Power Line EMI Meter - Alpha Labs (Demo Program)
1356
  • VR3VR3 Posts: 23,688
    Power conditioners are like cats, they are fun to play with at other people's houses, just not mine!
    - Not Tom
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
  • ClipdatClipdat Posts: 7,550
    delkal wrote: »
    I would not be concerned with numbers around 50. Close enough. But if I read correctly you said you were getting numbers around 470 directly from the Dectet at times. That would have to make me wonder.......
    Just for fun can you try plugging in your power conditioners to the noisy computer strip? If these conditioners do anything the number coming from the power out should be well under 1000.
    I don't have the meter anymore to try this.
    ^^^^^^^^Now that's a pretty big difference between those 2 units. Were they getting power from the same outlet for the comparison?
    No, they were each on their own 20a line.
    "Electronic music is human sound adapting to indulge technology, and for some, it feels like the signature sound of energy. New and abstract sounds over hypnotic rhythms can conjure vast soundscapes for escape, pleasure, and transcendence."
  • joecoulsonjoecoulson Posts: 4,108
    I would challenge any further meter testers to describe the difference in what they are hearing as it relates to the measurement discrepancies. What’s it doing to the sound?
    Auralic Vega G1/Rega TT/Denon SACD - Parasound P6 - PS Audio M700x2 - Elac Adante AF-61 - AQ Niagara 5000 - SVS SB16u
  • motorstereomotorstereo Posts: 1,396
    ^^^^^ When I swapped my 120 legs (one is very noisy at 6-800+ vs. 100 on the quieter one) there was a noticeable lowering of the noise floor. In my case I've found it's most noticeable through the phono circuit. Hands down the best upgrade I did this year was moving my 3 dedicated lines to the quiet leg. The improvement in the sound after the quieter circuits is the reason I caved in after many years to pony up the cash necessary for a good quality balanced pc, a furutech flux 50 and a shunyata power cord. Up until that point I had no idea how important clean power is or the difference it can make in bringing the rig to the next level. And all this all started with the simple to use alpha line meter thinking everything was fine and then I started measuring.
  • verbverb Posts: 9,032
    @monepolk you're up next! PM me your address. I'm gonna play with this thing over the next few days more (I'm off for the remainder of the year), and will get it out this weekend!
    Basement: Polk SDA SRS,Cary SLP-05 Pre,Enlightened Audio Designs CD Transport,Northstar Designs Excelsio DAC,Cambridge 851N streamer,Marantz SA-14 SACD,McIntosh MC300 Amp,Silnote Morpheus Ref2 Digital Cable,Furman 15PFi Power Conditioner,Pangea Power Cables,Wireworld Oasis 8 RCA IC's,MIT Shotgun S3 IC's,MIT Shotgun S1 Bi-Wire speaker cables
    Office: PC,EAR Acute CD Player,EAR 834L Pre,Northstar Designs Intenso DAC,PASS ACA Monoblocks,Denon UDR-F10 Cassette,Acoustic Technologies Classic FR Speakers,SVS SB12 Plus sub,MIT AVt2 speaker cables,IFI Purifier2,AQ Cinnamon USB cable,Groneberg Quatro Reference IC's
    Spare Room: Antique Sound Labs Wave AV-8 Monoblocks,Tisbury Mini Passive Pre,Tjoeb 99 tube CD player (modified Marantz CD-38),Analysis Plus Oval 9's,Zu Jumpers,AudioEngine B1 Streamer,Klipsch RB-61 v2,SVS PB1000 sub,Blue Jeans RCA IC's
    Living Room: Peachtree Nova Integrated,Cambridge CXN v2 Streamer,Rotel RCD-1072 CD player,Furman 15PFi Power Conditioner,Polk RT265 In Wall Speakers,Polk DSW Pro 660wi sub
  • audioluvraudioluvr Posts: 1,871
    I'm in also Dave. I have outlets behind each speaker in my living room and I'd be curious to know if my dreadnaught is adding noise since it's sitting behind one of my SDA's right next to an outlet. Great info here folks!
    Home System:
    SDA 1C's - Full mod with the help by Dave...
    1000 Va Dreadnought- w/ WireWorld Mini-Eclipse cables
    WireWorld Mini-Eclipse 7 speaker cables
    WireWorld Silver Eclipse IC's
    Cambridge Audio Azur 851N - DAC/Streamer
    Belles 21A Tube Pre
    Belles 350A Reference Amp
    BLE-Design 16mm Power Cables
    Denon DVD 2900
    Barn system:
    SDA SRS 2.3's Full mod done by myself
    Carver C-1 pre
    Carver M1.5t
    BluDenso - Bluetooth receiver/DAC
    Done! My pleasure sir! :smile:
  • delkaldelkal Posts: 645
    audioluvr wrote: »
    If your dreadnought is enclosed in a metal box you should not get any RFI interference or stray magnetic fields outside the container. The box will act like a Faraday cage.
    Still an interesting experiment to run........
