Verb is outta control! A Hickok has landed!
I wouldn't get too worked up about rolling tubes in it, were I you
The Loktal was a Philco thing (in case you didn't know that), although I guess the design itself was Sylvania's provenance. Philco made relatively lots of components using 'em.
Push-pull 41 outputs -- whoo-hoo!
Get yourself an old vacuum tube manual -- if you haven't already.
This one will be helpful for the 'double digit' tubes
http://www.tubebooks.org/tubedata/RC12.pdf
Might be harder to find a one-stop shop for Loktal ("lock in", generically) tube data, but most of 'em will be here (e.g.):
http://www.tubebooks.org/tubedata/RC17.pdf
You probably know all of the secret arcane info on the Loktals, but -- in case you don't -- I'll risk a visit from the shadowy forces of the Loktal Cabal to share a few nuggets.
The 6V filament Loktals have type numbers starting with "7"
The 12V filament Loktals have type numbers starting with "14"
(this does not, of course, mean that there aren't 'normal' tubes with 7 or 14 volt filaments, especially later on, when cheap 'series-string' (killer) TV sets started using tubes with unusual filament voltages)
You probably also know that there are some secret gems among the Loktals
For example (shhhhhh... come closer... quiet...) -- the 7N7 is a 6SN7 in a different package. And the 7F7?, I hear you ask -- 6SL7 in a different bottle.
Of course... you didn't hear this from me.
http://vinylsavor.blogspot.com/2016/06/tube-of-month-7f7.html
I'm not going to be able to sleep now. :'(
Thanks Mark! I was hoping to get some more tutelage from you! Yeah the tube rolling on the Philco, meh, but nice to have some spares anyways!
Did not know about the 7N7's - Lot of em out there! And they make an adapter so those locktal's can fit into a regular octal socket, from what I've seen.
All very interesting. This tube journey I'm on!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Although buried inside the art deco cabinet, gotta love the look of those 41's!
Somewhere in there! BTW I'm stuck! Help me!
This was interesting to me. 3 circuits in one tube! the 7C6, a triode and double diode tube!
http://www.r-type.org/exhib/aah0008.htmBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
You found me! Now pull me out!
Tubes like that became pretty common in small/cheap radios (and car radios) -- to save space and money.This was interesting to me. 3 circuits in one tube! the 7C6, a triode and double diode tube!
Here's one from the late 1950s (just before car radio was taken over by transistors), e.g., the 12AJ6. Three functions (a triode and two diodes) in one 7 pin miniature envelope. This 'space charge' tube and its kin are unique in that they operate at low plate voltages and require no HV power supply -- late 1950s/early 1960s car radios used space charge tubes with transistor power amplifiers, and could run directly off of the car's "12V" power!
https://frank.pocnet.net/sheets/106/1/12AJ6.pdf
(borrowed image of a 12AJ6)
The GE "Compactrons" of the early 1960s were the ultimate expression of how many tubes can we pack into one envelope value engineering
at the tail end of the vacuum tube age. This was a last-ditch effort to keep tubes relevant, and some of the smallest, and cheapest (?!) color TV portables of the early/mid 1960s used a handful of Compactrons to do all the work. The GE "PortaColor" is the best (or, depending on one's perspective, worst) example.
The 6AC10 is a reasonable example: three triodes in one squat bottle with the 12 pin "duodecar" Compactron base.
https://frank.pocnet.net/sheets/123/6/6AC10.pdf
(image borrowed from the web of a 6AC10; the three sections are readily visible)
Then again, there's this... thing. I found this in a box of "plinkers" from my father's shop. I was deeply perplexed by it. Turns out it is a 6JU8: a color TV tube that contains four diodes in one envelope. The weirdest thing about it (IMO) -- the tube elements in it are arranged sideways compared to typical vacuum tubes.
DSC_4222 (2) by Mark Hardy, on Flickr
The 6JU8A was essentially the same tube, but looked more ordinary inside.
Just got these NOS 6SN7GTB babies! Looks like re-branded Sylvania (Black T-Plates), but, just me, gotta love the brand! And nice surprise that they came with the boxes!
@verb There’s a pair of these FS locally. If you were to pick them up at his asking price, you would be out of control
Seriously though, you should try to hunt down a (reasonably priced ) pair ...good luck!
https://www.audiogon.com/listings/lis9j08e-sylvania-jan-chs-6sn7w-tubes
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Wow those look sweet! Pretty close to us too!
btw, another nice tube score!
I can see how the tube caddy has become more of a need than a wantAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Stupid ridiculous price. But yes old tall bottle tube. They have always rated high. Not sure at that price my ears will ever hear the details. Just think back in the day they cost like 3 bucks a tube
Thanks Dog! Just arrived today! In the original shipping box too! Seller did a great job, double boxing everything.
That is sweet
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Thanks to both you guys, my next tube caddy is on order!
The way you guys roll no doubt about it
I’m sure it’ll sit on anti-vibration blocks and have a TOTL computerized climate control HVAC system
😂😂😂AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Picked up a few more tubes. Some Loktal's, a spare for the Peachtree, and a couple of 12SN7's to do some measurement comparisons between the 6SN7's!
➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
Finally had a chance to spend time with a fellow Michigan Polkie - @GlennDog ! Gave him a quick tutorial on the TV-7D\U tube tester, and a whirlwind demo of the many rigs I have all over the house!
Next time, a few more hours!
Envious of that Dave.
No worries my brother - anytime you need to borrow it. Let me know!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I thought I was at Axpona! Dave’s got gear in every room! A true music lover . . .
Dave’s tutorial on the use of the TV7 was very good! I spent this morning checking on some toobs!
Additional tutelage is in my future!
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Sweet.
I've actually been shopping tube testers. Nothing yet just eyeballing atm.
