Post a picture... any picture
1…345346348350351…1153
  • Nightfall
    Nightfall Posts: 10,083
    @Viking64 what's that?
    afterburnt wrote: »
    Village Idiot of Club Polk
    Viking64 Posts: 7,808
    Nightfall wrote: »
    Normally I don't respond when people use that annoying "mention" feature, but in this case, I will make an exception. :p
    It is a "hub dust cap/cover" or a "wheel bearing dust cap/cover". It fits over that little hole in the center of the wheel. I highly recommend getting some, especially in the winter. They are about $4 on the internet.
  • boston1450
    boston1450 Posts: 7,758
    Hubcap works too
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    boston1450 wrote: »
    Hubcap works too
    As in a name for the dust cap or a hubcap in place of a dust cap?
  • Nightfall
    Good info, thanks. I never paid attention to that, my summer wheels are alloy's that are covered there.
    afterburnt wrote: »
  • boston1450
    My bad. When I say hubcap i mean the one that fits over the entire wheel
    Randy-Maine
    by David WMG
  • Nightfall
    Walmart has some pretty sweet plastic spinner hubcaps. That would be baller af.
    afterburnt wrote: »
    Nightfall wrote: »
    Is there a collar on the back side of the alloy wheels that fits into that center part? If not, you are still going to get salt in there.
    There is usually a notch in the threaded hub (to facilitate a cotter pin) that would/might allow salt to get into the wheel bearing, which would $uck goat appendages. :p
    edited October 2019
    Nightfall wrote: »
    That would upgrade your ride from a "chick magnet" to "chick vacuum"! :p
  • OleBoot
    OleBoot Posts: 3,138
    Viking64 wrote: »
    Nightfall wrote: »
    I have Walmart underpants.
    OleBoot wrote: »
    Is this leading up to a Michael Jackson joke? :p
  • OleBoot
    Viking64 wrote: »
    OleBoot wrote: »
    So I should put my underpants on ebay?
  • Nightfall
    We don't do salt here. Mag chloride I think it's called.
    It's just a snap in cap.
    afterburnt wrote: »
  • Nightfall
    It's crazy to me that Honda was putting super light weight Enkei alloy wheels on their economy cars.
    afterburnt wrote: »
    Nightfall wrote: »
    Magnesium chloride has the same affect as salt on a car.
    It doesn't appear that those wheels would prevent anything from getting in there. That plastic wheel center insert wouldn't cut it. There is just no real seal there.
    What year and model is it? I wonder if dust caps were stock or what the deal is?
  • Nightfall
    1995 Civic VX
    afterburnt wrote: »
    Nightfall wrote: »
    1995 Civic VX
    Here's a link for reference:
    https://www.ebay.com/itm/13990-Dorman-Wheel-Hub-Dust-Caps-2-In-Diameter/401070980485?fits=Year:1995|Model:Civic|Submodel:VX&epid=76611553&hash=item5d61b17d85:g:aEcAAOSwvQdcr2lq
    You can check and see which cars it fits, but it seems quite universal.
    It seems that most auto parts stores have them for $5-7 each. And considering the high production numbers of these Hondas, they should be very easy to find. All you would need is a rubber mallet or something similar to install them.
    I was worried that you might have issues when putting the alloys back on in the spring, but they are relatively low-profile so they are obviously designed to facilitate proper clearance.
    pitdogg2 Posts: 27,901
    I like using a large socket or ball joint cup to fit around it just on the outside rim as to not dent the dome.
    My .02
  • boston1450
    Put some of these on it & call it a day :)wl9zrsr2tpzn.jpg
    Randy-Maine
    by David WMG
  • Nightfall
    I've got more important things to spend money on, so I neglect cosmetic issues. It's had bubbly tint on it since I got it and I still haven't fixed that. If I was going to buy new wheels though I like the Volk TE 37's. They're stupid expensive though, so pretty unlikely.
    I wonder if anyone has ever put "muscle car" wheels on a Civic. I'm thinking it would look silly but I'm having a hard time picturing it.
    afterburnt wrote: »
  • Willow
    Willow Posts: 11,363
    Most up here leave hubcaps off. They tend to fall off with all the crusty snow and what ever you end up hitting. Our Rav goes just with what was once black rims, now looking rusty. The RDX has the OEM alum alloys that came with the vehicle for winter and some aftermarket ones for summer. This weekend is the changeover for the RDX the rav was done last week. YUCK!!
  • vcwatkins
    vcwatkins Posts: 1,992
    Chic Corea Trilogy with Christian McBride (!), Brian Blade - SO much better than expected! No prog, stuck with bop/post-bop. 3 Monk tunes. Had no idea Blade was so good. Just an unbelievable set. Catch 'em if you can.
  • aprazer402
    aprazer402 Posts: 3,463
    The two 1962 brochures were included, they are showing their age, acquired some moisture. The Lincoln turntable looks bulky and strange. Probably not very practical even in 1962.
    mhardy6647 Posts: 35,561
    You can watch that Lincoln/Fisher automatic changer in action in videos on Youtube. Yes it is bizarre.
  • aprazer402
    I watched it. Indeed it is. Thanks!
    edited October 2019
    Thorens made a moderately wild automatic rekkid playa, too.
    https://youtu.be/8QK_dgAV5yA
    Neither the Lincoln nor the Thorens really seem all that odd compared to myriad record playing contrivances employed in jukeboxes over the years, though. ;)
  • Willow
    Nothing exciting this year. It's been raining all day and we are expecting 30-50mm of rain.
    edited November 2019
    Evidence of time travel?
    A boom box... in 1971.
    B)
    source: http://reel2reeltexas.com/vinAd71.html
  • aprazer402
