This joint needs some more vintage hifi
15658606162
  • jdjohn
    jdjohn Posts: 3,357
    there're a couple of pieces here with those -- none has broken, though (so far). I guess I am lucky careful(?).
    Fixed it for ya ;)
  • mlistens03
    mlistens03 Posts: 2,767
    jdjohn wrote: »
    Another recovery from my dad's collection: Technics SU-V8X integrated.
    4X 8600uF filter caps, and a hefty transformer. 120WPC into 8 ohms. Total weight close to 30lbs.
    This model has the 'Computer Drive New Class A', which apparently has something to do with self/synchro-biasing. This unit needs some love, but so far I am impressed with the sound. It's not a full-on beast, but approaching that status in a relative way, especially compared to its contemporaries from Japan.
    From what I've read, some of the New Class A stuff is very good, particularly the earlier examples, which yours appears to be. As you get into later, mid 80s stuff like the SU-v75 that I had (I think) It is all plastic but still sounds solidly OK.
    I have yet to find any earlier New Class A models in the flesh. :)
    pitdogg2 Posts: 27,051
    there're a couple of pieces here with those -- none has broken, though (so far). I guess I am lucky(?).
    Hard to break a shelf queen
    mhardy6647 Posts: 35,019
    There is that -- actually the Technicses get loaned out on occasion, so they do get the occasional twist.
    Beautiful piece of equipment.
  • deronb1
    deronb1 Posts: 5,021
    That's what she said!
  • jdjohn
    jdjohn Posts: 3,357
    Wardsweb wrote: »
    Luxman PD-121 with a beautiful Grace 714 teak tonearm.
    Gorgeous. I have the 704 version of that arm, and they are true works of art!
    I noticed you have a Shanling CD player. I have one of their portable digital audio players (DAP), and it sounds quite good. I had no idea they made higher-end components.
    tonyb Posts: 33,072
    Still have a sansui 771 sitting here doing nothing if anyone is interested. Trade ? Very clean.
    treitz3 Posts: 19,992
    That's pretty phat, Luthor! What material is that platter?
  • Wardsweb
    Wardsweb Posts: 942
    treitz3 wrote: »
    The platter is aluminum. The mat is rubber.
  • jdjohn
    jdjohn Posts: 3,357
    Wardsweb wrote: »
    treitz3 wrote: »
    I'm gonna go out on a limb and say 'cast' aluminum...as opposed to stamped :s
  • jdjohn
    jdjohn Posts: 3,357
    jdjohn wrote: »
    Fixed it for ya ;)
    Catching-up on projects, I made an improvement to the fragile, brittle, Technics twisty speaker cable hookups. I didn't have much choice on the Technics SU-V8X I'm rehabbing. Only 3.5 out of 8 plastic twisty connectors were left on the amp, so here I had removed all of them, and de-soldered the panel from the PCB.
    Note the tabs to which the red arrow points. Those tabs go into slotted holes on the PCB...not exactly conducive to lead wires.
    Rear holes left in the chassis shown here, which provided a template for drilling holes in the replacement panel.
    Note the slotted holes (yellow arrow) to which a lead wire needs to attach.
    This clipboard provided a sacrificial panel to mount inside the amp's rear chassis.
    All done...from the inside.
    After stripping the wire insulators, I had to press the strands flat in order to insert them into the PCB slots.
    And the binding posts:
    These were the bargain choices from Parts Express: https://www.parts-express.com/mini-gold-plated-insulated-5-way-binding-post-banana-jack-set-2-red-2-black--320-3375
    Only real hickup was forgetting to align the binding post drill-through holes for speaker cable ends. Doh! Had to unscrew, align, and tighten back. In the end, it works and sounds great!
    120WPC with decent headroom - damping around 100
    Most impressive young Skywalker. :)
  • JayMX
    JayMX Posts: 455
    edited March 2020
    I had a good vintage restoration Saturday day today. Finished up a full cosmetic rework (clean, paint, vinyl wrap, scale LED’s, new pointer light) of a Pioneer SX-626 and started on restoring a very ratty pair of Sansui AS-200's. They sounded good dirty. Hope they sound better after cleaning and a re-cap. Has anyone had ears on them?
    Post edited by JayMX on
    Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), SDA CRS+ (194’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩
    Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5B (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (4x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA1(mod to “a” & SL1000 Wuhan mod), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
    Tony M Posts: 11,623
    You've got SKILLs. ;)
    B)
  • jdjohn
    jdjohn Posts: 3,357
    la2vegas wrote: »
    I for one, hate using spring clips for speaker wires.
    Good job on that worthwhile project.
    Thanks guys! But...not sure about that 'young' part :)
  • vcwatkins
    vcwatkins Posts: 1,993
    jbreezy5 wrote: »
    jdjohn wrote: »
    A Dual 1019...who else is excited?!?
    I got a Dual 721. The speed varies a bit. I’m afraid to try to fix this after the photo. 😲
    Anyone know the pecking order for this against other Dual’s?
    Lotta ins, lotta outs, lotta what-have-you's in the old Duder's head.
  • dromunds
    dromunds Posts: 10,126
    Call or email or check the website of Fixmydual
  • LoStrings
    LoStrings Posts: 38
    I’ve been lusting over a set of Infinity QLS-1’s for many years, and I finally fulfilled my dream of getting a pair. I was fortunate to find a set that was completely restored...16i5nscfzmsz.jpeg
    edited April 2020
    It looks like you have the amperage to drive them.
    That's cool how the flood/spot lights can't shine their light on all of those towers and bass cabinets fronts. Man are they BIG!
    Congrats!
  • LoStrings
    LoStrings Posts: 38
    Tony M wrote: »
    Congrats!
    Thanks Tony, yes it takes a lot of amp to drive these..they are the lowest sensitivity speaker I have ever owned, but with the right power, they really shine.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,771
    LoStrings,
    Love that MASSIVE appearance!!
    Harry
    Harry / Marietta GA
  • LoStrings
    LoStrings Posts: 38
    LoStrings,
    Harry
    Thanks, Harry, the only problem is it is a lot to move around to listen to other speakers in my rotation.
  • oldrocker
    oldrocker Posts: 2,590
    JayMX.
    That 626 sure turned out nice!
  • oldrocker
    LoStrings wrote: »
    That setup is just scary looking WOW!!
  • jdjohn
    jdjohn Posts: 3,357
    The ElectroBrand 9700 mini receiver, about the size of a cigar box.
    Technical info on it is scarce, but based on the research I did, it's probably about 12WPC.
    Here are the very basic guts:
    Here is the rear, but I can tell you that the 'Phono' input is really just a line-level input.
    The FM tuner worked fine for me.
    Also, you can see that the speaker outputs are RCA proprietary, but I can confirm they work!
    I plan to give this to a family friend for use in his garage. Nice small footprint for the receiver. I'll also construct appropriate RCA speaker cables for him, plus I found a pair of wall-mounted indoor/outdoor Infinity speakers in my dad's collection to include.
    More info about the receiver here:
    https://audiokarma.org/forums/index.php?threads/bizarre-mini-stereo-receiver-electro-brand-9700.769401/
  • BlueBirdMusic
    Jody, was the ElectroBrand 9700 in your dad's collection? I like the tower orientation.
    Harry / Marietta GA
  • jdjohn
    jdjohn Posts: 3,357
    Hi Harry. Yes, it came from there.
