Possible power outage for next two days
24567…15
  • daddyjt
    daddyjt Posts: 3,263
    One could be forgiven for calling this criminal incompetence. How many could die, especially if hospitals, nursing homes, dialysis centers, etc. close down? Even with backup generators, those big ones only have enough fuel for 48-72 hours of continual use...
    ― Aleksandr Solzhenitsyn
  • kevhed72
    kevhed72 Posts: 5,233
    Who is your power company....did you check their website or call them?
  • Jstas
    Jstas Posts: 15,018
    Kex wrote: »
    Not a single official from the Fire Department cited bad clearing as a contributing factor. 60% of such forest areas are managed at the federal level, not at the state or local level.
    That right there is the problem.
    Every state out here has a state forestry service that manages all forests in addition to the federal parks services that handle the national parks.
    Every independent and mostly out-of-state surveyor/analyst after every major fire in California has repeatedly stated that lax management is a contributing factor. Not contributing in how the fires start but in how fast they spread. The more ignition material on the ground near potential ignition sources the faster a fire can spread, especially in dry conditions. The faster a fire spreads, the more difficult it is for a fire fighting crew to get ahead of it and stay ahead of it to limit the advance of the flame front and minimize damage.
    Clearing power lines of extraneous debris and plant matter is a good idea no matter how you cut it. The management in California and, since you're blaming the feds 'cause it can't possibly be the management of the state's fault, is too lax. Improving management of the areas of potential fire sources is of utmost importance to management of a fire out break.
    If your transmission lines are hitting each other in the wind and causing big enough sparks to set stuff on fire then the two questions to ask here are:
    - Why are vital transmission lines so slack and placed so close together that wind gusts are causing them to interact with each other and start fires?
    - Why is there enough combustible material building up around the transmission wires that fire is a major concern?
    Expert Moron Extraordinaire
    John, normal people would ask those questions. We aren't dealing with normal.
    It's not that they can't fix this issue, it's that they simply won't, or have no will to allocate the funds. I'm just shocked, that they can allocate billions for other B.S. things, but something that effects everyone....nada ?
    How do business owners put up with this ? How do homeowners put up with this ? How does anyone in their right mind put up with this ? Is California now a 3rd world country ?
    I can understand being without power for 5 days if a hurricane comes through, major earthquake, things beyond our control. But purposely cutting it for 5 days....someone needs to lose a job or 2 over that.
    F1nut Posts: 52,406
    Understatement of the century!
  • daddyjt
    California also sues the Fed in court using bogus environmental regulation that prevent them from doing their part. CA may not have announced a succession from the United States, but everything they do and say demonstrates they want little to do with the rest of the nation, except they will take all money they can get from Uncle Sam...
  • BlueFox
    BlueFox Posts: 15,250
    So far power is still on here, but can’t speak about other areas. It appears to be delayed until later. Also, the wind is starting to pickup.
    ‘Around 234,000 will lose power during a second phase of shutoffs set to happen Wednesday afternoon and into the evening, PG&E said in an update.’
    https://www.kcra.com/article/pgande-power-shutoffs-california-wedenesday-wildfire/29409688#
  • Unknown
    edited October 2019
  • Nightfall
    Nightfall Posts: 10,083
    edited October 2019
    Wind is really picking up here even. Supposed to snow tonight and tomorrow morning.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • delkal
    delkal Posts: 764
    I don't blame the power company for turning off the power and limiting their liability. One of their power lines blew down in a storm last year. And they get sued for 12 billion dollars forcing them into bankruptcy.
    This wasn't an intentional act. Trees fall over and power lines go down everywhere. But only in California do the courts give these insane judgments against the "evil" power companies. And the residents were all applauding. Let them stew on reality now.
  • charley95
    charley95 Posts: 908
    I don't know how you guys survive in that state with all the lowlifes running the government. Are people really leaving in droves like the media would like us to believe?
  • Nightfall
    edited October 2019
    I've talked to people that moved here (Colorado) from California. See a lot of California license plates too. Hey, let's everyone move to Colorado and wreck their housing market and traffic too.
    afterburnt wrote: »
  • Unknown
    edited October 2019
  • charley95
    tonyb wrote: »
    Ok then, if the current power company is that frickin' bad, why are you still using them ? Nobody else available to supply power for the state ?
    I mean, it's not rocket science here, if they're doing such a horrible job, get rid of them or make them improve by regulations set onto them. Having power lines on the ground....is just unacceptable.
    ...and California needs to get their heads out of their rear ends and allow the forests to be cleaned up a bit. Again, it isn't rocket science on why that needs to be done.
    California hasn’t allowed any new infrastructure to be built(power plants, refineries, etc) in the last 50 years... in fact, government has forced many that exist to shut down through regulations and stopped others from being built through red tape and endless environmental lawsuits. Now, if they need to take a refinery down for maintenance, gas prices spike to absurd levels overnight.