  • mhardy6647mhardy6647 Posts: 24,519
    delkal wrote: »
    audioluvr wrote: »
    delkal wrote: »
    audioluvr wrote: »
    The box would have to be grounded (at RF ground potential, if memory serves)... wouldn't it?
    delkal wrote: »
    audioluvr wrote: »
    delkal wrote: »
    audioluvr wrote: »
    Not 100% sure but I don't think so. When the magnetic field hits the metal box it should generate a small electrical charge in one area. But since the whole box is conducting, the charge would just get canceled out. I am sure this is a gross oversimplification and there is a better technical explanation but with Faraday cages electrical signals should not get inside or outside of the box. The charge should stay on the conductive surrounding skin. They make bags you can place your cell phone or EZpass that stops them from receiving RFI signals. AFAIK they don't have to be grounded.
    But still definitely test this when you get the meter. First see if your line noise goes up when you play your stereo. We hear about all kinds of electronics polluting our AC power......Wouldn't it be ironic if one of your components did it too! Then unplug the interconnect. Whatever happens it will be interesting.
    edited December 2019
    ^^^^^^My meter says there's no increase in line noise here when I turn my rig on. But my balanced pc may have something to do with that. I hadn't thought of disconnecting my dreadnaught but I'm sure it's not adding any emi. Getting very low readings of 12-20 from my pc leads me to believe there isn't anything in the chain polluting the power.
    delkal wrote: »
    delkal wrote: »
    audioluvr wrote: »
    delkal wrote: »
    audioluvr wrote: »
    You are correct and I was (am) in space! sorry :p
    verb wrote: »
    So this is interesting. Super clean power upstairs in the spare room. Nothing running except the rig and ceiling light.
    Now checking the Shunyata Hydra 8, with the rig still running. No change. Interesting for sure.
    Can't clean already clean power? Interesting. As mentioned previously, EMI, although a biggie, is not the only factor when it come to power conditioning.
    It would certainly be interesting to bring the Hydra8 down into the office, and swap it out with the WW Spaceport.
    So today I checked the upstairs again, but this time I powered off the Shunyata and unplugged it from the wall. Then plugged it back it, and powered it up. Measured the EMI before and after. Pretty much the same readings, before and after, but this time down to about 11-12. Interesting.
    So while I'm pondering why I'm not seeing any difference in readings, this little guy is off to @monepolk either later today or tomorrow! :smile:
    Shipped out today to @monepolk ! PM sent.
  • GlennDogGlennDog Posts: 2,174
    While researching other audio stuff, I came across this comment
    “ Clearly the power supply on the NAS makes a difference ; also the NAS tends to pollute power all around the house, so it's nice to have a power filter ; and SSD is better than HDD ; and different routers, different ethernet cables yield different results ; a specialist I visited recently swears that attenuators on ethernet cables make a huge difference.”
    Power Rogue M180 monos & Adcom GFA 5802
    PS Audio PerfectWave Power Plant 10
    Rears Salk SuperCharged Surrounds
    Source PSA PWT into NSD Supremo
    Pre/Pro Integra DHC 40.1
    LCD Samsung LN46B750
    Mains Salk HT2-TL
    Center Salk HT2C
    Pre Cary SLP-05
    Wires WW & MIT
    GlennDog wrote: »
    Good insights Glenn. Probably a good idea to keep all computer equipment away from the same line as the audio.
    monepolk wrote: »
    Received!
    Yeah! :smile:
  • If it’s not too late I’d love to try this. I just purchased a Noise Harvester, still to be delivered and think my next move is tnot new equipment but rather having dedicated power.
    Thanks for this cool opportunity!
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platters & Neo TT-PSU
    Digital Source: Lumin T2 w/Roon
    Preamp: Rogue Ninety Nine Magnum
    Amp: Rogue Stereo 100
    Speakers: Audio Physic Tempo Plus (Tyler Linbrook Signature Monitors)
    Cables: Audio Art IC-3e & SC-5 ePlus, Signal Cable PCs
    Misc: APC H15 line conditioner, Noise Harvester, VTI rack, GIK acoustic panels
    Never too late! :smile:
    Wait! Hold everything! Am I not worthy? :'(
    Home System:
    Belles 21A Tube Pre
    Denon DVD 2900
    Barn system:
    Carver C-1 pre
    Carver M1.5t
    audioluvr wrote: »
    Of course you are most worthy! My bad. I now stand corrected! :smile:
    I'd be interested in seeing how clean the power is in other members lines. Just this morning I hit a new low of 9 coming out of the back of my Furman pc
  • monepolkmonepolk Posts: 1,063
    So far my highest reading was 245 @ 116V in one outlet the day I got it. But this morning the same outlet was 20 @ 120V. Most are 18 to 20 @ 116-120V.
    Wait, does that mean your AC mains are @ 124 VAC? That's smokin' :|
    Does it typically run that high at your house?
    ^^^No the voltage is fine; it just reads a bit high on that unit and yes I'd be concerned if it was up that high.
  • BlueFoxBlueFox Posts: 12,595
    LOL. Then why do you think the other measurement are accurate. :)
    Bud - Silicon Valley
    Lumin X1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Shunyata Triton v3/Typhon QR on preamp, Denali 2000 (2) on amps
Howdy, Stranger!
