Looking forward to L800 but have concerns, what are your thoughts?
joecoulson wrote: »Completely agree.
With what? -
Jimmy you're a toxic troll that hoped for genocide on a country. Do us all a favor and GTFO.
Agreed -
nooshinjohn wrote: »
Quoted. -
C'mon guys, let's get back to audio, this is a L800 thread
I am currently bi-amping my L800 to take advantage of the SDA with a single ended treble amplifier 160W@4ohms with a voltage gain matched quad-balanced bass amplifier 450W@4ohms.
I am about to setup my L800 with active Bi-Amp with the crossover set at 370Hz. Is it ok to remove the woofer low pass filter?
And on another note, the active crossover is a 3-way balanced crossover but currently only using it as a 2-way with High Pass and Low Pass filters, switchable to include a midband filter. Obviously the crossover network will need to stay for the treble section since there are necessary SDA components in there. For this crossover can I also create a schematic and perform component upgrades similar to what VRF has done for the older SDA?
If I keep the crossovers in there 5yr factory warranty will still be intact. Weighing the risk/rewards- Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
- Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.1 B&W Formation Duo and Bass
- Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
- Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
- Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
Is there an audible performance benefit to bi-amping the L800s? If so, what process/testing methods did you use to determine this?
Congrats @ptrooper on acquiring a set of L800's! I'm still coveting a set myself!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
mpitogo: is that your photo of your rig I saw on Polk’s ad for the L800? If so, very cool
@Clipdat for me there are two benefits to active bi-amping.
1) treble gets single ended power amplificatIon needed to get the full benefits of the SDA channels
2) power needed can be delivered to the speaker where it counts
For testing I used my ears. I ran them for a month on a single McIntosh MC452 and it was lacking on the SDA magic I heard at the demo. I had burned in and tested with a McIntosh MC452 and a Marantz PM-10.
Knowing about the deficiencies of SDA pulling a signal from differential balanced amplifiers, decided to try two non-balanced amplifiers a Rotel RA-1570 and a McIntosh MA5200. And immediately, I can hear the soundstage transform. I am now using an MA5200 for treble SDA and an MC452 for bass where power is needed.
Hope that helps you.
@dromunds yes it is.- Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
I heard the SDA magic when they were run off a Marantz pre pro and amp. Maybe it's the Mac that's lacking.
How the stereo separation with them close together?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
20 hrs running ❤️ They certainly like power
Toss the back out setting them up, or are you a recovering knuckle-dragger like me?
Nice rig!
F1Nut. Please call Scott Orth or Stu Lumdnsen. Scott personally told me of the SDA power amp recommendations after I bought them. They can’t pull a proper signal from a balanced amplifier. Its likely also why they demo with Marantz single ended amps or the PM-KI Ruby because they are not balanced. My Marantz PM-10 also did not produce the SDA effect to its fullest. But the PM-10/SA-10 is absolutely rocking on my older 707s?
If the PM/SA stack worked with the L800 i would have run with them. The combo is amazing.I heard the SDA magic when they were run off a Marantz pre pro and amp. Maybe it's the Mac that's lacking.
What is your proper amp recommendation for the L800? Maybe Parasound Halo A21+? I heard good things about parasound.
@ptrooper very nice color. I love that gloss black front. I wonder why they made the Walnut a matte black.
I said a Marantz pre pro and amp. I never said anything about the PM10. -
@F1nut are you suggesting the McIntosh amps are inferior even though the Marantz PM-10 produce the same results with SDA?
Apologies if I’m beating a dead horse but I’m responding to baseless comments.- Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
Well if the L800's were sitting in my house, I wouldn't waste time on the A21+. It would be JC5 all the way!!
The JC5 is a Dual Mono Design. I seem to have read something about that mix not working well?
Could very be wrong though, I'd love to have a JC5 to power my SDA's.
Exactly how I feel! My birthday is not for a few months.
Mike Reeter wrote: »
I thought I had heard that to and for that reason I didn't dare to try my dual mono Proton d1200 on my sda's for a long time. It turned out I heard wrong and that 1200 paired up quite well with my sda's. -
motorstereo wrote: »Mike Reeter wrote: »
I think the Dual Mono issue has more to do with the new L800's...maybe
Yep true but both have balanced inputs. Maybe neither work work as well with SDA.
I know with my SDA's and dreadnought the JC5 would work just fine. It just wouldn't work well with my bank account. -
I hear ya, would love to try the JC5 as well! But I can't stand tariff, especially after the past couple of weeks
Nothing baseless about my comments. The problem is you have an issue with reading comprehension.