    Bottom line isn’t there is no backup plan here. CA is a house of cards waiting for the next disaster....
    John, do you have future plans to leave the state or are you there for the long haul?
    F1nut Posts: 52,406
    Anybody for cooked and crispy worms?
  • Nightfall
    https://www.coloradovirtuallibrary.org/resource-sharing/state-pubs-blog/whos-moving-into-and-out-of-colorado/
    A lot of Californians and Texans moving here.
    According to a new report from the State Demography Office, “each year between 2011 and 2016 between 235,000 and 250,000 people moved into Colorado, and between 160,000 and 190,000 people moved out of Colorado.” That means our state’s population grows by about 60,000 to 75,000 people per year.
    The states that have the largest numbers of people moving to Colorado are California, Arizona, Texas, Florida, and Illinois, followed by New York, Virginia, North Carolina, Georgia, Missouri, and New Mexico. Arkansas, West Virginia, Vermont, and Maine had the fewest migrants into Colorado.
    afterburnt wrote: »
  • delkal
    delkal Posts: 764
    edited October 2019
    Can you even bury high voltage power lines on those huge tower's ?
    Kex wrote: »
    Apparently, it’s still under discussion for high risk areas, but who knows if it’s really feasible.
    I don't think you can. I saw a video of how they repair the high voltage wires while they are still live. A helicopter flies someone to the wires but before he can touch it he has to waive a long metal wand (attached to the helicopter) to equalize the charge. When they did a yard long spark shot out for a while before it was safe.
    And this was from an ungrounded helicopter. Imagine if it was underground next to earth. You would need a 20 ft wide tunnel with the wires insulated so they were exactly in the center. And you would need more than one.
    At least it is a good thing they don't have earthquakes in California.
  • Unknown
    edited October 2019
  • codycatalist
    codycatalist Posts: 2,661
    Nightfall wrote: »
    Lots of Californias moving here to AZ in troves as well. Same with Austin TX.
  • BlueFox
    Well, it is 8:10 PM, and power is still on here. While 500K people have lost power up North, there is no wind here. Hopefully we will bypass this mess.
  • Unknown
    edited October 2019
  • sucks2beme
    sucks2beme Posts: 5,703
    Utility issues are becoming common all over.
    Local power company asked for a modest rate hike to fix the grid again.
    And it was voted down by city council again.
    Every time it rains, power goes out all over.
    None of the lines are buried, and trees hit the lines all the time.
    We have a LOT of big trees. And they are all next to utility poles.
    They did come out and finally trim back stuff last fall in my area and
    my subdivision doesn't have as many issues since.
    mhardy6647 Posts: 35,562
    edited October 2019
    I am kind of amused by the news reports about this.
    "Hundreds of thousands of people", against the population of the suburban sprawl of 'metropolitan areas' of California, is basically in the background noise level.
    Now, if, say, the whole Bay Area went dark for a few days -- that'd be interesting.
    Heck, even the 1989 Loma Prieta earthquake's effect on the south bay was fairly limited. I flew to Chicago from SJC the next morning. The first wave of flights out was cancelled (because the planes didn't arrive the night before), but the second wave (planes that flew in from elsewhere in the morning) were all on-time.
    When I got to Chicago, my colleagues were surprised to see me. They assumed I'd be staying home to take care of the disaster they perceived had befallen the area. There certainly was disaster (particularly the collapse of the freeway bridge in Oakland) but most of us were basically unscathed.
    I dunno man, every other state has transmission lines up in the air, separated and secure enough to withstand some real gusty winds. Here around the Chicago area, you see them all over, and never have I heard of them blowing down, and we get some pretty gusty winds from storms in the 60-70mph range. Trees fall over before the lines do....so that tells me it can be done even in California.
    Maybe, the environmentalists don't want to see big towers dotting the landscape like in other states. I get it...but, you have to put the needs of the people first, not just the few.
    As for the comment about "saving lives" with this planned power outage, maybe we should get rid of cars too for periods of time, save thousands of lives. Oh, we need cars you say ? We need electricity too.
    Again, this is something that can be done, and the state needs to assist the power company in finding a solution other than cutting power on windy days. It's not hard, we have the know how, just help them fund the solution instead of funding other B.S. stuff. We grown ups like to call that prioritizing, or is that not acceptable anymore.
    It gets a little drier and hotter in (much of) California than it does in Chicago.
    Doesn't matter Doc, it's the wind that supposedly is knocking down the wires onto the dry ground. Since we can't control the weather, we can control how stable we built towers to hold those lines. Make sense ?
    If you bury the lines, yeah it's gonna cost more, but you still have earthquakes to contend with....and they get a few from time to time.
