Vintage Monitor and SDA Speaker Deals
10 hours to go...Santa Barbara Cal. . 52.00 but reserve has not been met.
https://www.ebay.com/itm/184451125023?ul_noapp=true
How much is the reserve? -
Can an eBay seller remove the Reserve Requirement during the bidding if they wish?George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout. -
You have to contact the seller to find out.
Or if the bidding goes high enough, it will show reserve has been met. The bidding can continue on though if a bidding war happens.Most people just listen to music and watch movies. I EXPERIENCE them.
Gardenstater wrote: »Can an eBay seller remove the Reserve Requirement during the bidding if they wish?
You used to be able to. -
17 minutes left and the bidding is still at 52 dollars.
They have been relisted.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I'm not surprised that he didn't get much interest. He's got ZERO feedback and his first auction is for 30-year-old, very large speakers with local pickup only. Just put a BIN price on there and let it ride.KEF Xq5s / Velodyne DD12 / Apollon Purifi 1ET6525SA / SST Thoebe II / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
I actually forgot to look at the sellers sales/purchase record.
Yea, 0 doesn't help one bit.Most people just listen to music and watch movies. I EXPERIENCE them.
Now this is a smokin deal.
RD-0?s already in place.
1250.00
Santa-Monica Ca.
These look great! Tape or light suction can fix those dust caps.
https://www.ebay.com/itm/114432753359?ul_noapp=true
So which model might these be?
His ad says SRS and there are 13 screws on the crossover plate, so without a picture of the serial number and/or terminal cup, we have to believe him.
Hopefully, those tweeters are 194s and all of the mids are correct. He states in the ad that all of the drivers were replaced 8 years ago.KEF Xq5s / Velodyne DD12 / Apollon Purifi 1ET6525SA / SST Thoebe II / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts -
They are SRS's the drivers say Polk on them so he probably means he replaced the tweetersGustard X26 Pro DAC
I tried to enlarge the serial number picture but no luck.
Original SRS.
My bad...there is one pic of a serial number. Using the magnifying tool in ebay, it looks like 5226 or 5228. So, assuming the other channel is around the same number, they should work with the Dreadnaught or AI-1. If the left channel is less than 5000, then not so much...KEF Xq5s / Velodyne DD12 / Apollon Purifi 1ET6525SA / SST Thoebe II / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
The type of interconnect socket is the determining factor of what they are.
Blade/blade = Original SDA SRS (non-compatible with Dreadnaught or AI-1).
Pin/Blade = SDS SRS 1.2 The speakers either have the RD0-194's or they been TL'd depending if the RD0-198 tweeters are installed along with the appropriate changes to the crossover) or they are SDA SRS 1.2TL with the RD0-198's. Dreadnaught or AI-1 compatible.
SDA SRS 2.3TL's
SDA 2B TL's -
These early 5's with silver basket MW's and Peerless look pretty nice but typical NJ market prices $180
https://www.ebay.com/itm/PAIR-Vintage-Polk-Audio-Monitor-5-Speakers-with-Peerless-Tweeters-Early-version-/133457735176?_trksid=p2385738.m4383.l4275.c10
George / NJ
iFi nano iDSD DAC
iPurifier3
A pair of SDA-SRS in Nashville for $1,000...but missing a mid. They look to be in good condition otherwise.
https://nashville.craigslist.org/ele/d/nashville-vintage-polk-audio-floor/7209400086.html
I just got home from Nashville a couple hours ago.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Those are 1.2's which can be converted to 1.2tl's. The binding post nuts need to be reversed, in order to hear them in correct phase. The diagram on the back is for the original SRS (blade/blade IC socket) and these are pin/blade.SDA SRS 2.3TL's
SDA 2B TL's -
Looks like that one driver was torn out as you can see the spider.
Yeah, wondering if these are worth the price given the need for a replacement mid, crossover upgrades, etc."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
I'd buy 'em! Can someone pick 'em up for me and deliver to Colorado? I'll definitely buy you some brews from some of the local breweries...KEF Xq5s / Velodyne DD12 / Apollon Purifi 1ET6525SA / SST Thoebe II / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
I could probably get his price down a bit because of the damaged woofer. Of course I'd want to check movement on the other mid-woofers, and check overall condition. Hmmm..."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Not vintage but the new kid on the block. Open box @ a discount...
https://www.musicdirect.com/speakers/Polk-Audio-Legend-L800-Tower-Speakers-Walnut-OPEN-BOX?sc_src=email_1786480&sc_lid=97255930&sc_uid=QIIxpsp4LG&sc_llid=56609&utm_source=Emarsys&utm_medium=email&utm_campaign=musicdirect+soundbytes+issue+#960_5_10-16-20sc_eh=0860fe8ee87102da1➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S3.3 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Nice Work! It's down to $800!!!!!!!KEF Xq5s / Velodyne DD12 / Apollon Purifi 1ET6525SA / SST Thoebe II / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts -
How does a woofer cone get ripped off of the spider and surround?George / NJ
iFi nano iDSD DAC
iPurifier3
