Looking good Mark!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
mhardy6647 wrote: »took me two hours to make four freaking cables (numerous cases of pilot error -- good thing I wasn't helming a 737-MAX8
)... but, as I type this, all of the embarrassing cables have been purged from the main part of the upstairs hifi except for the tuner and the subwoofa.
Not that you'll be able to tell from the photos I just took
DSC_4264 (2) by Mark Hardy, on Flickr
I guess that depends on what you consider to be embarrassing. For example, I see one pair of Acoustic Research interconnect cables (all blue) and one pair of Monster Cable interconnects (fuzzy ones in the back, silver color with blue stripes) in the background ((bokeh)).
HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Yeah, but you essentially can't see the two brand new pairs now connecting the phono preamp and the DAC to that source selector/TVC "passive preamp"
You can see the pair of new cables going from the passive towards the amp.
I labeled the shield-connected ends of the connectors I made today (and earlier this week) with heatshrink. The first pair I made (seen in the photo above) just have a little snippet of masking tape at the shield-connected end
Today I began serious listening evaluation of a set of 1.5M Audioquest WEL RCA interconnects... so far I can say that solid silver is a vastly different listening experience, and that you don't need much of it to make a difference. The detail within the upper frequencies is definitely more airy and delicate. There is more space and shimmer up top as well, but it also walks the edge of inviting sibilance into the equation, which is not a good thing with Polk Audio's tweeters, even the RDO-198's.
At this point, my next focus will be to get my Dreadnaught built and install the new binding plates I have had laying around for a while. Beyond that, I think I have come to the point where there is very little left to do besides sit back and listen. If there are more improvements to be made, it will need to come from replacing the Polks.
I run a set of dh labs revelation which are solid silver... I agree it adds a hint of shimmer- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I find so far that on some recordings it really can elevate the performance of the artists, and on others it can be distracting. They also really seem to have an impact on the SDA side of things. Greater bloom, expansion of the soundstage and mire pinpoint imaging with a very focused center. It seems like I am running my center channel at times.
There seems to be just a bit more growl to electric guitars as well.Post edited by nooshinjohn onThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Got these puppies in, so far I am very impressed. Are they as good as my previous separates setup? No but I think it would be unrealistic to expect a 2000 set of speakers to keep up with 12k worth of equipment. I will say the difference is not huge though, and I haven’t even added the sub into the mix yet. I’m very happy with the decision to transition to these. Now waiting for some taller Skylan stands to come in!
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
Cool! And welcome! Post some pics of your fine work!
Pics from the changes to my Ariston RD11S last week. Also switched out my rectifier this morning on the Dynaco ST-70. Purchased an old Amperex GZ34 from the classifieds on here (Thanks to @mikeyb128 ) to replace a JJ GZ34.
I finally took the time to troubleshoot the buzz in my Quads. I thought it might be the cable box, and sure enough that's it. I was surprised that it was causing the ground loop through the HDMI cable. It happens if the HDMI cable is plugged directly into the TV as well. I also tried a different cable to verify and it continued. I'll try swapping boxes next.PS Audio Stellar Gain Cell DAC/Preamp
Denon DVD 2910
Quad 12L Active Monitors
Marin Logan Dynamo 700W -
Just got these locally from a CL ad. Analysis Plus Oval 9's speaker cables with locking banana's, and a set of silver coated jumpers, also Analysis Plus!
[emphasis added]Just got these locally from a CL ad. Analysis Plus Oval 9's speaker cables with locking banana's, and a set of silver coated jumpers, also Analysis Plus!
Is banana theft a big problem in your area?
sorry, couldn't resist.
I spent a few minutes still tryin' to document my fine new phalanx (kind of a mini-phalanx) of freshly-minted wires upstairs.
DSC_4275 (2) by Mark Hardy, on Flickr
DSC_4274 (2) by Mark Hardy, on Flickr
I might even swap out those dump find Monsters one of these days...
Hehe!
No but I like the locking aspect of em, so they don't get loose over time. Especially with the weight of those cables!
Today I mounted my Dreadnaught transformer inside its case and got the new terminal plates for my SDA's drilled out and installed the binding posts.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
This must mean you are in the market for monoblocks... HA! you're always in the market!Gustard X26 Pro DAC
If you have extra cable at the entrance you could re-terminate the F connector at the box and do not use the coax ground shield. Other's try 3 to 2 prong cheater plugs and it works. I believe its caused by having two different ground pontenials between house and cable. I've successfully used the F connector method with no problems. For some changing boxes doesn't help because it's not a box problem.
My .02 -
My .02
You're on the money. Changing the box didn't help at all. I tried running the cable through a Panamax, but that didn't help either. Finally tried running it through a surge protector and the problem is solved.PS Audio Stellar Gain Cell DAC/Preamp
Denon DVD 2910
Did a little cable management using some simple split look and cable clips. These stands are temporary as I am waiting for Skylans to come in but they don’t have any cable management built in, so this concept should also work well when those come in.
Gotta get my hands on a 2m set of eclipse rcas now. Anybody got one laying around?!
Nice Zach! Love the blue KEF's!
Installed the Analysis Plus Oval 9's on the Bottlehead rig. At about 1m, they were the perfect length! Howard Jones putting em through the paces now!
Very tidy setup you got there Dave2 Channel in my home attic/bar/man cave
stangman67 wrote: »Very tidy setup you got there Dave
Thanks Zach. I’m pretty arnal when it comes to cable management!
I think you should turn your new ribbon cables 180 degrees.
Just kidding.
They're fine.
You are welcome to come over and fix my cable mess any time you like.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Love to John. Next time I’m in CA for sure!
Looks great Dave! Notice any improvements in sound? Inquiring minds want to know...Gustard X26 Pro DAC
Nothing really jumped out as compared to a set of Douglass Connections cables I had previously. But I didn't really spend too much time with em, as the Bottlehead was put aside for the Antique Sound Labs monoblocks!
Ah. NICE SWAP! NEED PICS...Gustard X26 Pro DAC
Crazy journey I'm on!
https://forum.polkaudio.com/discussion/186131/antique-sound-labs-in-verbs-house#latestBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Today I thanked God for all of the more money than brains audiophiles out there buying uber-expensive gear and cables, for without them, there would be no secondary markets for guys like me to be able to cash in at pennies on the dollar.
Thanks for the great deals and even better sound.
