Vintage Monitor and SDA Speaker Deals
1…199200202204205…259
  • engie490
    engie490 Posts: 447
    KEF Xq5s / Velodyne DD12 / Apollon Purifi 1ET6525SA / SST Thoebe II / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
  • engie490
    engie490 Posts: 447
  • engie490
    engie490 Posts: 447
  • engie490
    engie490 Posts: 447
  • engie490
    engie490 Posts: 447
    edited October 2020
    The type of interconnect socket is the determining factor of what they are.
    Blade/blade = Original SDA SRS (non-compatible with Dreadnaught or AI-1).
    Pin/Blade = SDS SRS 1.2 The speakers either have the RD0-194's or they been TL'd depending if the RD0-198 tweeters are installed along with the appropriate changes to the crossover) or they are SDA SRS 1.2TL with the RD0-198's. Dreadnaught or AI-1 compatible.
    So, I pestered the owner for a pic of the SDA connection and this is what he added to the auction...
    And now he's added this...
    Tony M Posts: 12,015
    Seems like prices are going UP... :p
  • michaeljhsda2
    michaeljhsda2 Posts: 2,216
    edited October 2020
    engie490 wrote: »
    They are 1.2's at the least because they have the pin/blade socket, however, the next question is...are the tweeters RD0-198's, if so they would be 1.2TL's ...if they're RD0-194's they're 1.2's but can be converted to 1.2 TL's. Easy way to find out is to remove a tweeter and if the white negative post is larger than the colored positive post they're RD0198's.
    What's up with the socket further down? Looks like a microphone socket. SMH
    SDA SRS 2.3TL's
    SDA 2B TL's
  • engie490
    engie490 Posts: 447
    [/quote]
    They are 1.2's because they have the pin/blade socket but what's up with the socket further down? SMH
    [/quote]
    He said he connected using that XLR JACK and it didn’t affect the sound. I asked him to take a pic of the binding posts so I could see the SDA jack and he realized that he show try connecting the SDA cable correctly. So, he wants to hear the SDA effect before he sells them.
    He also did the leak test and the drivers moved back in about a second.
    He did confirm the tweets are all RD-0194s.
  • michaeljhsda2
    edited October 2020
    The Binding post nuts need to be reversed because the 1.2 and 1.2 TL is the opposite of the original SRS. The label on the back of the speakers show that the positive is on the right but that is incorrect since these are 1.2's. Polk was Notorious for using old stock on newer models. For once you don't want to follow the label directions LOL
    Once the seller reverses the wires he will notice a major improvement in bass, as it is now, the speakers are out of phase.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • spongebobsquarepants
    https://www.ebay.com/itm/233753356447
    SDA-2(A?) in NJ for $250 with "make an offer."
    I wanna buy 'em cause the cabinets look great(way better than mine).... but the WAF of having two sets of these in the house... even for a few months :#
  • engie490
    engie490 Posts: 447
    Spongebob...this one is a softball...
    "Honey, I only got these because I want to make you happier about my speakers. These are SO much better looking than my current pair and I'll sell the old ones in a couple months and break even."
    Boom. Done.
  • BlueBirdMusic
    engie490 wrote: »
    Boom. Done.
    Most of the time WAF will defy logic.
    Harry / Marietta GA
  • engie490
    engie490 Posts: 447
    engie490 wrote: »
    Boom. Done.
    I may have failed to adequately explain this last part. The “Boom” is a shotgun blast and Spongebob is the “Done.”
  • engie490
    engie490 Posts: 447
    OK...here's a pretty good deal in KC. Pair of SDA-2Bs for $125. Looks great, but only one works. Could be a polyswitch...
    https://kansascity.craigslist.org/ele/d/olathe-polk-audio-sda-2b-speakers/7219530424.html
    I'd buy them if the mid-woofers move freely. ;)
  • Gardenstater
    Gardenstater Posts: 4,936
    edited October 2020
    Ha ha these sound strangely familiar. Most likely all 3 drivers are blown in the speaker that doesn't work.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,829
    I just want the drivers.
    Uh-oh, he accepted $200!
  • Gardenstater
    edited October 2020
    xschop wrote: »
    Check the other thread. I think he sold them already and most likely the voice coils were trashed due to some high current flow, maybe a lightning strike or amplifier malfunction. Do you have any plans on how to fix MW's with bad voice coils. We know you can fix the tweeters and make them better to boot ;)
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,829
    Maybe I spoke too soon.
    I'd taken the MW drivers as long as they ohm out....
  • engie490
    engie490 Posts: 447
    I hope your life insurance is paid up!
  • bigmontana
    You are correct. I took a chance on them, and all three are indeed blown.
    I think they're a bigger project than I want to tackle at the moment. If anyone in the area wants them for parts, let me know.
    audioluvr Posts: 6,079
    Welcome to Club Polk. Man up and put some love into them. Lots of help here if needed.
  • Gardenstater
    edited October 2020
    If you decide to keep them refer to the other thread and start another one and we'll continue to help. Giddyap!
    https://forum.polkaudio.com/discussion/192261/sda-2b-crossover-help#latest
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • bigmontana
    Thanks!
    You're probably right. They could be a decent starting point for a full rebuild. Gonna need to shop for a lot of parts.
  • Gardenstater
    I see the crossovers fairly often on eBay. You may have a damaged inductor or two in that speaker that doesn't work, in addition to fried voice coils in all the drivers. The SDA 2B and the CRS+ use the same crossovers. You could probably find an inductor with the same inductance and resistance and you could replace them in matched pairs on both XO's also if you wanted.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,829
    Do the MWs even ohm out or are they open/shorted?
  • bigmontana
    ALL drivers in the bad speaker read open. Unfortunately, the 6511 in the working speaker has also been replaced with a 6500 at some point in time.
