Power Line EMI Meter - Alpha Labs (Demo Program)
13567
    VR3 Posts: 29,383
    Power conditioners are like cats, they are fun to play with at other people's houses, just not mine!
    Clipdat Posts: 13,078
    delkal wrote: »
    I would not be concerned with numbers around 50. Close enough. But if I read correctly you said you were getting numbers around 470 directly from the Dectet at times. That would have to make me wonder.......
    Just for fun can you try plugging in your power conditioners to the noisy computer strip? If these conditioners do anything the number coming from the power out should be well under 1000.
    I don't have the meter anymore to try this.
    ^^^^^^^^Now that's a pretty big difference between those 2 units. Were they getting power from the same outlet for the comparison?
    No, they were each on their own 20a line.
  • joecoulson
    joecoulson Posts: 4,943
    I would challenge any further meter testers to describe the difference in what they are hearing as it relates to the measurement discrepancies. What’s it doing to the sound?
  • motorstereo
    motorstereo Posts: 2,317
    ^^^^^ When I swapped my 120 legs (one is very noisy at 6-800+ vs. 100 on the quieter one) there was a noticeable lowering of the noise floor. In my case I've found it's most noticeable through the phono circuit. Hands down the best upgrade I did this year was moving my 3 dedicated lines to the quiet leg. The improvement in the sound after the quieter circuits is the reason I caved in after many years to pony up the cash necessary for a good quality balanced pc, a furutech flux 50 and a shunyata power cord. Up until that point I had no idea how important clean power is or the difference it can make in bringing the rig to the next level. And all this all started with the simple to use alpha line meter thinking everything was fine and then I started measuring.
  • verb
    verb Posts: 10,176
    @monepolk you're up next! PM me your address. I'm gonna play with this thing over the next few days more (I'm off for the remainder of the year), and will get it out this weekend!
    audioluvr Posts: 5,861
    I'm in also Dave. I have outlets behind each speaker in my living room and I'd be curious to know if my dreadnaught is adding noise since it's sitting behind one of my SDA's right next to an outlet. Great info here folks!
  • verb
    verb Posts: 10,176
    Done! My pleasure sir! :smile:
  • delkal
    delkal Posts: 764
    audioluvr wrote: »
    If your dreadnought is enclosed in a metal box you should not get any RFI interference or stray magnetic fields outside the container. The box will act like a Faraday cage.
    Still an interesting experiment to run........
    mhardy6647 Posts: 34,905
    delkal wrote: »
    audioluvr wrote: »
    delkal wrote: »
    audioluvr wrote: »
    The box would have to be grounded (at RF ground potential, if memory serves)... wouldn't it?
  • delkal
    delkal Posts: 764
    delkal wrote: »
    audioluvr wrote: »
    delkal wrote: »
    audioluvr wrote: »
    Not 100% sure but I don't think so. When the magnetic field hits the metal box it should generate a small electrical charge in one area. But since the whole box is conducting, the charge would just get canceled out. I am sure this is a gross oversimplification and there is a better technical explanation but with Faraday cages electrical signals should not get inside or outside of the box. The charge should stay on the conductive surrounding skin. They make bags you can place your cell phone or EZpass that stops them from receiving RFI signals. AFAIK they don't have to be grounded.
    But still definitely test this when you get the meter. First see if your line noise goes up when you play your stereo. We hear about all kinds of electronics polluting our AC power......Wouldn't it be ironic if one of your components did it too! Then unplug the interconnect. Whatever happens it will be interesting.
  • motorstereo
    edited December 2019
    ^^^^^^My meter says there's no increase in line noise here when I turn my rig on. But my balanced pc may have something to do with that. I hadn't thought of disconnecting my dreadnaught but I'm sure it's not adding any emi. Getting very low readings of 12-20 from my pc leads me to believe there isn't anything in the chain polluting the power.
    delkal wrote: »
    delkal wrote: »
    audioluvr wrote: »
    delkal wrote: »
    audioluvr wrote: »
    You are correct and I was (am) in space! sorry :p
  • verb
    verb Posts: 10,176
    verb wrote: »
    So this is interesting. Super clean power upstairs in the spare room. Nothing running except the rig and ceiling light.
    Now checking the Shunyata Hydra 8, with the rig still running. No change. Interesting for sure.
    Can't clean already clean power? Interesting. As mentioned previously, EMI, although a biggie, is not the only factor when it come to power conditioning.
    It would certainly be interesting to bring the Hydra8 down into the office, and swap it out with the WW Spaceport.
    So today I checked the upstairs again, but this time I powered off the Shunyata and unplugged it from the wall. Then plugged it back it, and powered it up. Measured the EMI before and after. Pretty much the same readings, before and after, but this time down to about 11-12. Interesting.
    So while I'm pondering why I'm not seeing any difference in readings, this little guy is off to @monepolk either later today or tomorrow! :smile:
  • verb
    verb Posts: 10,176
    Shipped out today to @monepolk ! PM sent.
  • GlennDog
    GlennDog Posts: 3,149
    While researching other audio stuff, I came across this comment
    “ Clearly the power supply on the NAS makes a difference ; also the NAS tends to pollute power all around the house, so it's nice to have a power filter ; and SSD is better than HDD ; and different routers, different ethernet cables yield different results ; a specialist I visited recently swears that attenuators on ethernet cables make a huge difference.”
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • verb
    verb Posts: 10,176
    GlennDog wrote: »
    Good insights Glenn. Probably a good idea to keep all computer equipment away from the same line as the audio.
  • verb
    verb Posts: 10,176
    monepolk wrote: »
    Received!
    Yeah! :smile:
  • If it’s not too late I’d love to try this. I just purchased a Noise Harvester, still to be delivered and think my next move is tnot new equipment but rather having dedicated power.
    Thanks for this cool opportunity!
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • verb
    verb Posts: 10,176
    Never too late! :smile:
    Wait! Hold everything! Am I not worthy? :'(
  • verb
    verb Posts: 10,176
    audioluvr wrote: »
    Of course you are most worthy! My bad. I now stand corrected! :smile:
  • motorstereo
    I'd be interested in seeing how clean the power is in other members lines. Just this morning I hit a new low of 9 coming out of the back of my Furman pc
  • monepolk
    monepolk Posts: 1,154
    So far my highest reading was 245 @ 116V in one outlet the day I got it. But this morning the same outlet was 20 @ 120V. Most are 18 to 20 @ 116-120V.
    Wait, does that mean your AC mains are @ 124 VAC? That's smokin' :|
    Does it typically run that high at your house?
  • motorstereo
    ^^^No the voltage is fine; it just reads a bit high on that unit and yes I'd be concerned if it was up that high.
  • BlueFox
    BlueFox Posts: 15,251
    LOL. Then why do you think the other measurement are accurate. :)
