Group-buy-2019-dreadnought-avel-lindberg-1000va-isolation-transformers
11112131517
    F1nut Posts: 46,130
    audioluvr wrote: »
    No. Grade 5 steel. That's why I bake potatoed it
    Seems like flawed logic to me.
    gudnoyez Posts: 7,682
    Mine showed up today I'm glad my mailbox was big enough for it to fit in. I thought I had everything dont have a bolt what length and type am I needing? Glad we got enough guys together for these.
  • RobbyKY
    RobbyKY Posts: 117
    Mine arrived today. Guess it takes a little longer to haul this chunk of copper all the way down to Texas. Wife called me at work and said we had a package she couldn't pick up, knew immediately what it was. Weekend project!!f5igujo36mm0.jpg
    Media Room: Parasound JC-5, Cambridge 851N, Schiit Freya, SDA SRS 1.2tl
    Game Room: Carver M4.0t, Carver C-4000, Oppo BDP-105, SDA SRS 1.2tl
    Bar/Card Room: Carver TFM-55, Carver C-1(BillD), Oppo BDP-93, SDA SRS 3.1
    Son's Room: Carver TFM-55, Carver C-1(BillD), Laptop/AQ Dragonfly, SDA SRS 3.1
    Bedroom: McIntosh MC150, Cambridge CXN, SDA 2Btl
    Outdoor Pool Area: Yamaha R-N803 with four Polk Atrium 6
    HT: Polk RTi A9s, CSi-A6, RT-65, RTi-A3's, Marantz SR5012, XPA3, UDP-203, Epson 5040UB
    audioluvr Posts: 3,627
    audioluvr wrote: »
    Nuh uh!
    Cambridge Audio 851N Streamer/DAC
    Belles 350A Reference modded with Mundorf Supreme caps
    There is about a 5% genetic difference between apes and men …but that difference is the difference between throwing your own poo when you are annoyed …and Einstein, Shakespeare and Miss January.
    by Dr. Sardonicus
    VR3 Posts: 24,680
    These things are big and heavy, kind of like lugging around a cinder block (or two)
    - Not Tom
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
    F1nut Posts: 46,130
    edited June 2019
    audioluvr wrote: »
    audioluvr wrote: »
    Nuh uh!
    Not sure why you think aluminum foil wrapped around the bolt head is going to prevent the steel bolt from affecting the toroidal's magnetic field.
    Good to know a stainless steel bolt nut and washer and some dynamat extreme is what I'm after tommorow then, glad I double checked.
    F1nut Posts: 46,130
    gudnoyez wrote: »
    Brass or aluminum will work too.
    pitdogg2 Posts: 19,250
    Dang it all around me ... Glad it didn't arrive today rained cats and dogs. It would have been in the rain for hours.
    nooshinjohn Posts: 22,984
    A little water never hurt anything...
    The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with Pass Labs Xono Phono Preamp, Walker Precision Motor Drive, ClearAudio Goldfinger Statement V2 cartridge and Origin Conqueror Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X0.2 three chassis preamp, PS Audio PerfectWave DAC MkII, Pioneer Elite SC-LX701, Oppo UDP-205 4K Blu-ray player, Sony XBR70x850B 4k, Polk audio AB800 "in-wall" surrounds.
    “Every record has been destroyed or falsified, every book has been rewritten, every picture has been repainted, every statue and street building has been renamed, every date has been altered…History has stopped. Nothing exists except the endless present in which the party is always right” — George Orwell
    “If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
    It rained like crazy here to I was worried all day that if it showed up it would be soaked but it fit in our rather large mailbox with barley room to spare, surprised it did not tip over from the weight.
    EndersShadow Posts: 17,235
    I think gods trying to make me understand what Seattle is like 24/7, so I appreciate the heat and humidity of IN summers more lol...
  • daddyjt
    daddyjt Posts: 1,444
    vcwatkins wrote: »
    Well, I never received a shipping notice as was done in the past, but the transformer arrived a few minutes ago.
    Group buy members, please let me know when yours arrives.
    I'll send out confirmation requests later to those who don't confirm in this thread.
    Thanks for your patience!
    Mine both showed up today.
    Thank you again for organizing this sir!
