12223252728202
  • joecoulson
    joecoulson Posts: 4,943
    Something new afoot for the coulson rig...
  • jdjohn
    jdjohn Posts: 3,380
    joecoulson wrote: »
    What!?! Besides the M700s???
    audioluvr Posts: 5,983
    Gerres26 wrote: »
    Just added this bad boy to my rig...
    My first step into the tube world, and boy does this Modwright sound sweet!
    PURDY!
    pitdogg2 Posts: 27,257
    steveinaz wrote: »
    I just realized that in 2018-2019, I replaced my entire system (sans my power center). 2018 brought the PSB Imagine T2's, Parasound A21, and Kimber 8VS bi-wire spkr cables; 2019 brought the PS Audio Stellar GCD, Bluesound Node 2i, and Kimber Hero XLR's. Holy crap, how did I sneak this major upgrade past the wife? Awesome.
    Prolly shouldn't look in her closet then..... :blush:
  • joecoulson
    edited March 2019
    jdjohn wrote: »
    joecoulson wrote: »
    Lol. No just That. Forgot I already posted about it. Just excited is all :D
    audioluvr wrote: »
    Okay so I did some comparison between my XLR's and my RCA IC's and there is a definite difference that makes the XLR's loose terribly. First they ad a harshness to the high frequencies that make it unpleasant to listen to. Also with the regular IC's the sound stage gets wider, higher, lower, deeper and far smoother and greatly detailed. Listening to The Beatles' "Yesterday" you can pick out the exact location of each instrument and it's depth on stage by inches. Gonna post this info on my CA post.
    Hate to sound like a broken record, but your first mistake was to go to monoprice for a balanced cable. Just sayin'...
    Up your game a bit with Audioquest, Kimber, or better if the wallet allows.
    Clipdat Posts: 13,100
    tonyb wrote: »
    Why is it a "mistake"? I'm currently getting amazing sound with them in my system, running from the stellar pre to S300.
  • stangman67
    stangman67 Posts: 2,328
    Paid Backert to do some tasty mods on my Rhumba 1. Should have it back in a little while!
    VR3 Posts: 29,540
    Installed this bad boy... Really transformed the rig
  • joecoulson
    Optimus or the speaker?
  • halo
    halo Posts: 5,618
    stangman67 wrote: »
    You've got a pre and an amp modded by Mr. Backert. Pretty Schweet!
    VR3 Posts: 29,540
    joecoulson wrote: »
    Optimus Prime!
  • GlennDog
    GlennDog Posts: 3,158
    stangman67 wrote: »
    Did you do the secret bass mods that are hard as nails to get details on?
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • stangman67
    edited March 2019
    They didn’t tell me much. They recommended a power supply and gain stage upgrade. I did everything they recommended and we will see how it pans out. I originally sent it in to have some hiss looked at and mentioned I’d like to get whatever easy upgrades are available and those 2 are what I ended up with. According to Andy it’s pretty much on par with the 1.3 now
  • GlennDog
    I'm expecting delivery of a Revalation Audio Labs CryoSilver Reference umbilical power cord for the new-to-me Cary ...
    and ahem, today I ordered some new replacement lamps for the burnt back light bulbs for the volt and current meters
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    nooshinjohn Posts: 25,991
    Tomorrow the Audioquest Meteor speaker cables will get here along with the new 72v DBS boxes.
  • joecoulson
    Sweet. Pics when hooked up John please.
  • joecoulson
    Can we get a review of how Prime changed the rig trey? Imaging? Dynamics etc.
    joecoulson wrote: »
    No problem, but I may not get them in the rig until Saturday. I have to open up the wall behind the turntable to swap cables out.
    VR3 Posts: 29,540
    He really brought out the cheese one liners and dragged out the chorus versus getting the ending down right
  • voltz
    voltz Posts: 5,384
    I had a set of AQ gibraltar's and Rocket 33's and both went to the way side in favor of the acoustic zen satori cables..
    The AQ's was a let down in comparisons! just me 2 cents or 1 depending on how you feel about my opinions ;)
  • joecoulson
    At the recommendation of @voltz I have these on the way to me
    Cool gents, nice cables, have them myself. One of the best out there for a midfi system. If your looking for a cable to breathe some new life into your system, these are them.
    Pair them with the AZ matrix 2's or higher IC's. I've also found the Wireworld Eclipse 7 IC's work well with them also. Have used Analysis Plus crystal ovals with these Satori's also with good results.
    Looking forward to your thoughts.
  • motorstereo
    motorstereo Posts: 2,359
    Soldered in 6 new led panel lights in one of my monoblocks. One side completed and one more to go.
  • motorhead43026
    motorhead43026 Posts: 4,030
    I rotated the SDA2BTL's back into the lineup. Although my room is way less than ideal they sound really good. Much more meaty than the S60's.
    – Kevin Alfred Strom
  • maxward
    maxward Posts: 1,715
    I pulled the Joule out of the rack to use my Deoxit vacuum tube survival kit received yesterday along with 100 MFSL record sleeves. The Joule was dropping the left channel for some time and after a lot of sleuthing and hand wringing, it has behaved itself after I last removed and replaced the tubes several times. Swapping tubes never changed the channel, so I figured the problem might have been a dirty tube socket. These were never cleaned before today and it showed. Wish I’d thought of getting this kit (or at least a very thin brush) much earlier. At least now I also have all new caps on the power supply side. Time to think about doing the rest of the capacitors.
    They are full-run bi-wires... basically TWO pairs for the price of one!yio4f8dfapzz.jpg
  • Mikey081057
    Mikey081057 Posts: 7,127
    I have that same carpet.... I'm gonna replace it soon tho...
    Garage | Polk Monitor 5B's
    very nice Mr. John ;)
    edited March 2019
    I have a phone call into the seller now. The cables do not have factory terminations on them and a sticker or tag that identifies them as being demos. I’m wanting to learn more about the providence of these cables before I install them. If they are legitimate factory cables my plan is to get them over to audio quest and have them re-terminated.
    If they are not factory cables or if the seller cannot confirm the legitimacy of the cables or refuses to let me send them to audio quest for re-termination then I will be requesting a refund.
    Post edited by nooshinjohn on
