Vintage Monitor and SDA Speaker Deals
1…200201203205206…262
    pitdogg2 Posts: 27,877
    How does a woofer cone get ripped off of the spider and surround?
    Cats!
  • JayCee
    JayCee Posts: 1,509
    I might add...my PS Audio DirectStream DAC was open box and purchased from Music Direct. I was able to get another $500 discount by simply asking for a lower price. YMMV.
    JayCee wrote: »
    ➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S3.3 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • engie490
    engie490 Posts: 447
    edited October 2020
    Telarc cannons!???!?!?
    Methinks the fact that it was one of the lowest ones is an important clue.
    KEF Xq5s / Velodyne DD12 / Apollon Purifi 1ET6525SA / SST Thoebe II / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
  • Gardenstater
    Gardenstater Posts: 4,919
    What might be the condition of the other ones if this ^^^ is the case? :#
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Mike Reeter
    Mike Reeter Posts: 4,315
    JayCee wrote: »
    JayCee wrote: »
    Yes, The people at M.D. will negotiate. Never hurts to ask.
    audioluvr Posts: 6,065
    ^^^ Holy. And I don't mean like the pope.
  • engie490
    engie490 Posts: 447
    edited October 2020
  • engie490
    engie490 Posts: 447
    edited October 2020
  • engie490
    engie490 Posts: 447
  • engie490
    engie490 Posts: 447
  • engie490
    engie490 Posts: 447
  • engie490
    engie490 Posts: 447
  • engie490
    engie490 Posts: 447
  • engie490
    engie490 Posts: 447
  • engie490
    engie490 Posts: 447
  • engie490
    engie490 Posts: 447
  • engie490
    engie490 Posts: 447
    edited October 2020
    The type of interconnect socket is the determining factor of what they are.
    Blade/blade = Original SDA SRS (non-compatible with Dreadnaught or AI-1).
    Pin/Blade = SDS SRS 1.2 The speakers either have the RD0-194's or they been TL'd depending if the RD0-198 tweeters are installed along with the appropriate changes to the crossover) or they are SDA SRS 1.2TL with the RD0-198's. Dreadnaught or AI-1 compatible.
    So, I pestered the owner for a pic of the SDA connection and this is what he added to the auction...
    And now he's added this...
    Tony M Posts: 11,997
    Seems like prices are going UP... :p
  • michaeljhsda2
    michaeljhsda2 Posts: 2,207
    edited October 2020
    engie490 wrote: »
    They are 1.2's at the least because they have the pin/blade socket, however, the next question is...are the tweeters RD0-198's, if so they would be 1.2TL's ...if they're RD0-194's they're 1.2's but can be converted to 1.2 TL's. Easy way to find out is to remove a tweeter and if the white negative post is larger than the colored positive post they're RD0198's.
    What's up with the socket further down? Looks like a microphone socket. SMH
    SDA SRS 2.3TL's
    SDA 2B TL's
    I think some used xlr plugs/sockets in the past.
  • engie490
    engie490 Posts: 447
    [/quote]
    They are 1.2's because they have the pin/blade socket but what's up with the socket further down? SMH
    [/quote]
    He said he connected using that XLR JACK and it didn’t affect the sound. I asked him to take a pic of the binding posts so I could see the SDA jack and he realized that he show try connecting the SDA cable correctly. So, he wants to hear the SDA effect before he sells them.
    He also did the leak test and the drivers moved back in about a second.
    He did confirm the tweets are all RD-0194s.
  • michaeljhsda2
    edited October 2020
    The Binding post nuts need to be reversed because the 1.2 and 1.2 TL is the opposite of the original SRS. The label on the back of the speakers show that the positive is on the right but that is incorrect since these are 1.2's. Polk was Notorious for using old stock on newer models. For once you don't want to follow the label directions LOL
    Once the seller reverses the wires he will notice a major improvement in bass, as it is now, the speakers are out of phase.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • spongebobsquarepants
    https://www.ebay.com/itm/233753356447
    SDA-2(A?) in NJ for $250 with "make an offer."
    I wanna buy 'em cause the cabinets look great(way better than mine).... but the WAF of having two sets of these in the house... even for a few months :#
  • engie490
    engie490 Posts: 447
    Spongebob...this one is a softball...
    "Honey, I only got these because I want to make you happier about my speakers. These are SO much better looking than my current pair and I'll sell the old ones in a couple months and break even."
    Boom. Done.
    Whatcha want in the obit section Bob???
  • BlueBirdMusic
    engie490 wrote: »
    Boom. Done.
    Most of the time WAF will defy logic.
    Harry / Marietta GA
  • engie490
    engie490 Posts: 447
    engie490 wrote: »
    Boom. Done.
    I may have failed to adequately explain this last part. The “Boom” is a shotgun blast and Spongebob is the “Done.”
  • engie490
    engie490 Posts: 447
    OK...here's a pretty good deal in KC. Pair of SDA-2Bs for $125. Looks great, but only one works. Could be a polyswitch...
    https://kansascity.craigslist.org/ele/d/olathe-polk-audio-sda-2b-speakers/7219530424.html
    I'd buy them if the mid-woofers move freely. ;)
  • Gardenstater
    edited October 2020
    Ha ha these sound strangely familiar. Most likely all 3 drivers are blown in the speaker that doesn't work.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
