Verb is outta control! A Hickok has landed!
The tester gives a reading from 0-120, and using the included manual to convert to Gm:
However some nice fella posted this conversion chart on line! You can use this complete chart (or linear interpolate yourself)
Those are a lot of numbers and lot of complicated math problems. Too much for my old eyes and brains (if any is still left)
Enjoy!! -
Lol! Nothing that an EXCEL spreadsheet can't handle!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
So today is tube checker day. Gonna check out the tester. Kinda nervous actually, as I have never done this before. My memories of checking tubes was going with my dad to the drugstore and watching him, but not really paying attention.
I was eyeing the candy aisle of course!
So I picked a couple of known good tubes, and ones that would not upset me too bad if I accidentally fried em!
EH 6SN7
Conn 12AU7
First the 6SN7. The included booklet has the settings as shown. Even the booklet is military grade, waterproofed, and thicker stock paper.
Power the tester on, let it warm up for a few minutes, triple check the settings, and pop the tube in! Let the tube warm up for a few minutes too.
Woohoo! I get a reading! Based on that, triode #1 is cranking out 1750 Gm, about average for a NOS tube. So far, so good!
Now the 12AU7.
Triple check the settings, and check the line test to make sure it's zeroed out.
Now check for Gm.
Based on this reading, and my little EXCEL calculator, this baby is cranking out 1725 Gm, again about average for a NOS tube.
So far, so good!
Good work!
Did you break out the mallet and check for microphonics?AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
No shorts? You checkin both triodes?
Put your skivvies back on I was referring to shorts within the tube
I haven't heard skivvies since my nanny (grandma) was alive.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Of course checked both sides.
Now the skivvies. Oh. I didn't see that in the manual either. My bad!
Post edited by verb onBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Good work!
My mallets are considerably larger than this little guy! From the web:
Well done ‘prazer!
😆😆😆😆😆😆AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Skivvies is a term my brother used while in the Marine CorpsHT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
So who said there is no drama in the tube testing world?
As many of you know, and what I do as an engineer at work, is not rely on a single test to make a decision about how a product performs. This could be the new parts that I am testing, or in other cases, the test set-up. Or even the test equipment.
We rely on tests results that can be repeated, with as many samples as possible, to ensure we have the best correlation between predicted values and actual test values.
Well, to a lesser degree, I used the same strategy on my newly acquired tester!
And, well, my results were, a bit wonky!
I re-tested the same tubes, again, and again, and got nothing! The indicator dial started acting a bit jerky, and then, zero. Repeat, same result.
So I tested a few more 6SN7's and 12AU7's (all known good tubes), zilch, zero, nada.
Sent a e-mail to the seller, offered his phone number, and we chatted for a bit. Got a good feeling during the conversation, as he was very apologetic, and proclaimed that this unit was just recently serviced and calibrated. He has done work with the famous Dan Nelson of Hickock calibration fame, but found a local guy (Columbus, OH area) that he claims does great work! Uh huh.
He offered to pay for my return shipping, take it back to his service guy, ensure nothing was damaged or got loose during shipping, and return the unit back to me. All at his cost. If after I get the unit back, and still not satisfied, will refund me in full. Sounds good so far.
I agreed, and will return the unit back to him this week. We'll see.
And the drama continues!
^^^ So this sounds like the fuel gauge in my 2007 Buick Rainier (only 64K on vehicle). In the past month the gauge goes from E to F and back <-> several times every few minutes while driving. I know this is a known GM faulty part. Why couldn't a corp. like GM with over 100 years of experience design a reliable fuel gauge or sending unit in the tank? Sounds like your Hickok Tube tester is doing the same thing. Can I send my used SUV back for repair?
aprazer402 wrote: »^^^ So this sounds like the fuel gauge in my 2007 Buick Rainier (only 64K on vehicle). In the past month the gauge goes from E to F and back <-> several times every few minutes while driving. I know this is a known GM faulty part. Why couldn't a corp. like GM with over 100 years of experience design a reliable fuel gauge or sending unit in the tank? Sounds like your Hickok Tube tester is doing the same thing. Can I send my used SUV back for repair?
Probably the stepper motor in the Instrument Cluster is failing. Yes a known issue, GM had a recall or service bulletion out there IIRC on a lot of vehicles back in the day, as the stepper motors were widely used. Not really a design issue, but a supplier quality issue (they are purchased directly from a Tier2 supplier). Any warranty costs incurred by GM would be billed back to the supplier.
A few suppliers actually went bankrupt due to the charge back costs. In those cases GM would have to eat the bill.
My 2004 SSR (less than 2000 miles) has the same issue.
There are refurbish companies out there that will re-build your cluster, replace all the stepper motors, not just the failed one, for not a lot of money.
I would not have a dealer swap out the cluster with an OEM one, as there is no guarantee the replacement would be any better. If they have it in stock of course. Dealers would probably just sent it out to one of the refurbish companies anyway in that case.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Verb, thank you very much for your reply, I was being a little too funny. I understand the part was made by another firm (supplier), I'm not sure what Tier2 means. As complicated as these vehicles are anymore, the manufacturer can't make every little piece, but they should somehow test the parts in advance, which I'm sure there is some process in place for. Not my area of expertise. I hope your tube tester comes back fixed, you've spent a lot of time with it so far.
aprazer402 wrote: »Verb, thank you very much for your reply, I was being a little too funny. I understand the part was made by another firm (supplier), I'm not sure what Tier2 means. As complicated as these vehicles are anymore, the manufacturer can't make every little piece, but they should somehow test the parts in advance, which I'm sure there is some process in place for. Not my area of expertise. I hope your tube tester comes back fixed, you've spent a lot of time with it so far.
No worries brother! My SSR got me a bit frustrated because the speedo died, then the fuel gauge, ugh. Prior to their death they did exactly as you described. I use my phone now as a speedo, and the fuel range function still works.
I don't drive that thing that much, but I'll get it fixed eventually. Most likely I'll pull the cluster out myself and send it to a shop, but the removal process on that thing is a bit of a pain.
Oh, Tier 2 is just another term for a supplier of a supplier! They supply the stepper motors to the instrument cluster supplier (Tier 1) who ships directly to us (OEM).Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
So it's probably the gauge stepper motor in the dash rather than the sending unit piece in the fuel tank?
My speedo is fine. If you have a portable Garmin it will post your speed too. -
That would be my guess. But again, could be the sending unit. Ugh, another supplier part!
Did a quick search. Interesting, that my 04 SSR is not on the list! Ugh.
https://www.motortrend.com/news/gm-will-pay-to-repair-faulty-fuel-gauges-on-2005-2007-suvs-124235/Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Sounds like my ex wife's 03 Silverado whole shaband went cattywampus one day. Removed the instrument cluster and it had to be rebuilt for 400.00
Yep. Nowadays it'll cost a bit less than that.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I've got an old Hickok 600 that was given to me decades ago.
I need to update and calibrate it ( recap)
It seems to work ok. If a tube has issues, it will tell me.
But as far as tube relative health, most likely a bit iffy.
I did replace the power cord, since all the insulation was crumbling off.
Cleaning switches is always a good idea on anything this old."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Say what ? Verb outta control ??
Tell me when he was actually "in" control.
lsi 9's -
^^^^ Agree!
Feels like I've been a kid in a candy store for the past 2 years! Wow, has it been that long?
Shipped the TV7 back today. And the drama continues! Hopefully everything will work out before I request a refund.
No drama to solid state. Just sayin'
Yeah those little glass bottles are fragile, for sure! But the benefits are worth the drama! IMO, of course!
