Soldered in the 16 new leds for the meter lights yesterday and they're not photogenic at all. Much better than original incandescents a lot of which were burnt out.
nooshinjohn wrote: »
These will be used to connect from my preamp to the amplifiers... I should have them in a week or so.
Dang! those are nice - did you get a good deal on these too? -
Built some Wireworld Mini-Eclipse interconnect cables for my Dreadnought in anticipation of the new A/L 1000va tranny on order!
I made some cables today, too!
Rather more modest, prosaic, and unbalanced.
My next-door neighbor delivered a package to me today saying that the USPS driver threw the box on his front porch from a distance where it tumbled like a bowling ball until it came to a stop
MOTHER TRUCKERS !
My system is ON and the tubes are piping hot, so I’ll roll these in tomorrow…
Anyone have experience with bottom getters?
3rd pic is a comparison between the Tung Sol short base w/ tall bottle & Sylv that’s just slightly shorter in overall length
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
No experience, but dibs on your hand me downs!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
If I don’t wear them out first!
I forgot to mention all 6 sides of the box tossed on the porch were blatantly covered in RED fragile stickersAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Installed these:
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
Nice!Gustard X26 Pro DAC
MOTHER TRUCKERS !
Those are nice tubes. I have several with bottom getters. Those VT-231/ 6SN7's are early and most had foil bottom getters or rectangular bottom getters.
I have a pair of 1945 Sylvania's with foil getters. Mine are ladder plates those are box plates. I'd expect those to have rectangular bottom getters
I have a pair of Tung-Sol's just like those. They have a warm sound to my ears in my tube buffer. -
Last night I went back to the Mullard 12au7 in the Vincent phono pre and well I like what I’m hearing. Not sure how to explain, I just like it more. The CBS was no slouch but it had a higher noise floor.
Nice to have options. -
joecoulson wrote: »Nice to have options.
Indeed!
Although I wish I had access to less expensive tubes
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Price was right so I had to give these a try.
About to pay the repair bill on a pass labs amp...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
X150, bad voltage regulators- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
It won't be anywhere near as bad as what you expect...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
It should work better than new.
My XP-22 pre was recently repaired, but it was new enough to be free. I sure hope neither X600 amps break because they each weigh over 100 lbs, and I have zero desire to box and ship them.
Three 20 amp circuits. -
motorstereo wrote: »Price was right so I had to give these a try.
Would love for you to do a review on these with a/b testing -
Or simply a comment of if they improved at all...
Verb, I missed that one. Do you have the Cliff notes on the conclusion?
Please do not discombobulate the rest of the membership. Bad Ju-Ju will happen, Skip.
Thanks Verb!
NO!!!! Not more JuJu….The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Awesome! Thank you for posting that review Verb. From what I gather it seems the best place for me to use them is on my dedicated circuits which I wasn't doing because the harvesters blink the slowest on them. Now I need to order one more.
I built another pair of wires yesterday -- gonna do one (ideally, two) more pairs today, too.
The only problem is that it's still cold in the basement -- have to use the soldering iron for warmth.
took me two hours to make four freaking cables (numerous cases of pilot error -- good thing I wasn't helming a 737-MAX8
)... but, as I type this, all of the embarrassing cables have been purged from the main part of the upstairs hifi except for the tuner and the subwoofa.
Not that you'll be able to tell from the photos I just took
DSC_4264 (2) by Mark Hardy, on Flickr
DSC_4262 (2) by Mark Hardy, on Flickr
