Vintage Monitor and SDA Speaker Deals
Polk SDA SRS 1.2s (claimed) in VA
https://richmond.craigslist.org/ele/d/richmond-polk-sda-12/7211794170.html
Apogee Stages / Apollon Purifi 1ET6525SA / Classe CT-SSP / Innersound Phono / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts -
Polk SDA SRS 2.3TLs in NC
https://greensboro.craigslist.org/ele/d/graham-polk-audio-sda-srs-23tl/7215406858.htmlApogee Stages / Apollon Purifi 1ET6525SA / Classe CT-SSP / Innersound Phono / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts -
Polk SDA SRS 2.3s in Central Coast of CA.
https://hanford.craigslist.org/ele/d/riverdale-polk-audio-sda-speakers/7215751096.htmlApogee Stages / Apollon Purifi 1ET6525SA / Classe CT-SSP / Innersound Phono / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts -
Polk Audio SDA SRS 3.1TL near Palm Springs CA
https://inlandempire.craigslist.org/ele/d/hemet-polk-audio-sda-srs-31tl-speakers/7214425263.htmlApogee Stages / Apollon Purifi 1ET6525SA / Classe CT-SSP / Innersound Phono / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts -
michaeljhsda2 wrote: »The type of interconnect socket is the determining factor of what they are.
Blade/blade = Original SDA SRS (non-compatible with Dreadnaught or AI-1).
Pin/Blade = SDS SRS 1.2 The speakers either have the RD0-194's or they been TL'd depending if the RD0-198 tweeters are installed along with the appropriate changes to the crossover) or they are SDA SRS 1.2TL with the RD0-198's. Dreadnaught or AI-1 compatible.
So, I pestered the owner for a pic of the SDA connection and this is what he added to the auction...
And now he's added this...
Seems like prices are going UP...
They are 1.2's at the least because they have the pin/blade socket, however, the next question is...are the tweeters RD0-198's, if so they would be 1.2TL's ...if they're RD0-194's they're 1.2's but can be converted to 1.2 TL's. Easy way to find out is to remove a tweeter and if the white negative post is larger than the colored positive post they're RD0198's.michaeljhsda2 wrote: »The type of interconnect socket is the determining factor of what they are.
What's up with the socket further down? Looks like a microphone socket. SMH
SDA SRS 2.3TL's
SDA 2B TL's -
I think some used xlr plugs/sockets in the past.
[/quote]
They are 1.2's because they have the pin/blade socket but what's up with the socket further down? SMH
[/quote]
He said he connected using that XLR JACK and it didn’t affect the sound. I asked him to take a pic of the binding posts so I could see the SDA jack and he realized that he show try connecting the SDA cable correctly. So, he wants to hear the SDA effect before he sells them.
He also did the leak test and the drivers moved back in about a second.
He did confirm the tweets are all RD-0194s.Apogee Stages / Apollon Purifi 1ET6525SA / Classe CT-SSP / Innersound Phono / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts -
The Binding post nuts need to be reversed because the 1.2 and 1.2 TL is the opposite of the original SRS. The label on the back of the speakers show that the positive is on the right but that is incorrect since these are 1.2's. Polk was Notorious for using old stock on newer models. For once you don't want to follow the label directions LOL
Once the seller reverses the wires he will notice a major improvement in bass, as it is now, the speakers are out of phase.SDA SRS 2.3TL's
SDA 2B TL's -
https://www.ebay.com/itm/233753356447
SDA-2(A?) in NJ for $250 with "make an offer."
I wanna buy 'em cause the cabinets look great(way better than mine).... but the WAF of having two sets of these in the house... even for a few months
spongebobsquarepants wrote: »I wanna buy 'em cause the cabinets look great(way better than mine).... but the WAF of having two sets of these in the house... even for a few months
Spongebob...this one is a softball...
"Honey, I only got these because I want to make you happier about my speakers. These are SO much better looking than my current pair and I'll sell the old ones in a couple months and break even."
Boom. Done.
Whatcha want in the obit section Bob???
Boom. Done.
Most of the time WAF will defy logic."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Boom. Done.
I may have failed to adequately explain this last part. The “Boom” is a shotgun blast and Spongebob is the “Done.”Apogee Stages / Apollon Purifi 1ET6525SA / Classe CT-SSP / Innersound Phono / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts -
OK...here's a pretty good deal in KC. Pair of SDA-2Bs for $125. Looks great, but only one works. Could be a polyswitch...
https://kansascity.craigslist.org/ele/d/olathe-polk-audio-sda-2b-speakers/7219530424.html
I'd buy them if the mid-woofers move freely.
Ha ha these sound strangely familiar. Most likely all 3 drivers are blown in the speaker that doesn't work.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
I just want the drivers.Don't take experimental gene therapies from known eugenicists.
Uh-oh, he accepted $200!
Check the other thread. I think he sold them already and most likely the voice coils were trashed due to some high current flow, maybe a lightning strike or amplifier malfunction. Do you have any plans on how to fix MW's with bad voice coils. We know you can fix the tweeters and make them better to boot
George / NJ
iFi nano iDSD DAC
iPurifier3
Maybe I spoke too soon.
I'd taken the MW drivers as long as they ohm out....Don't take experimental gene therapies from known eugenicists. -
spongebobsquarepants wrote: »Uh-oh, he accepted $200!
I hope your life insurance is paid up!Apogee Stages / Apollon Purifi 1ET6525SA / Classe CT-SSP / Innersound Phono / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts -
Gardenstater wrote: »Ha ha these sound strangely familiar. Most likely all 3 drivers are blown in the speaker that doesn't work.
You are correct. I took a chance on them, and all three are indeed blown.
I think they're a bigger project than I want to tackle at the moment. If anyone in the area wants them for parts, let me know. -
Welcome to Club Polk. Man up and put some love into them. Lots of help here if needed.Gustard X26 Pro DAC
If you decide to keep them refer to the other thread and start another one and we'll continue to help. Giddyap!
https://forum.polkaudio.com/discussion/192261/sda-2b-crossover-help#latestGeorge / NJ
iFi nano iDSD DAC
iPurifier3
Thanks!
You're probably right. They could be a decent starting point for a full rebuild. Gonna need to shop for a lot of parts. -
I see the crossovers fairly often on eBay. You may have a damaged inductor or two in that speaker that doesn't work, in addition to fried voice coils in all the drivers. The SDA 2B and the CRS+ use the same crossovers. You could probably find an inductor with the same inductance and resistance and you could replace them in matched pairs on both XO's also if you wanted.George / NJ
iFi nano iDSD DAC
iPurifier3
Do the MWs even ohm out or are they open/shorted?Don't take experimental gene therapies from known eugenicists.
ALL drivers in the bad speaker read open. Unfortunately, the 6511 in the working speaker has also been replaced with a 6500 at some point in time.
