Looking forward to L800 but have concerns, what are your thoughts?
1…1516182021…24
  • Hermitism
    Hermitism Posts: 4,348
    Viking64 Posts: 7,801
    joecoulson wrote: »
    Completely agree.
    With what?
    F1nut Posts: 52,376
    Clipdat wrote: »
    Jimmy you're a toxic troll that hoped for genocide on a country. Do us all a favor and GTFO.
    Agreed
    nooshinjohn Posts: 26,135
    la2vegas wrote: »
    We do... until you and Viking show up and start your BS.
    la2vegas wrote: »
    Quoted.
  • dromunds
    dromunds Posts: 10,173
    C'mon guys, let's get back to audio, this is a L800 thread
  • mpitogo
    mpitogo Posts: 523
    I am currently bi-amping my L800 to take advantage of the SDA with a single ended treble amplifier 160W@4ohms with a voltage gain matched quad-balanced bass amplifier 450W@4ohms.
    I am about to setup my L800 with active Bi-Amp with the crossover set at 370Hz. Is it ok to remove the woofer low pass filter?
    And on another note, the active crossover is a 3-way balanced crossover but currently only using it as a 2-way with High Pass and Low Pass filters, switchable to include a midband filter. Obviously the crossover network will need to stay for the treble section since there are necessary SDA components in there. For this crossover can I also create a schematic and perform component upgrades similar to what VRF has done for the older SDA?
    If I keep the crossovers in there 5yr factory warranty will still be intact. Weighing the risk/rewards
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
    Clipdat Posts: 13,104
    Is there an audible performance benefit to bi-amping the L800s? If so, what process/testing methods did you use to determine this?
  • verb
    verb Posts: 10,176
    Congrats @ptrooper on acquiring a set of L800's! I'm still coveting a set myself! :smile:
  • dromunds
    mpitogo: is that your photo of your rig I saw on Polk’s ad for the L800? If so, very cool
  • mpitogo
    mpitogo Posts: 523
    @Clipdat for me there are two benefits to active bi-amping.
    1) treble gets single ended power amplificatIon needed to get the full benefits of the SDA channels
    2) power needed can be delivered to the speaker where it counts
    For testing I used my ears. I ran them for a month on a single McIntosh MC452 and it was lacking on the SDA magic I heard at the demo. I had burned in and tested with a McIntosh MC452 and a Marantz PM-10.
    Knowing about the deficiencies of SDA pulling a signal from differential balanced amplifiers, decided to try two non-balanced amplifiers a Rotel RA-1570 and a McIntosh MA5200. And immediately, I can hear the soundstage transform. I am now using an MA5200 for treble SDA and an MC452 for bass where power is needed.
    Hope that helps you.
    @dromunds yes it is.
    F1nut Posts: 52,376
    I heard the SDA magic when they were run off a Marantz pre pro and amp. Maybe it's the Mac that's lacking.
  • BlueFox
    BlueFox Posts: 15,250
    How the stereo separation with them close together?
    ptrooper wrote: »
    Toss the back out setting them up, or are you a recovering knuckle-dragger like me?
    Nice rig! B)
  • ptrooper
    ptrooper Posts: 672
    @nooshinjohn Definitely a recovering knuckle dragger here ,i use to be able to lift very heavy things. B)
    These are boxed very well , a trolly and instruction booklet made a very easy install.
    Much easier than the big boys!
    Isoacoustic GAIA are on the next wish list.
  • mpitogo
    mpitogo Posts: 523
    edited March 2020
    F1Nut. Please call Scott Orth or Stu Lumdnsen. Scott personally told me of the SDA power amp recommendations after I bought them. They can’t pull a proper signal from a balanced amplifier. Its likely also why they demo with Marantz single ended amps or the PM-KI Ruby because they are not balanced. My Marantz PM-10 also did not produce the SDA effect to its fullest. But the PM-10/SA-10 is absolutely rocking on my older 707s?
    If the PM/SA stack worked with the L800 i would have run with them. The combo is amazing.
    What is your proper amp recommendation for the L800? Maybe Parasound Halo A21+? I heard good things about parasound.
  • ptrooper
    ptrooper Posts: 672
    verb wrote: »
    Come on buddy, you can do it. Don't let the team down :p
  • mpitogo
    mpitogo Posts: 523
    @ptrooper very nice color. I love that gloss black front. I wonder why they made the Walnut a matte black.
    F1nut Posts: 52,376
    mpitogo wrote: »
    I said a Marantz pre pro and amp. I never said anything about the PM10.
  • mpitogo
    mpitogo Posts: 523
    @F1nut are you suggesting the McIntosh amps are inferior even though the Marantz PM-10 produce the same results with SDA?
    Apologies if I’m beating a dead horse but I’m responding to baseless comments.
    pitdogg2 Posts: 27,876
    Well if the L800's were sitting in my house, I wouldn't waste time on the A21+. It would be JC5 all the way!!
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited March 2020
    The JC5 is a Dual Mono Design. I seem to have read something about that mix not working well?
    Could very be wrong though, I'd love to have a JC5 to power my SDA's.
  • verb
    verb Posts: 10,176
    ptrooper wrote: »
    verb wrote: »
    Exactly how I feel! My birthday is not for a few months. :wink:
  • motorstereo
    motorstereo Posts: 2,422
    I thought I had heard that to and for that reason I didn't dare to try my dual mono Proton d1200 on my sda's for a long time. It turned out I heard wrong and that 1200 paired up quite well with my sda's.
  • Mike Reeter
    I think the Dual Mono issue has more to do with the new L800's...maybe ;)
    Yep true but both have balanced inputs. Maybe neither work work as well with SDA.
    I know with my SDA's and dreadnought the JC5 would work just fine. It just wouldn't work well with my bank account.
  • Mike Reeter
    I hear ya, would love to try the JC5 as well! But I can't stand tariff, especially after the past couple of weeks :#
    F1nut Posts: 52,376
    mpitogo wrote: »
    Nothing baseless about my comments. The problem is you have an issue with reading comprehension.
