the primer from bonding.
I'd try something like this:
https://www.amazon.com/POR-15-40204-Metal-Prep-quart/dp/B00J5940JEGeorge / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
New billet plates Anodized and lazer engraved. Looking and sounding great!!
Huge thank you to Ray xschopYamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Thank you! and yes Rob of course 👍🙂Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
NICE!!!Political Correctness'.........defined
@xschop Whats happening Hoss ! When the site took a plunge I did not get back on for a while. Looks like your work has been kickin **** and taking names ! This is some great stuff you are building here man. I finally found 4 Polk MW in Atlanta. One with a slipped magnet so I finally got to try the tool . Quick easy works perfectly. Another original Polk Mid woofer saved from the scrap heap. Drove 4 hours round trip but 30.00 for four MW 6500's was worth it. Well, I did pick up some other stuff while I was out and about you know..
The laser engraving lettering almost looks white but I guess it is silver aluminum color? Looks great!George / NJ
iFi nano iDSD DAC
iPurifier3
Those look amazing
