Group-buy-2019-dreadnought-avel-lindberg-1000va-isolation-transformers
11112131416
  • verb
    verb Posts: 10,176
    Got home today and 2 heavy boxes were at my doorstep Woo Hoo! :smile:
    pitdogg2 Posts: 27,220
    Mine showed up yesterday. Still working on my plates. I took my flycutter and milled off all the powder coat...ready to be anodized.
    Thanks again to all involved for making this happen.
    nice counter sunk holes. what color you going with?
  • I think I'm going to go with a dark blue. I know Larry's are red so I dont want to copy him.lol
    The Night is Dark and Full of Terrors
  • verb
    verb Posts: 10,176
    So newbie question on the Neutrik chassis mount connector. Is this the preferred one? I've read that this is built better than the 2-pole version.
  • honestaquarian
    honestaquarian Posts: 3,258
    That's the one I got
    EndersShadow Posts: 17,718
    Correct. Use that one.
    Very nice that should be sweet.
    verb wrote: »
    Yes and air tight.... Don't need any molecules escaping the coffin.
  • verb
    verb Posts: 10,176
    verb wrote: »
    Yep. Seen some builds with the mating gasket.
    VR3 Posts: 29,526
    If you want to go wild, you can use this one, you would have to enlarge the hole though -
    https://www.fullcompass.com/prod/071941-neutrik-nlt4mp-heavy-duty-4-pole-speakon-chassis-connector-nickel?gclid=CjwKCAjwxrzoBRBBEiwAbtX1n0zdd4Uq2F0TWMwcgf2AfvHXq0h7Enmam_9NCJv3jv8KDqDIPhd_NhoCt8sQAvD_BwE
    I used this one on the utopias, liked the metal chassis
    verb wrote: »
    verb wrote: »
    Yes but some even with the gasket are not air tight. I still seal inside the with hot hot glue with the air tight models and around all binding posts.
  • verb
    verb Posts: 10,176
    VR3 wrote: »
    I saw that one! Have to open up the hole to clear 31mm diameter, doable for sure! :smile:
  • verb
    verb Posts: 10,176
    Ugh, and the mounting hole spacing has to increase! NL4MP panel cutout:
    F1nut Posts: 51,939
    That's the wrong one, you want the NL4MP-UC. Fits perfectly in the hole.
    The gasket just gives it a finished look.
  • vcwatkins
    vcwatkins Posts: 1,992
    PM sent to the six who have not confirmed receipt here in the thread.
    Sure hope @erniejade is not the last to receive his. :#
  • Great news! Just sat down to listen to the finished product and the first thing I noticed was dead silence. I’ve been running without the interconnection for a year because I couldn’t get it quiet with it, ground loop or something. Well worth the wait.
    Currently listening to Weather Report and the bells and cymbals are crisp and clear like never before.
    Thank you again for including me in this upgrade!
    This concludes two years of upgrades to my 1.2’s
    Until something else comes along of course!
    Eric
  • verb
    verb Posts: 10,176
    Gotcha. Same interface as the NL4MP, but that's the one with a higher current rating. Thank you sir! :smile:
    F1nut Posts: 51,939
    You got it.
  • verb
    verb Posts: 10,176
    edited June 2019
    Ok, next question, should've asked all at once, but I'm slow. :smile: And too lazy to search the basement for my box of 1C upgrade goodies from @westmassguy :smile: What is the preferred cable end connector?
    F1nut Posts: 51,939
    NLT4FX-BAG
  • verb
    verb Posts: 10,176
    NLT4FX-BAG
    Thanks again brother! :smile: Beautiful.
    Eric
    What brand is your amp?
    F1nut Posts: 51,939
    verb wrote: »
    NLT4FX-BAG
    If the end bell is too small for your cable you can rip off the rubber tip and the clip ring inside. If it's still too small grind out the end like I did.
    Rotel
    RB-1092
    Interesting. It should be common ground. I was thinking you might gave a hybrid type amp. Butler comes to mind.
    VR3 Posts: 29,526
    Fwiw, the gold tipped neutrik allows cables upwards of 5/8 thick
    F1nut Posts: 51,939
    edited June 2019
    The NLT4FX-BAG max opening with the rubber bushing still in it is also 16mm or 5/8". I needed 22mm for the MIT cable, which is why I enlarged the end bell by grinding out the inside. I know someone else simply cut off part of the end bell. I thought of that, but I was concerned the end bell would be too short. I will say the grinding process was a PITA.
  • motorstereo
    motorstereo Posts: 2,359
    Another option to enlarge the holes on the neutriks is to use a step drill. This is how I enlarged mine for my bi-wire MIT's. If I had to do it over I would not use bi-wires as that was a real challenge for my fat and not so steady fingers.
    You made it easy as well Craig. Your experience was truly needed and for that I say
    THANK YOU !! If we ever share the same space I owe you some adult beverages..
