Group-buy-2019-dreadnought-avel-lindberg-1000va-isolation-transformers
Big iron was just dropped off at the warehouse. Sweet! I'm lazy. Who has a wiring schematic?
You are the Lightman... you don’t need no stinkin schematics. Just plug a couple bare wires straight into the wall and firmly grasp the others in your sweaty palms while standing in a bathtub.Big iron was just dropped off at the warehouse. Sweet! I'm lazy. Who has a wiring schematic?
Good times!
Its here! Its here!
Well after a few hours of listening i am sold on this purchase of the Dreadnought. For me i have noticed more depth, width and an increase of my bass & mid bass. The sound is really improved for the better.
I was going to go with a cut up MIT cable but, decided to use what i was originally using for an SDA cable. A Supra quad something or another. I wound up adding a jumper like i did when upgrading my 1C's so i am using all four connectors on the Neutric connector. An easy peasy job hooking up when using @DarqueKnight instructions.
Also, Larry this box is da bomb. This just adds to the total package with great looks & build. Quality through & through. Thank You Larry!!!!!!!!!!!!!!
Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh" -
Mine arrived today as well.....thanks again.
Mine arrived today also.
@vcwatkins Just unboxed mine. Craig, thank you for your efforts!➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S3.3 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
Putting it together! Sweet!
Looks like a lot of heavy metal being off-loaded today. Don't wait years to put them together like I did.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Opted to secure everything with aluminum rivets to minimize RF escaping and to give it that little extra industrial bling look. I also used a carriage bolt and bake potatoed the head.
Right Pin = Red/Yellow
Right Blade (Negative Speaker Terminal) = Black/Orange
Left Pin = Grey/Brown
Left Blade (Negative Speaker Terminal) = Blue/VioletGustard X26 Pro DAC
Is that carriage bolt non magnetic stainless steel ?
No. Grade 5 steel. That's why I bake potatoed itGustard X26 Pro DAC
Nice to see! I clearly remember being floored by how obvious the improvement was when I first set up the 800VA Dread, and then being equally impressed when I upgraded to the 1000VA. And yes, Larry's box totally completes it! Happy listening!Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
It's nice to see DK's and Larry's research and work paying off so well for so many sda owners.
Got mine in the mail yesterday. Like others have said, this thing is heavy! I have a project now, but it will be a few weeks before I get to it as we have a lot of family vacation time over the next few weeks.
Thanks all for this! This is going to be sweet once it is complete.Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Yamaha RX-V3800 Receiver
Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable -
Mine showed up today I'm glad my mailbox was big enough for it to fit in. I thought I had everything dont have a bolt what length and type am I needing? Glad we got enough guys together for these.
Mine arrived today. Guess it takes a little longer to haul this chunk of copper all the way down to Texas. Wife called me at work and said we had a package she couldn't pick up, knew immediately what it was. Weekend project!!
Media Room: Parasound JC-5, Cambridge 851N, Schiit Freya, SDA SRS 1.2tl
Game Room: Carver M4.0t, Carver C-4000, Oppo BDP-105, SDA SRS 1.2tl
Bar/Card Room: Carver TFM-55, Carver C-1(BillD), Oppo BDP-93, SDA SRS 3.1
Son's Room: Carver TFM-55, Carver C-1(BillD), Laptop/AQ Dragonfly, SDA SRS 3.1
Bedroom: McIntosh MC150, Cambridge CXN, SDA 2Btl
Outdoor Pool Area: Yamaha R-N803 with four Polk Atrium 6
HT: Polk RTi A9s, CSi-A6, RT-65, RTi-A3's, Marantz SR5012, XPA3, UDP-203, Epson 5040UB -
Nuh uh!Gustard X26 Pro DAC
These things are big and heavy, kind of like lugging around a cinder block (or two)
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Not sure why you think aluminum foil wrapped around the bolt head is going to prevent the steel bolt from affecting the toroidal's magnetic field. -
Good to know a stainless steel bolt nut and washer and some dynamat extreme is what I'm after tommorow then, glad I double checked.Home Theater
Brass or aluminum will work too. -
Dang it all around me ... Glad it didn't arrive today rained cats and dogs. It would have been in the rain for hours.
A little water never hurt anything...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
It rained like crazy here to I was worried all day that if it showed up it would be soaked but it fit in our rather large mailbox with barley room to spare, surprised it did not tip over from the weight.Home Theater
