Group-buy-2019-dreadnought-avel-lindberg-1000va-isolation-transformers
11112131416
  • verb
    verb Posts: 9,809
    Got home today and 2 heavy boxes were at my doorstep Woo Hoo! :smile:
    Basement: Polk SDA SRS, Cary SLP-05 Pre with ultimate upgrade,Enlightened Audio Designs CD Transport, Northstar Designs Excelsio DAC, Cambridge 851N streamer, Marantz SA-14 SACD, McIntosh MC300 Amp, Silnote Morpheus Ref2 Digital Cables, Furman 15PFi Power Conditioner, Pangea Power Cables, Wireworld Oasis 8 RCA IC's, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
    Office: PC, EAR Acute CD Player, EAR 834L Pre, Northstar Designs Intenso DAC, PASS ACA Monoblocks, Denon UDR-F10 Cassette, Acoustic Technologies Classic FR Speakers, SVS SB12 Plus sub, MIT AVt2 speaker cables, IFI Purifier2, AQ Cinnamon USB cable, Groneberg Quatro Reference IC's
    Spare Room: Antique Sound Labs Wave AV-8 Monoblocks, Tisbury Mini Passive Pre, Tjoeb 99 tube CD player (modified Marantz CD-38), Analysis Plus Oval 9's, Zu Jumpers, AudioEngine B1 Streamer, Klipsch RB-61 v2, SVS PB1000 sub, Blue Jeans RCA IC's, Shunyata Hydra 8 Power Conditioner
    Garage: Cambridge Audio 640A Integrated Amp, Project Box-E BT Streamer, Polk Tsi200 Bookies, Douglas Speaker Cables, Shunyata Power Conditioner
    pitdogg2 Posts: 18,537
    Mine showed up yesterday. Still working on my plates. I took my flycutter and milled off all the powder coat...ready to be anodized.
    Thanks again to all involved for making this happen.
    nice counter sunk holes. what color you going with?
  • I think I'm going to go with a dark blue. I know Larry's are red so I dont want to copy him.lol
    The Night is Dark and Full of Terrors
  • verb
    verb Posts: 9,809
    So newbie question on the Neutrik chassis mount connector. Is this the preferred one? I've read that this is built better than the 2-pole version.
  • honestaquarian
    honestaquarian Posts: 2,973
    That's the one I got
    EndersShadow Posts: 17,216
    Correct. Use that one.
    Very nice that should be sweet.
    verb wrote: »
    Yes and air tight.... Don't need any molecules escaping the coffin.
  • verb
    verb Posts: 9,809
    verb wrote: »
    Yep. Seen some builds with the mating gasket.
    VR3 Posts: 24,478
    If you want to go wild, you can use this one, you would have to enlarge the hole though -
    https://www.fullcompass.com/prod/071941-neutrik-nlt4mp-heavy-duty-4-pole-speakon-chassis-connector-nickel?gclid=CjwKCAjwxrzoBRBBEiwAbtX1n0zdd4Uq2F0TWMwcgf2AfvHXq0h7Enmam_9NCJv3jv8KDqDIPhd_NhoCt8sQAvD_BwE
    I used this one on the utopias, liked the metal chassis
    - Not Tom
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
    verb wrote: »
    verb wrote: »
    Yes but some even with the gasket are not air tight. I still seal inside the with hot hot glue with the air tight models and around all binding posts.
  • verb
    verb Posts: 9,809
    VR3 wrote: »
    I saw that one! Have to open up the hole to clear 31mm diameter, doable for sure! :smile:
  • verb
    verb Posts: 9,809
    Ugh, and the mounting hole spacing has to increase! NL4MP panel cutout:
    F1nut Posts: 45,732
    That's the wrong one, you want the NL4MP-UC. Fits perfectly in the hole.
    The gasket just gives it a finished look.
  • vcwatkins
    vcwatkins Posts: 1,989
    PM sent to the six who have not confirmed receipt here in the thread.
    Sure hope @erniejade is not the last to receive his. :#
    Study: Roon * ProJect Stream Box Ultra & Pre Box S2 * Pass ACA * DH Labs SS Q10 * Brines Folded ML-TQWT RS 40-1354
    Audio: PS Audio DirectStream Jr. * Belles 20a * Pass Aleph 30 - Zu Omen DW * Sunfire Sig II - Polk SRS 2.3tl * PSAudio PP3 * MIT S3
    Den: Sonore ultraRendu * Cary xCiter * Dayens Menuetto * KEF LS50
  • Great news! Just sat down to listen to the finished product and the first thing I noticed was dead silence. I’ve been running without the interconnection for a year because I couldn’t get it quiet with it, ground loop or something. Well worth the wait.
    Currently listening to Weather Report and the bells and cymbals are crisp and clear like never before.
    Thank you again for including me in this upgrade!
    This concludes two years of upgrades to my 1.2’s
    Until something else comes along of course!
    Eric
  • verb
    verb Posts: 9,809
    Gotcha. Same interface as the NL4MP, but that's the one with a higher current rating. Thank you sir! :smile:
    F1nut Posts: 45,732
    You got it.
  • verb
    verb Posts: 9,809
    edited June 2019
    Ok, next question, should've asked all at once, but I'm slow. :smile: And too lazy to search the basement for my box of 1C upgrade goodies from @westmassguy :smile: What is the preferred cable end connector?
    F1nut Posts: 45,732
    NLT4FX-BAG
  • verb
    verb Posts: 9,809
    NLT4FX-BAG
    Thanks again brother! :smile: Beautiful.
    Eric
    What brand is your amp?
    F1nut Posts: 45,732
    verb wrote: »
    NLT4FX-BAG
    If the end bell is too small for your cable you can rip off the rubber tip and the clip ring inside. If it's still too small grind out the end like I did.
    Rotel
    RB-1092
    Interesting. It should be common ground. I was thinking you might gave a hybrid type amp. Butler comes to mind.
    VR3 Posts: 24,478
    Fwiw, the gold tipped neutrik allows cables upwards of 5/8 thick
    - Not Tom
    F1nut Posts: 45,732
    edited June 2019
    The NLT4FX-BAG max opening with the rubber bushing still in it is also 16mm or 5/8". I needed 22mm for the MIT cable, which is why I enlarged the end bell by grinding out the inside. I know someone else simply cut off part of the end bell. I thought of that, but I was concerned the end bell would be too short. I will say the grinding process was a PITA.
  • motorstereo
    motorstereo Posts: 1,595
    Another option to enlarge the holes on the neutriks is to use a step drill. This is how I enlarged mine for my bi-wire MIT's. If I had to do it over I would not use bi-wires as that was a real challenge for my fat and not so steady fingers.
Howdy, Stranger!
