MagniFi Max SR - Surrounds Popping (despite software updates)
123457»
  • Nick_SNick_S Posts: 12
    edited April 2019
    Just watched Bohemian Rhapsody on BR on version 115 & experienced interference on right rear about 4 times during film (seemed to be a start of several of the songs). Played perfectly a few weeks ago on v.112, so something has changed for the worse. No wi-fi enabled devs or router anywhere near rears/sub or sound bar.
  • sultjapsultjap Posts: 5
    Having same issue with rear right on v 115
    Darn it - & it was all going so well!! Hopefully next update will fix but very frustrating, Not had any issues with v112 & was very happy with performance. I must of jinxed it by telling dealer all was now (finally) working 100%!!
  • As for background noise and firework sounds lol try turning down voice volume a notch or two it could be user error max volume was affecting my sb1 performance
  • My left rear surround speaker has been going crazy the last few weeks. I tried watching game of thrones last night with a few people over and they all commented on how bad it crackles... When the system works as it should, it's great. The problem is that it almost never works as it should anymore. Constant pops during shows... I have had this system for well over a year now and am really unimpressed with it not being fixed yet. I think this will have to be my last Polk product that I purchase.
    Firmware v115
  • mo_ustmo_ust Posts: 1
    It was perfect with 112. After v115, my rear surround keep crackles during movies for last few weeks. It is frustrated.
  • joesephKjoesephK Posts: 29
    I still have not had any issues with 115, same as 112 for me
  • EclizEcliz Posts: 29
    I also don't see any differences between 115 and 112
  • polksuxpolksux Posts: 1
    Another sucker here. No wonder the surround speakers were a free "bonus deal" they crack more than the local crack head.
    I just knew wireless speakers would be ****. Polk suck..
  • jaydencjaydenc Posts: 1
    edited May 2019
    No problem at 115, however still won’t recommend this sound bar to anybody
    Post edited by jaydenc on
    How does this problem relate to this topic?
  • LeeSoFLLeeSoFL Posts: 92
    Ecliz, I guess jaydenc edited the post you're speaking about.
  • So I got the sound bar first, and then added the surrounds like 6 months later on Christmas of 2018. They just didn't have a set with surrounds available at the time, and I'm in a rental house so I can't add a wired system very easily, I always had the intention of having a surround system. I am honestly, sadly regretting this purchase. The sound bar is great, gets loud, never had sub connection problems, bass is adequate. But man, these surrounds just won't stop popping! I have the crackle out of my left almost constantly, right sometimes. A low, quiet crackle that often my girlfriend can't even hear but it takes me out of whatever we're watching and fills me with a quiet rage. I actually plugged my surrounds into smart home plugs so I have the ability to turn them off from the couch, they're so bad. I usually don't have them turned on at all, then I'll try them until I hear the crackle and turn them off again. Total waste of $150 for the surrounds, and I guess the sound bar was a waste too because I only wanted one that supported surrounds. So if you're reading this thread because you're considering this sound bar, I advise stay away if you're aiming for a system with surrounds. There are other options, and if not they will be here soon probably. It's not worth the money these cost to just be frustrated and turn them off constantly.
  • BlueFoxBlueFox Posts: 13,060
    Why did you post here versus starting a new, relevant thread? Anyway, based on your description I would guess you are over driving the speaker since it only cost $150.
    Bud - Silicon Valley
    Lumin X1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Shunyata Triton v3/Typhon QR on preamp, Denali 2000 (2) on amps
    edited August 2019
    doublea423 wrote: »
    So I got the sound bar first, and then added the surrounds like 6 months later on Christmas of 2018... these surrounds just won't stop popping! I have the crackle out of my left almost constantly, right sometimes.
    Are you on the latest update, 115? I've gone thru lots of pain since Dec '17 when the snaps and crackles were widespread. Most people have had the problem corrected, some unfortunately started getting the pops with newer updates. There's an email address for a Polk person.
    Get in touch with them ↓↓ for personal assistance.
    [email protected]
    BlueFox wrote: »
    This is the place to hang your hat on a similar problem. It's much more visible here as a new post on an aged thread, as opposed to starting your own new one.
    I have no idea what you mean about over-driving the speaker based on the cost??
  • So I’ve been following this thread and the journey to pop-free sound. I just bought the soundbar and woofer only and purposely did not buy the SR speakers. Is the problem fixed yet with V.115? Are they safe to buy? If not, I’ll just live without surround speakers.
    I haven't had the surround pops for well over a year now. Purchased in Dec 2017 with problems from day one. Worked with Polk and it took a lot of time, but it's solid now. (my personal experience)
  • HI ALL THIS IS NOT AN UNCOMMON ISSUE AS YOU GUYS MUST HAVE SEEN SO MANY OF THEM ARE FACING THE SAME ISSUE..... I HAD THE ISSUE FOR COUPLE OF DAYS THEN AFTER GETTING LOT OF INSTRUCTIONS FROM THE TECHNICAL GUY OF THE COMPANY HERE IS WHAT WORKED....ALL YOU NEED TO DO IS
    1-RESET YOUR SOUNDBAR THEN RESTART
    2-USING GOOGLE HOME APP CONNECT THE BAR TO THE INTERNET
    3-SYNC WITH SUBWOOFER
    4-POWER OFF AND THEN ON AGAIN
    5- SYNC WITH SURROUND SPEAKER
    6 - POWER OFF AND ON AGAIN
    7-THIS TIME LET IT SIT FOR SOME TIME (MAKE SURE THE INTERNET IS ON)AND IT WILL SHOW ONE VOLUME LED (IT IS ACTUALLY UPDATING THE SURROUND SPEAKERS)
    8-ONE VOLUME LED GOES TO 2 THEN 2 TO 3 AND SO ON
    9-THEN IT WILL ALSO RESTART WITH ONE VOLUME LED AGAIN( I GUESS ITS WHEN THE FIRST SURROUND SPEAKER IS UPDATED AND STARTING TO UPDATE THE SECOND ONE )
    9-IN THE END WHEN DONE IT WILL SHOW GREEN LED AT THE END OF THE VOLUME LED'S THAT'S WHEN YOU KNOW THE SOUND BAR HAS UPDATED THE SURROUND SPEAKERS
    AND BINGO!!
    ENJOY !!
  • Viking64Viking64 Posts: 5,058
    AMITVAR27 wrote: »
    AND BINGO!!
    ENJOY !!
  • PexarPexar Posts: 1
    I had change my TV sound output setting from PCM to DTS neo 2.5 or Dolby Digital, it's works. Crackle noise is gone.
  • AdampoAdampo Posts: 2
    Pexar whats your magnifi max firmware version ?
  • dangishdangish Posts: 21
    Still having this issue
  • Just bought the polk..... wish I'd seen this tread 1st. Not so much a poping but definitely unusual goings on with the rear surrounds. I'll be returning the system if I can't sort it in the next week.
  • AMITVAR27 wrote: »
    AND BINGO!!
    ENJOY !!
    I'm going to try this
    Going on 2 years. SR1s pop like crazy. 115 is the last update I have.
Howdy, Stranger!