    ― Aleksandr Solzhenitsyn
  • lightman1
    lightman1 Posts: 10,671
    Well..... I'm starting to think Sketchy Craig might have some redeeming values after all.......
    Perfect timing.. I got back to NC a couple of days ago and a few of us are heading to the mountains tomorrow. Up to HZtwikkers or whatever. The iron will make its debut there,
  • Thanks to all for making this happen. My heavy box appeared a couple days ago as well. Can’t wait to hear the new magic.
    What is the preferred method of attaching the four wires to the two male spades of the Speakon?
    Just twist them together and put them (2) in a female spade?
    Sounds to easy so must not be correct.
  • B-Man
    B-Man Posts: 13
    vcwatkins wrote: »
    Both of mine arrived on Thursday. Thanks again !!
  • daddyjt
    Spades are adequate, but I would recommend soldering them (I will be soldering mine). However, you must be careful not to melt the plastic of the Speakon. Use high heat, good flux, and be quick.
    VR3 Posts: 24,680
    If you are melting the speak on plastic you have it wayyyyy to hot and are hanging out way to long.
    I have soldered some heavy duty wires on to speak ons with no issues.
    - Not Tom
  • So, skip the female spade and solder wires directly to spade.
    Got it.
    Thank you for helping make it easier!
    F1nut Posts: 46,130
    It is easy.
    The Eagle has landed....
    F1nut Posts: 46,130
    Manticore wrote: »
    Well after a few hours of listening i am sold on this purchase of the Dreadnought. For me i have noticed more depth, width and an increase of my bass & mid bass. The sound is really improved for the better.
    I was going to go with a cut up MIT cable but, decided to use what i was originally using for an SDA cable. A Supra quad something or another. I wound up adding a jumper like i did when upgrading my 1C's so i am using all four connectors on the Neutric connector. An easy peasy job hooking up when using @DarqueKnight instructions. diqq5nc4u2uw.jpg
    Also, Larry this box is da bomb. This just adds to the total package with great looks & build. Quality through & through. Thank You Larry!!!!!!!!!!!!!!
    What's up with the extra wire/connections?
    VR3 Posts: 24,680
    Probably did jumpers for a shotgun approach
    - Not Tom
  • Manticore
    Manticore Posts: 408
    Yes i read about what Trey had done in an old post about going the shotgun approach using the Supra Quad wire. That is what i had done when i did my 1C upgrades to replace the original pin/blade SDA wire.
    Just a jumper between the not used Nuetric connectors. I liked the idea and have been happy with the Supra Quad shotgun SDA wire so instead of cutting up an MIT cable i just used another piece of the Supra Quad cable that i already had. Seems to be working great as i am very pleased with the way it turned out.
    I know you told me how to do it Jesse but, i didnt jump on a For sale MIT cable when i had the chance. I snoozed and loosed!
    Denon AVR X4200W
    Parasound A23 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    Vincent PHO 701 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk SDA 1C's modded
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
  • vcwatkins
    vcwatkins Posts: 1,989
    Help with DN cables needed!
    I need to make new DN cables from MIT Terminator2's. Any tips? Leave the network interface boxes in place? If yes, do they go at the DN end? I cannot remember if I already ordered Neutriks - is there a particular part# I should look for or avoid? Other considerations?
    Thanks for any help,
    Craig
    Study: Roon * ProJect Stream Box Ultra & Pre Box S2 * Pass ACA * DH Labs SS Q10 * Brines Folded ML-TQWT RS 40-1354
    Audio: PS Audio DirectStream Jr. * Belles 20a * Pass Aleph 30 - Zu Omen DW * Sunfire Sig II - Polk SRS 2.3tl * PSAudio PP3 * MIT S3
    Den: Sonore ultraRendu * Cary xCiter * Dayens Menuetto * KEF LS50
    F1nut Posts: 46,130
    edited June 2019
  • vcwatkins
    Excellent. Thanks F1!
    https://meniscusaudio.com/product/outrigger-spike-set-of-4/
    Thinking about ordering these outrigger spike combos for mine or does anyone have a better idea on something else?
  • Mine showed up yesterday. Still working on my plates. I took my flycutter and milled off all the powder coat...ready to be anodized.
    Thanks again to all involved for making this happen.
    The Night is Dark and Full of Terrors
